    Slicer v5.11 Not slicing on Mac
    13 Posts 5 Posters 4.4k Views 5 Watching
      It is downloadable as v5.14 in the SCF PluginStore.
      Where did you get your seemingly older version from ?
      Note how it explains in the 'More Info' page [first in its thread] that you must download/install the special ttf font file on a MAC, otherwise it will fail to work properly [PCs are more forgiving].
      It works on MAC & PC - the ttf font is recommended for both OSs, but it is mandatory for the MAC.
      This might be one of your issues...
      It only slices 'solid' objects [e.g. a grouped box].
      What does Entity Info report when it's selected?
      What happens when you try to use Slicer?
      Any error message-boxes?
      If the Ruby Console is open what do you see in it?
      How big is this object?
      There are many questions...
      Please provide us with some more clues...
      • H
        herr_dk
        Hello TIG,
        first: a great plugin, indeed!
        despite that, i have a similar problem,
          @herr_dk said:
          Hello TIG,
          Firstly... can you answer all of the question raised in the post immediately before yours...
          Saying you have a problem is not what you tell the doctor... you need to give us some help to help you...
          My preceding post listed several possible MAC issues.
          A main one is MAC users failing to install the txt.ttf from the download-able zip file - which then breaks the toolset - unlike a PC which skips over the potential issue and uses the last used/available font ??
          If you have none of those problems, then explain clearly what your problem is...
          Use the Ruby Console to see errors, and then report them etc...
          • H
            herr_dk
            @tig said:
            @herr_dk said:
            Hello TIG,
            i´m sorry, i accidently released the question before it was finished...
            in the meantime, i could answer most questions myself, but one remains:
            if i have a cube (40x40x40cm) and want to slice it evenly into 10 pieces, 4cm thick,
            without any space in between, i always get 11 pieces, first and last overlapping by half the thickness, of course because the spacing starts in the middle, i can´t figure out how to fix this. (please also see the attachment)
            one more thing: what hides behind the last 3 buttons in the toolbar?
            (for the failure report also see the attachments)
            thank you again for this great script and your engagement in helping!
              The 'fixed-spacing' slicing currently always starts with a 'centered slice' so you can only have an 'uneven' number of slices - hence 11 ? ***
              BUT: If you enter 0 as a Spacing, and then in the consequent additional dialog you enter the number of Spaces you have control over the number of slices - because they are ALL spaced evenly throughout the object, and then an odd number of Spaces makes an even number of slices... 💭
              To export slices' data you need to have sliced something, and then selected a 'flattened' set...
              ***I'll look at an update to optionally centralize on a 'slice' or a 'gap' - so you can then have 'even' numbers of slices with a fixed-spacing...
              Watch the tool's main thread, for the update...
                A new version of Slicer 5.22 is now available and has an option to Centralize on a Slice or a Gap .
                This new option, taken with the alternative entering 0 as a spacing and then entering the number of spaces, should cover most bases ?
                http://sketchucation.com/plugin/781-tig_slicer
                • C
                  cjc0306
                  The item is a group.
                  • C
                    cjc0306
                    Thanks Tig, adding the Font took care of the problem.
                    • B
                      BAsso695
                      I also have this problem with not slicing on mac. Can someone link me directly to the font download please? I can't seem to find it...
                        You get the required TXT.ttf font-file from the link on the Slicer Document pages in the PluginStore - linking to the main Slicer 'feedback' thread's first post...
                        http://sketchucation.com/forums/viewtopic.php?p=374969#p374969
                        The download is actually this:
                        http://sketchucation.com/forums/download/file.php?id=81087
                        Download it, then UnZip it and install the Font's ttf file...
                        • B
                          BAsso695
                          It worked. Thank you!
