    Tutorial: Model in SketchUp, Realtime Render in Blender
    18 Posts 7 Posters 5.3k Views 7 Watching
    • chippwaltersC
      chippwalters
      @rv1974 said:
      What happens to Evee when it hits the glass ceiling of video card memory limit?
      Currently my average RAM usage (in architectural exteriors) is about 25-40Gb of RAM. The average video card is only 6-12
      In my video series, I go over how to optimize your video memory by using a custom streamlined shader which uses significantly less memory than the custom advanced shader.
      Furthermore, Blender 2.8 can use both GPU and CPU to render a scene, so if you don't have enough video, you can automatically render in CPU mode, albeit a lot slower.
      Currently working with Cross-Reality technologies
      • majidM
        majid
        More than happy to be involved please and may Gosh bless you!
          rv1974
          My question was about Eevee. From what I understood it's a GPU only engine (not supporting multiple cards rig). So when the memory limit will be reached, will it crash/freeze or give an error pop-up?
          • soloS
            Does EEVEE use multiple GPU's?
            • chippwaltersC
              chippwalters
              Hi majid! Please email me at chippATchipp.com (replace AT with @). Look forward to working with you. πŸ˜„
              • chippwaltersC
                chippwalters
                EEVEE will render with GPU and/or CPU. It uses OpenGL. I believe if you reach the texture memory limit of your GPU it will automatically render on the CPU (slower of course). My tutorial series covers this and I provide a efficient material shader and one that is more advanced as well.
                • majidM
                  majid
                  I am reviving all I know on Blender with new UI, and let me say miles way easier to work with comparing to previous version ...
                  • chippwaltersC
                    chippwalters
                    @rv1974 said:
                    https://devtalk.blender.org/t/is-will-eevee-support-multi-gpu/625
                    [url]https://blender.stackexchange.com/questions/110142/eevee-seem-not-to-benefit-from-multiple-gpus-for-rendering
                    [/url]
                    No multiple GPUs for Eevee. Are they wrong?
                    Wow. Really good catch! I just assumed that because cycles supported multiple gpus then Eevee did also. Thanks for the correction. Here's another link I found on the subject.
                    Just a moment...
                    (blender.stackexchange.com)
                    • chippwaltersC
                      chippwalters
                      Yep, Blender 2.8 is a game changer.
                        rv1974
                        • chippwaltersC
                          chippwalters
                          Absolutely. In fact, a GPU (or two) is highly recommended.
                          It can even use the new RTX series from Nvidia.
                          EDIT: Correction: While Cycles benefits from multiple GPUs, it appears EEVEE does not. Furthermore, it's not clear whether or not EEVEE takes advantage of the new RTX cards yet (Cyles does).
                          • G
                            Glenn at home
                            Yes it is. It's like a breath of fresh air πŸ˜‰
                              When will Blender 2.8 be released? All I have found out so far is that release is delayed.
                              • Bryan KB
                                Yes, I am interested in testing as well.
                                • soloS
                                  Blender Builds - blender.org
                                  Continuous build delivery with the latest features and fixes. Use at your own risk!
                                  Blender Builds - blender.org (builder.blender.org)
                                  • chippwaltersC
                                    chippwalters
                                    I'm hearing sometime in Q2-2019..BUT there many people are now using it since it's been in BETA. Beta typically means all the features are locked down but there may still be bugs. I've been using it for a few months now and it's pretty darn robust. As Pete says, you can download it now.
                                    Regarding DL'ing of Blender 2.8. You should consider updating your download every couple of weeks. I know this sounds silly, but it's pretty amazing how robust the daily builds are. I've yet to have to 'revert' to an older version, and I've been doing this for both 2.79 and 2.8 for quite some time now.
