    [Plugin] Shell
    93 Posts 33 Posters 67.0k Views 34 Watching
      stch
      Thanks. I'll give it a go. And thanks for the other plugins of yours I'm using. Solid Inspector is a life saver, as I'm sure you know.
      • Bob JamesB Offline
        Bob James
        I downloaded version 0.3.0 last night and found the following differences:
        Usage
        Select groups and/or components.
        Activate Shell from the Tools menu. %(#FF0000)[**It's in plugins under thomthom plugins**]
        Enter a thickness in the VCB or pick a distance in the model.
        Double-click to commit. (You can also use Return to commit as long as the thickness has not changed.) %(#FF0000)[**It defaults to the last value you used. (if you've not used it before it defaults to 1"). If you change it to something else you have to hit return before double-clicking.**]
          Dentice
          Hi there,
          when selecting the group / component and then selecting the shell from the list of plugins, I do get the temporary shell. I can also type in the dimension but as soon as I double click or press enter, nothing happens. I do not know how I can terminate the command. please can you help?? thanks a lot.
          • mitcorbM Offline
            mitcorb
            I think the Spacebar works in most cases. See if that is correct.
            • tt_suT Offline
              tt_su
              @dentice said:
              Hi there,
              Double-click or hit Return. It's described in the first post of this thread.
              • Randy HutniakR Offline
                Randy Hutniak
                I've used the plugin for a few years very successfully but in SU17 I can't seem to get it to commit by using the Enter key and a set distance, in this case 1".
                I even drew a 1" line to try with the mouse and curser but that didn't work either. dbl click, triple, didn't matter. It did work with larger offsets, 4"+.
                any thoughts?
                  If you open the Ruby Console, is there any errors appearing?
                    Randy Hutniak
                    Hi Tomas
                    Today its working fine...the Ruby Console says that Points are not planar.
                    I've been having a few problems with SU17. 'Out of Memory' freeze and Move/Ctrl place crashes. maybe be it has something to do with those things. see my post: http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=66314%26amp;e=0
                    thanx for the quick reply!
                      Do you have a sample model that reproduce this?
                      • em3diE Offline
                        em3di
                        Hey thomthom, Thank's for this great plugin! But I instaled it and it doesn't show up on tools menu!
                        https://cdn.steemitimages.com/DQmYNmtuA2NTauttxNz8Qu9MVq8oqdjXQcoQ165pZQYpHeR/1.png
                        but when i go to "Extensions -> SketchUcation -> SketchUcation Plugins Manager" the "tt_shell" is there!
                        https://cdn.steemitimages.com/DQmQAggY21so6ryCL1BT3TqQVKjQkJJA4UD9TbBor6WXgAm/2.png
                        How can I acesse the Shell Plugin?
                          What version of SketchUp are you using? Your profile indicates 2016 Make but your screen shot shows Solid Tools and Eneroth Solid Tools which aren't available for Make.
                          Do you have the current version of TTLib installed?
                          • em3diE Offline
                            em3di
                            Hey Dave, thank's for the feedback!
                            Nop! And that was it! I installed, and work's fine now!
                            Thank You Dave!
                            • 5 / 5
