    Blender forum in sketchucation
    Scheduled Pinned Locked Moved Ideas Box & Board Issues
    48 Posts 21 Posters 39.7k Views 21 Watching
    • chippwaltersC
      chippwalters
      @pilou said:
      Don't know if it's indispensable...because collada format seems working...
      (i see that Premium SKetchucation members has a cool
      Awhile back, I bought that, then tried to contact the author-- all with no results. It's dead for sure. Even if it did work, it wouldn't work in 2.8 as they now use Collections instead of Layers.
      Currently working with Cross-Reality technologies
      • ntxdaveN
        ntxdave
        So what is the best way to move my models to Blender 2.8?
        I tried .dae and only parts showed up. I also tried fbx but got a message in Blener 2.8 that it did not support fbx.
        Press F1...thank me later
        • chippwaltersC
          chippwalters
          See my YouTube video above. It walks you through all the settings.
            rv1974
            @chipp, are they planning to add skp to supported import formats?
            • andybotA
              andybot
              I've been consistently using .obj export for years with good results. I find duplicate faces and lots of other problems with .dae
              You can use AutoDesk's FBX converter to convert to a different FBX format that will import correctly. I forget the details as I use it infrequently, but it is possible.
              • soloS
                @andybot said:
                Do we have a subforum yet!? πŸ˜„ I want to discuss pros and cons of obj vs. dae format import. Nice intro video you linked Solo, glad to see they are finally taking seriously the UI compatibility with other software
                We are still waiting for Rich O'Brien to create the subforum, I do not have admin rights to do it.
                • andybotA
                  andybot
                  Sounds like some more changes coming to Sketchucation than just an additional subforum πŸ˜„
                  404 Not Found
                  (sketchucation.com)
                  @rich o brien said:
                  OK, we'll get you guys a Blender forum for SketchUp users up and running.
                  We are doing some server upgrades at the moment as we need to move to a newer php version. So give us a day or 2 to get something set up.
                  • F
                    fossa
                    Looking forward to the new Blender sub-forum. The 2.8 UI overhaul is unbelievable. Kudos all around for the blender devs that worked on that. Can't wait for more Blender topics....
                    In response to some threads above about DAE vs OBJ. I've been having good luck with DAE imports from SU. It places all objects in an "empty" and scales the empty to the correct units. Haven't had any problems with duplicate faces.
                    Now I'm just trying to figure out how to deal with "empty" object types in Blender. πŸ˜„
                    • pbacotP
                      I've also used the Blender skp importer add-on, but it only works up to 2.79 and then you can open in 2.8.
                      • K
                        Khai
                        Thinking, while we're waiting, could we make clearly labeled threads (think "blenducation : having issues importing....") to go on with, with the labels making it easy to round em up and move them when the forums active?
                        • chippwaltersC
                          chippwalters
                          Haven't heard anything about that. I sorta doubt it. Of course someone could always write a plugin, but going from SU to Blender isn't that hard using .OBJ (IMO).
                          • chippwaltersC
                            chippwalters
                            I guess this never happened. 😞
                            • 3 / 3
