    [Plugin] Shell
    93 Posts 33 Posters 65.1k Views 34 Watching
      hm.. then it will take some more digging. I'll see if I can work out what it is.
      Btw, could you fill out your profile information to include your OS and SketchUp version?
        Thomthom, I just installed this on my Mac in the correct Plugins folder and it loads without a problem.
          I think it could be related to corrupted setting data. Not sure though...
            archheni
            Hi, deleting the Sketchup preferences in the library seems to have solved the issue. Works fine again.
              Thanks for the info. I'm still trying to track down where it might have failed.
                stch
                Hi - brilliant plugin - seems to be working for simpler shapes, but i can't get it to work for the attached file. I put in the shell thickness, then double click (or press return) and the shell just doesn't 'set' - when I click elsewhere the shell has disappeared. Help massively appreciated as I'm working to a deadline. Any ideas?shape that i cannot shell.skp
                  Yea, this plugin is in very early stages - an experiment. I've not had time to work on it. I'd recommend you try Fredo's JointPushPull instead: http://sketchucation.com/forums/viewtopic.php?t=6708
                    stch
                    Thanks. I'll give it a go. And thanks for the other plugins of yours I'm using. Solid Inspector is a life saver, as I'm sure you know.
                    • Bob JamesB Offline
                      Bob James
                      I downloaded version 0.3.0 last night and found the following differences:
                      Usage
                      Select groups and/or components.
                      Activate Shell from the Tools menu. %(#FF0000)[**It's in plugins under thomthom plugins**]
                      Enter a thickness in the VCB or pick a distance in the model.
                      Double-click to commit. (You can also use Return to commit as long as the thickness has not changed.) %(#FF0000)[**It defaults to the last value you used. (if you've not used it before it defaults to 1"). If you change it to something else you have to hit return before double-clicking.**]
                        Dentice
                        Hi there,
                        when selecting the group / component and then selecting the shell from the list of plugins, I do get the temporary shell. I can also type in the dimension but as soon as I double click or press enter, nothing happens. I do not know how I can terminate the command. please can you help?? thanks a lot.
                        • mitcorbM Offline
                          mitcorb
                          I think the Spacebar works in most cases. See if that is correct.
                          • tt_suT Offline
                            tt_su
                            @dentice said:
                            Hi there,
                            Double-click or hit Return. It's described in the first post of this thread.
                            • Randy HutniakR Offline
                              Randy Hutniak
                              I've used the plugin for a few years very successfully but in SU17 I can't seem to get it to commit by using the Enter key and a set distance, in this case 1".
                              I even drew a 1" line to try with the mouse and curser but that didn't work either. dbl click, triple, didn't matter. It did work with larger offsets, 4"+.
                              any thoughts?
                                If you open the Ruby Console, is there any errors appearing?
                                  Randy Hutniak
                                  Hi Tomas
                                  Today its working fine...the Ruby Console says that Points are not planar.
                                  I've been having a few problems with SU17. 'Out of Memory' freeze and Move/Ctrl place crashes. maybe be it has something to do with those things. see my post: http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=66314%26amp;e=0
                                  thanx for the quick reply!
                                    Do you have a sample model that reproduce this?
                                    • em3diE Offline
                                      em3di
                                      Hey thomthom, Thank's for this great plugin! But I instaled it and it doesn't show up on tools menu!
                                      https://cdn.steemitimages.com/DQmYNmtuA2NTauttxNz8Qu9MVq8oqdjXQcoQ165pZQYpHeR/1.png
                                      but when i go to "Extensions -> SketchUcation -> SketchUcation Plugins Manager" the "tt_shell" is there!
                                      https://cdn.steemitimages.com/DQmQAggY21so6ryCL1BT3TqQVKjQkJJA4UD9TbBor6WXgAm/2.png
                                      How can I acesse the Shell Plugin?
                                        What version of SketchUp are you using? Your profile indicates 2016 Make but your screen shot shows Solid Tools and Eneroth Solid Tools which aren't available for Make.
                                        Do you have the current version of TTLib installed?
                                        • em3diE Offline
                                          em3di
                                          Hey Dave, thank's for the feedback!
                                          Nop! And that was it! I installed, and work's fine now!
                                          Thank You Dave!
                                          • 5 / 5
