    Blender forum in sketchucation
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 21 Posters 37.0k Views 21 Watching
    • andybotA Offline
      andybot
      Do we have a subforum yet!? πŸ˜„ I want to discuss pros and cons of obj vs. dae format import. Nice intro video you linked Solo, glad to see they are finally taking seriously the UI compatibility with other software
      • PixeroP Offline
        Pixero
        I just bought Chip Walters Blender video course and so far I'm enjoying it.
        Much info in a short time so I'm sure I have to go back to remember everything.
        Recommended.
        Right now there is a reduced price also.
        • pbacotP Offline
          @box said:
          Something to keep in mind, all software, just like any analog tool, is only as good as how well you learn how to use it. The correct hammer and chisel in untrained hands will reveal a driveway from a block of marble instead of a David.
          Some of us just need a driveway ( I could use a new one, concrete not marble). And a forum is helpful for learning how. Not much help in getting a David though (I'd need a TON more to get there myself πŸ˜› )
          • chippwaltersC Offline
            chippwalters
            Hey all,
            As many of you may know, I have a course that takes you from modeling in SketchUp to rendering and animating using EEVEE (Blender's realtime photorealistic renderer) in Blender.
            It's at https://gum.co/EEVEE
            Also, here's one of the lessons from the course which may get some of you started. It's on IMPORTING from SketchUp to Blender while keeping the proper scale units.
            Currently working with Cross-Reality technologies
              Don't know if it's indispensable...because collada format seems working...
              (i see that Premium SKetchucation members has a cool reduction) πŸ˜‰
              • N Offline
                nlipovac
                BlendUp is no longer available.
                  Khai
                  the main problem is, DAE is a poorly supported format.
                  no no! hear me out!
                  there's plenty of apps that write DAE.. but damn few that read it.
                  but there's plenty that do read OBJ - it's the almost universal 3D format..
                    chippwalters
                    Awhile back, I bought that, then tried to contact the author-- all with no results. It's dead for sure. Even if it did work, it wouldn't work in 2.8 as they now use Collections instead of Layers.
                    • ntxdaveN Offline
                      ntxdave
                      So what is the best way to move my models to Blender 2.8?
                      I tried .dae and only parts showed up. I also tried fbx but got a message in Blener 2.8 that it did not support fbx.
                      Press F1...thank me later
                        chippwalters
                        See my YouTube video above. It walks you through all the settings.
                          rv1974
                          @chipp, are they planning to add skp to supported import formats?
                          • andybotA Offline
                            andybot
                            I've been consistently using .obj export for years with good results. I find duplicate faces and lots of other problems with .dae
                            You can use AutoDesk's FBX converter to convert to a different FBX format that will import correctly. I forget the details as I use it infrequently, but it is possible.
                            • soloS Offline
                              We are still waiting for Rich O'Brien to create the subforum, I do not have admin rights to do it.
                              • andybotA Offline
                                andybot
                                Sounds like some more changes coming to Sketchucation than just an additional subforum πŸ˜„
                                http://sketchucation.com/forums/viewtopic.php?p=646088#p646088
                                @rich o brien said:
                                OK, we'll get you guys a Blender forum for SketchUp users up and running.
                                We are doing some server upgrades at the moment as we need to move to a newer php version. So give us a day or 2 to get something set up.
                                • F Offline
                                  fossa
                                  Looking forward to the new Blender sub-forum. The 2.8 UI overhaul is unbelievable. Kudos all around for the blender devs that worked on that. Can't wait for more Blender topics....
                                  In response to some threads above about DAE vs OBJ. I've been having good luck with DAE imports from SU. It places all objects in an "empty" and scales the empty to the correct units. Haven't had any problems with duplicate faces.
                                  Now I'm just trying to figure out how to deal with "empty" object types in Blender. πŸ˜„
                                  • pbacotP Offline
                                    I've also used the Blender skp importer add-on, but it only works up to 2.79 and then you can open in 2.8.
                                      Khai
                                      Thinking, while we're waiting, could we make clearly labeled threads (think "blenducation : having issues importing....") to go on with, with the labels making it easy to round em up and move them when the forums active?
                                        chippwalters
                                        Haven't heard anything about that. I sorta doubt it. Of course someone could always write a plugin, but going from SU to Blender isn't that hard using .OBJ (IMO).
                                          chippwalters
                                          I guess this never happened. 😞
                                          • 2 / 3
