    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 899.0k Views 40 Watching
    • fredo6F
      Is "Pressure gauge - 21-Sep-2018 09-57-10 - Gauge 3/4" the name of your file? If so, then 3/4 is probably creating an issue, as '/' is used as a folder separator.
      • C
        cgalaon
        @migmat said:
        PROBLEM GENERATING VIDEO with ffmpg.exe INSKETCHUP 2013 (Works Animator for this versión?)
        1- Animator Beta Works OK
        2- Install ffmpeg.exe in LibFredo6 (disapear the red text to Find the ffmpeg.exe)
        3- Make a simple animation that Works fine in preview
        4- Try to generate a video with defaut parameters. Push the button "Test Image" and also work
        5- Push the button "Generate Video" and NOTHING HAPPENDS. Sketchup continues inside the animator plugin. I can exit and star again the plugin,but nothing happends.
        I instal the two versión of ffmpeg.exe, the last and the 3.2 (more stable).
        Thanks in advance
        PROBLEM SOLVED!!!!
        M8, I had the same problem until I figured it out. When you name your "Film" in Animator, DON'T USE symbols like the followings (the ones that Windows files creator wouldn't allow it either): \ / : * ? " <> and |. Change the name using other symbols (all the rest, the allowed ones) and TACHA!!
        Regards to all readers and SU/Animator users. Chip
        • C
          CiscoNA
          I can not find the button of the Animator plugin in Sketchup 2018. Is it visible in my extension manager but I can not open the plugin. What do i need to do?
          • fredo6F
            Did you install the companion library LibFredo6?
              Auressalmi
              Hi!
              I did a quick animation and tried to make it mp4-video, but it fails every time?
              Animation runs fine on Sketchup and video render does open and work, but when its done
              MP4- button is red and says "error in the video file generation".
              I have tried different setting and FFmpeg.
              I have Windows 7, Animator 2.3c and sketchup 2017
              Greetings from Finland - Juho
              • fredo6F
                Juho,
                I would need that you post or PM the model to me to investigate.
                  Auressalmi
                  Thanks for quick answer!
                  Here is the file, do you need something else?
                  Edit Tested on different model, same error message.
                  -Juho
                  Hammastanko_Sähköohjaustehostin.skp
                  • fredo6F
                    Strange. I can generate the movie in Natural mode (i.e. without rendering).
                    Are you trying with a rendering software ?
                    Film 1.mov
                      Auressalmi
                      I have followed instruction from the page 1. and i'm using all the same software's ect.
                      I don't fully understand what you mean with rendering software, but i'm using Animator only, nothing else.
                      I have tried different things here and there with no success.
                      -Juho
                      • fredo6F
                        I fixed the issue with the generation of video via recent versions of FFmpeg in LibFredo6 - v8.7f - 10 Jan 19.
                        This is compatible with older versions of FFmpeg too.
                        So if you have problem with the video generation (red button MP4), then make sure you updated LibFredo6.
                        • V
                          VeskoArch
                          Hi Fredo !
                          First wonderful work on all the plugins and especially on this one!
                          I was bugging myself with some issues regarding the plugin but overall I've managed to understand the principle of it. However there is still something that bugs me and I'm not sure how to fix it:
                          I have made a sequence - then I've generated a video and everything is good. I've closed sketchup and reopened it but all the objects (groups) that had an APPARITION function disappeared and wont show up when the sequence starts. I've checked the "Outliner" and those object were not listed there as well. If I purge all the sequences on the animator everything comes back as it is - but I have to redo the whole thing again.
                          I've tried all the things i can think of but no luck.
                          Has anyone else experience such a thing.
                          Sincerely,
                          Vesko Mutafchiev
                          PS: Is there any option on the Kinematic constraint that connects several objects and move them one by one and a different span of time - for example plates connecting one after the other. I've done this with regular movement tool, I just want to see if I can save some time.
                          • fredo6F
                            I think the best would be that you post or PM the model so that I can investigate. If you can do it again, please open the console to check if there are errors displayed.
                            This is a function which is on my to-do list (Construction / Deconstruction), but not for now.
                              Macho3001
                              Hi Fredo..
                              Could you kindly share with us your personal email address/ drop in a mail to us at ans.3dads@gmail.com regarding some assignment that we think you may be interested in. I apologize to you, having written this message on the forum but regretfully I could not locate any other way to contact you or get my message across to you.
                              Do please revert, many thanks.
                              Ar. Nitin Sharma
                              3DA
                              Email: ans.3dads@gmail.com
                              3DADS
                              'Leadership, by Design'
                              3rd Dimension, Architecture Design Studio
                              • fredo6F
                                You can send me a Private message on the forum (use PM button) and tell me what it is about.
                                This would avoid you showing your email address, which is not advised on a public forum (I suggess you edit your previous post and remove it).
                                  ACWN
                                  Still no option for moving a camera along a path? Just checking to make sure I didnt miss something.
                                  • fredo6F
                                    Not yet but planned....
                                      ACWN
                                      Dangit. A'righty, thank you!
                                      • T
                                        TonyAU
                                        Hi Fredo,
                                        Thank you for your efforts with this plug-in, it adds a whole new level of useability to the sketchup platform.. I have used it to create 3 animations now and the results are pretty impressive. I have a question, does the plug-in allow for transfer of the animation parts to other components, or the copying of the component with the animations attached. I have looked thru the forum for the answer and nothing has popped out at me. I am doing animations that require repetitive actions to components and I'm finding myself doing the same animated time after time,ie, move up 150mm, move right 150mm, move down 75mm, rotate 90. if I could just copy the component with the animation attached I could just stagger in the time line and that would save me huge amount of time. Once again thanks for your efforts with this extension..
                                        • fredo6F
                                          In principle, you have the Clone Sequence button in the Sequence Editor for Movements
                                          But this works for sequences individually.
                                          Cloning a list of sequences for another object is something Animator should provide, but I have still to find a way to do this with the UI.
                                          • T
                                            TonyAU
                                            Awesome..
                                            Thanks for the quick response, I'll have a play with it and see how it works..
                                            Cheers.
                                            • 5 / 7
