    SketchUp 2019 release
    430 Posts 94 Posters 370.1k Views 94 Watching
    • pbacotP Offline
      Over time, much as I like some software, I've come to realize that if I don't like how it's done (or NOT done), I can just go start my own software business. So there.
      • N Offline
        numerobis
        @glenn at home said:
        Last update on Twitter was from June. I just sent a message to them to see if they are still actively working on this.
        Thanks! I just found it 😉
        • andybotA Offline
          andybot
          Amazing. Worst fears confirmed. 😞
            What's that?
            They've fixed a mess of bugs and some issues that people have been complaining about, they added some new features that people wanted like dashed lines in SketchUp, they've made SketchUp Pro less expensive to get started in with their subscription option which also gives the user access to SketchUp Shop, an unlimited Trimble Connect storage account and other features. And for those who aren't interested in having access to SketchUp Shop and the other add-ons, they can continue with their Classic license as they've always done.
            • kenK Offline
              ken
              I have 2018, with the maintenance license still in effect. I have downloaded 2019. It requests a license and an authorization code. Before I would copy the license from the previous version. This time 2019 says it is not a valid license.
              So do I to buy another 2019 license or am I doing something wrong. I just want the classic, not interested in the $600 program.
              So help if you can.
              Thank you in advance
              Ken
              So DaveR do you remember when the bowlers came into style?
              • pbacotP Offline
                Ken,
                Maybe this?
                Tip: If you’re active in the upgrade, maintenance, and support plan, you receive an email with new license information after a new version of SketchUp Pro is released. Download and install the new version of SketchUp Pro, authorize the license, and begin using the new version of SketchUp. After you authorize the new version, your old SketchUp license expires after 60 days.
                (help.sketchup.com)
                • PixeroP Offline
                  Pixero
                  I think it’s what I expected.
                  Nothing about speed and stability for high poly models and faster import.
                  Nothing very impressive but at least two things are good.
                  DWG Import
                  In SketchUp you now have the ability to Import and Export Materials improving interoperability for CAD and BIM workflows
                  This one if it works as I hope will be of big use to me since much is modeled in Revit at work.
                  Getting materials in to Sketchup will save me time.
                  Fixed an issue where SketchUp would take focus during start up preventing work in other apps.
                  A good and wanted fix.
                  Now I can do something productive instead of looking at Sketchup loading.
                  • utilerU Offline
                    utiler
                    SketchUp 2019 Release:
                    https://blog.sketchup.com/article/a-whole-new-way-to-sketchup
                    Just Curious...
                    • pbacotP Offline
                      The above referenced blog says they've made SketchUp "faster".
                      • ntxdaveN Offline
                        ntxdave
                        @pbacot said:
                        Ken,
                        Maybe this?
                        (help.sketchup.com)
                        I have the active upgrade, maintenance and support plan. I have had it for several years When I install the new version each year, the old version is still there and still works. It does not expire after the 60 days (or at least it never has for me).
                        Looks like I can continue on the same path with the Classic plan.
                        Press F1...thank me later
                        • F Offline
                          function
                          dashed lines and some other stuff 🎉 🎉 🎉
                          • ntxdaveN Offline
                            ntxdave
                            Do not have it yet, but it appears that the dashed lines works in a way that all the sages tell us not to do. You can only use dashed lines in conjunction with a layer (according to my understanding). Which means that the layer where you are going to use dashed lines must be the "active" layer. All of the advice I have seen from the sages say that you should ALWAYS draw on layer0 and then assign the object/group/component to a layer after completing the action. Again, according to what I am seeing on the SketchUp forum, you would have to draw you objects/groups/components on a layer other than layer0 in order to use dashed lines.
                            Hope someone can show me that I am wrong!!
                            • ntxdaveN Offline
                              ntxdave
                              Kind of my first impression also until I others corrected my understanding of some things. The Classic version and it's licensing continues the environment we have been used to. 👍
                                alpro
                                Can I change my vote in the poll?? I've been using Sketchup since version 6 and had really high hopes for 2019 especially with the release delay. Doesn't seem like anything to get excited over though I will hold off on judging it till I have used it for a few weeks. But the biggest disappointment is going subscription. And before people start replying with "the classic version license" just read Mark's statements again, "for the time being", so it won't be long before Sketchup is following the Autodesk empire's footprints. I would of rather had them double or triple the yearly maintenance fee. So where to go from here? Guess now would be a good time for some developers to come up with a Blender addon that at least kinda mimicked SU especially with the 2.8 release. I would buy it.
                                  There's never been a case where you would enter your license for the previous version in the licensing fields for a new one. Nothing has changed regarding that. They have already said they will be sending e-mails in the next day or so out to those who have current maintenance agreements providing new serial numbers and keys. If you can't wait that long, you can go to the website and get the license info directly
                                  No. You don't need to buy another license. You can continue with what they now call the Classic license. You'll get SketchUp 2019 with a perpetual license.
                                  So help if you can.
                                  I tried. I hope that helps to clarify.
                                  I ain't quite that old. 😄 I do remember the time ThomThom was trying to get them to have a comeback, though.
                                  • jujuJ Offline
                                    juju
                                    yeah, I saw that too, I would love to know what/how things were made faster and if it has been quantified / qualified
                                      rogalxxx
                                      They made shadows faster. It seems like it does not recalculate shadows when rotating view. No ora a short delay waiting for them to reappear.
                                      I have my license valid till the end of 2020 but I did not recieve updated license. Keep waiting or should I do something?
                                      • jujuJ Offline
                                        juju
                                        go to licence manager section on their website, enter licence details with your e-mail, a new serial will be sent
                                        • sketch3d.deS Offline
                                          sketch3d.de
                                          @juju said:
                                          go to licence manager section on their website...
                                          besides having bought by a reseller who will then deliver the license data of rev. 2019 to the registered email address in a few hours/days.
                                            Khai
                                            Hmm new license areas aside, not to impressed with only minor adjustments to the program and minor feature adds.
                                            Have to see how it goes...
                                            • 11
                                            • 12
                                            • 13
                                            • 21
                                            • 22
                                            • 11 / 22
