    Blender forum in sketchucation
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 21 Posters 37.0k Views 21 Watching
      Khai
      @hepf said:
      I usually hop from sketchup (make) to Blender, and it is rather painless, apart some quirks. Blender accepts .dae rather well. Instead I've had problems with exports from Sketchup to DAZ Studio, which is strange, since both programs use .dae as the default format. Any idea?
      I'm betting only part of the model comes in.
      and I'm thinking, you make your models multi coloured...? and I'll say of you keep them default white they load fine..
      yup ran into that when I tried it. seems (from my limited understanding) SU puts out a DAE with each colour as an object and DS has issues with the way it's doing that.
        Bim ---> FreeCad --> Blender
        Animation πŸ˜‰
        https://pbs.twimg.com/media/DvspZT3X4AIltIi.jpg
        https://pbs.twimg.com/media/DudzXagV4AEkeld.jpg
        https://pbs.twimg.com/media/Dudzb3gUUAAaZGb.jpg
        • ntxdaveN Offline
          ntxdave
          Pilou, are you saying (showing us) that Blender has the ability to print documents like LayOut?
          Press F1...thank me later
            liam887
            Well I am 4 days in and having lots of fun!
            VISIT MY ONLINE GALLERY
            • pbacotP Offline
              what is it?
                No, for the moment it makes "easily" (depends of users skill πŸ˜‰ animations of parts of Bim files!
                But sure that in a few times, it will be capable! πŸ˜‰
                  liam887
                  @pbacot said:
                  what is it?
                  Some sort of robot loosely based on this https://www.artstation.com/artwork/egDZX
                  • andybotA Offline
                    andybot
                    Do we have a subforum yet!? πŸ˜„ I want to discuss pros and cons of obj vs. dae format import. Nice intro video you linked Solo, glad to see they are finally taking seriously the UI compatibility with other software
                    • PixeroP Offline
                      Pixero
                      I just bought Chip Walters Blender video course and so far I'm enjoying it.
                      Much info in a short time so I'm sure I have to go back to remember everything.
                      Recommended.
                      Right now there is a reduced price also.
                      • pbacotP Offline
                        @box said:
                        Something to keep in mind, all software, just like any analog tool, is only as good as how well you learn how to use it. The correct hammer and chisel in untrained hands will reveal a driveway from a block of marble instead of a David.
                        Some of us just need a driveway ( I could use a new one, concrete not marble). And a forum is helpful for learning how. Not much help in getting a David though (I'd need a TON more to get there myself πŸ˜› )
                        • chippwaltersC Offline
                          chippwalters
                          Hey all,
                          As many of you may know, I have a course that takes you from modeling in SketchUp to rendering and animating using EEVEE (Blender's realtime photorealistic renderer) in Blender.
                          It's at https://gum.co/EEVEE
                          Also, here's one of the lessons from the course which may get some of you started. It's on IMPORTING from SketchUp to Blender while keeping the proper scale units.
                          Currently working with Cross-Reality technologies
                            Don't know if it's indispensable...because collada format seems working...
                            (i see that Premium SKetchucation members has a cool reduction) πŸ˜‰
                            • N Offline
                              nlipovac
                              BlendUp is no longer available.
                                Khai
                                the main problem is, DAE is a poorly supported format.
                                no no! hear me out!
                                there's plenty of apps that write DAE.. but damn few that read it.
                                but there's plenty that do read OBJ - it's the almost universal 3D format..
                                  chippwalters
                                  Awhile back, I bought that, then tried to contact the author-- all with no results. It's dead for sure. Even if it did work, it wouldn't work in 2.8 as they now use Collections instead of Layers.
                                  • ntxdaveN Offline
                                    ntxdave
                                    So what is the best way to move my models to Blender 2.8?
                                    I tried .dae and only parts showed up. I also tried fbx but got a message in Blener 2.8 that it did not support fbx.
                                      chippwalters
                                      See my YouTube video above. It walks you through all the settings.
                                        rv1974
                                        @chipp, are they planning to add skp to supported import formats?
                                        • andybotA Offline
                                          andybot
                                          I've been consistently using .obj export for years with good results. I find duplicate faces and lots of other problems with .dae
                                          You can use AutoDesk's FBX converter to convert to a different FBX format that will import correctly. I forget the details as I use it infrequently, but it is possible.
                                          • soloS Offline
                                            We are still waiting for Rich O'Brien to create the subforum, I do not have admin rights to do it.
                                            • 2 / 3
