    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      Is it for all popup dialog boxes ?
      • pbacotP Offline
        I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
        • fredo6F Offline
          Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
          Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
          Another user has signaled me an anomaly with popup messages.
          • pbacotP Offline
            I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
            • pbacotP Offline
              hmm... check for updates doesn't work either.
              • fredo6F Offline
                Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
                Since you have FredoTools installed, could you check if
                • the Quick Launcher works
                • if Solid Volume displays a dialog box
                • pbacotP Offline
                  Ok updating several Fredo6 plugins allows me to open without prompts and FredoTools and Fredo Collection seem to be in place as before!
                  Still when I choose "View Trace Log Files..." sometimes a window flashes on and off but nothing else happens.
                  FredoTools Launcher doesn't do anything.
                  Solid Volume flashes a window briefly.
                  • fredo6F Offline
                    @oxer, @pbacot,
                    Can you tell me which version of Safari you run on your Mac.
                    It seems that Safari does not like a change I made in my code related to dialog boxes.
                    • OxerO Offline
                      Oxer
                      Yes, have you probe anther options like Defaults Options..., Translate Language.., etc?
                      To me, with all these options the popup window appear and disappear immediately.
                      macOS High Sierra 10.13.6 & SU2017
                      • pbacotP Offline
                        I have Safari 12.0.2 (13606.3.4.1.4)
                        • OxerO Offline
                          Oxer
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                            LibFredo6 8.7d fixes a major bug preventing dialog boxes to display on MAC
                            • Z Offline
                              ztoundas
                              [quote="fredo6"]NEW RELEASE: LibFredo6 v8.7d - 20 Dec 18
                              ...Just installed an on windows, the dialog box for Convexify refused to show. :[
                              • Z Offline
                                ztoundas
                                Can we have access to 8.7a again? I've searched absolutely every where I can't find it, 8.7d broke Windows dialog boxes. Thanks!
                                • pbacotP Offline
                                  Thanks Fredo for the help! (I just haven't got back to checking this last one.)
                                    alirezakharazmi
                                    Fredo,
                                    I can not install Cruviloft! This is the error:
                                    Curviloft: This plugin requires LibFredo6 version greater than 68.
                                    Current version is 75.
                                    I couldn't find a higher version of LibFredo. What should I do?
                                    Thank you so much.
                                    Alireza
                                    • fredo6F Offline
                                      @alirezakharazmi said:
                                      Fredo,
                                      I think the message is that you require LibFredo6 v8.6, and you have an old version (v7.5).
                                      So just upgrade LibFredo6.
                                      • fredo6F Offline
                                        I fixed it with LibFredo6 v8.7e.
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v8.7e - 01 Jan 19
                                          LibFredo6 8.7e fixes a major bug preventing some dialog boxes to display
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v8.7f - 10 Jan 19
                                            LibFredo6 8.7f fixes a major bug preventing Animator to generate videos with recent versions of FFmpeg
                                            • 108
                                            • 109
                                            • 3 / 109
