    SketchUp 2019 release
    430 Posts 94 Posters 381.1k Views 94 Watching
    • andybotA
      andybot
      Yep, I only installed 2018 on one of my computers for this very reason. I've only used 2018 in the past year to open 2018 version SU files, but do my main modeling on a different computer, usually in 2016. I'm planning to trial 2019 on that same computer and even if I do end up purchasing for some reason, I likely won't touch my other installs.
      @juju said:
      You'll find that, once you've been issued a license for an updated (newer) version, and you have used it to activate the updated (newer) version, the serial for older versions won't work anymore after (I think) a month. Existing activated installations will keep on working as normal, but you won't be able to do a fresh install and activate any of the older versions. I suppose they do it that way to curb unauthorized installations.
      • G
        Glenn at home
        @juju said:
        ... but you won't be able to do a fresh install and activate any of the older versions. I suppose they do it that way to curb unauthorized installations.
        This is a shame. This is one of the benefits of having an AutoDesk subscription. You can download and install older versions of the software if you have some sort of need like to run an older version say for a 3rd party add-on or plugin that is not updated yet. Oh well, maybe one day.
        • sketch3d.deS
          sketch3d.de
          @glenn at home said:
          ... You can download and install older versions of the software if you have some sort of need like to run an older version say for a 3rd party add-on or plugin that is not updated yet.
          • SketchUp Forum: RfE: make License Data eligible for previous Version(s) (12/2015)
          • H
            hedvachen
            What about SketchUp 2019??
            • sketch3d.deS
              sketch3d.de
              • jujuJ
                juju
                @sketch3d.de said:
                ROTFLMAO
                unfortunately yes
                • jujuJ
                  juju
                  Who would have thought?! This thread hit 100,000 views in the last 24h!
                  • F
                    function
                    I hope sketchup pro moves to web platform and we can finally get rid of those pesky desktop versions once and for all.
                    • sketch3d.deS
                      sketch3d.de
                      @function said:
                      ... we can finally get rid of those pesky desktop versions once and for all.
                      pretty mischief.
                      • pbacotP
                        I guess there are others interested. I've checked this thread 99,000 times just for the banter.
                        • F
                          faust07
                          @ function: No way! That would be the ultimate end.
                          • soloS
                            That would be my last day with SU
                            • G
                              Garry K
                              If you experienced a situation where you needed to be operated on - would you want a web app to say work on pumping your blood through your body to keep you alive? Then the internet goes down - OOPS.
                              Mission critical software should remain offline. As should CNC routers etc. This extends to large models where web apps will bring the entire system down to its knees !!!
                              • sfto1S
                                sfto1
                                I'm hoping "function" was joking, but if not YIKES!
                                If SU were to be Web only, Solo would need to change his name because there would be a heck of a lot of SU users joining him out the door.
                                • sketch3d.deS
                                  sketch3d.de
                                  afaik a guarantee for a periodic release of new main versions is not promised.
                                    Jeff89
                                    No "function" is very serious about this.
                                    But we are getting off topic here. Any news about SU 2019 yet?
                                      rv1974
                                      v2019 will feature 3 most anticipated features: a new logo, ability to choose color for your section planes and maybe some new politically correct human in default template
                                      You'll see sadly I'm very close to reality
                                        @rv1974 said:
                                        ...ability to choose color for your section planes
                                        That already exists.
                                        People will whine and complain no matter how many new features they add.
                                        • sketch3d.deS
                                          sketch3d.de
                                          ranting is the new dedication 😆
                                            rv1974
                                            Are you sure you can assign individual color to a concrete inactive section plane?
                                            Exactlty.. Even section colorization won't stop this whining
                                            • 21
                                            • 22
                                            • 8 / 22
