    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      This is an example of metal roof and wall cladding (utilizing the Material Manager in both the Truss and Wall plugins):
      http://design.medeek.com/resources/images/wall_su259_800.jpg
      http://design.medeek.com/resources/images/wall_su260_800.jpg
      http://design.medeek.com/resources/images/wall_su261_800.jpg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      The model was created with all three plugins. The only manual edit was moving the person outside of the structure and re-positioning of two anchor bolts that landed in the middle of the garage door. The entire model except for the foundation (slab-on-grade) is fully parametric, moving openings or changing the roof pitch is a couple clicks of the mouse. Model creation time was about 10 minutes.
      As far as speed of modeling goes I think this is starting to close in on other design packages like Revit and Chief Architect. Once I add the estimating and then the engineering it will even exceed their capabilities.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Tutorial 6 - Custom Material Library:
        design.medeek.com
        • medeekM
          medeek
          A whole different area I really haven't explored yet is fixtures (and furniture).
          Technically this is a very broad topic and could really use an entirely different plugin to do it justice.
          However, I will add in a toolbar called "Fixtures" which will allow the user to select from a matrix of options (Bath, Bedroom, Kitchen etc...) and then to select from some standard layouts.
          For bathrooms the layout below (Layout A) is very typical in the US for many mid-range homes:
          http://design.medeek.com/resources/images/wall_su262_800.jpg
          An 8'x5' bathroom with a sink, toilet and tub.
          The idea being that the user can quickly generate any standard layout from a library of components. I will probably include a few default (low poly) components however it will be up to the user to drop their own preferred components into the plugin sub-folders if they want to be able to select from them in the drop down menus.
          I don't want to include a large number of high poly count components in the plugin because is will make the .rbz file too large and cumbersome. Besides there are vast libraries of manufacturer components available in the 3D warehouse.
          The cool thing about integrating this within the plugin suite is that it will then be possible to obtain counts for estimating purposes on many of these fixtures and assign prices etc...
          The Edit menu will allow the user to swap out any of the components and also custom position them as required.
          For this particular bathroom layout (and most layouts in general) there is a left and right hand orientation. The user will be able to select the orientation in the draw and/or edit menu. The first mouse click will establish the insertion point the second click will establish the rotation. Clicking the shift key will toggle orientation (left or right).
          Some fixtures such as the bath tub shown come in a left and right version. It will be up to the user to upload both versions for use however I will include an additional parameter (rotation: 0 or 180) so that orientation can be controlled.
          http://design.medeek.com/resources/images/wall_su263_800.jpg
          With this new module I will start with bathrooms first and then branch into other rooms as the need arises.
          design.medeek.com
          • jujuJ
            juju
            I think the fixtures should rather be a separate extension.
            • medeekM
              medeek
              Version 0.9.9e - 11.08.2018
              • Removed all advertising banners from the global settings.
              • Fixed a bug (metric) for window and door grilles in the global settings.
              Note that this is a critical fix for Windows 10 and Mac users. The intermittent response times of the google ads was causing issues for the HTML menu pages of the global settings so I decided to completely remove all advertisements.
              design.medeek.com
              • medeekM
                medeek
                Version 0.9.9d - 11.07.2018
                • Added a material parameter for ext. wainscot ledges.
                • Added toolbar icons for "Fixtures" module.
                http://design.medeek.com/resources/images/wall_su265_800.jpg
                http://design.medeek.com/resources/images/wall_su264_800.jpg
                This extra parameter was added per customer request.
                This will allow the designer to setup a texture/material for rowlock brick.
                http://design.medeek.com/resources/images/wall_su266_800.jpg
                design.medeek.com
                • medeekM
                  medeek
                  I had a request yesterday for multiple rows of blocking/nogging. A typical example might be a 12 ft. wall with a row of blocking every 4 ft.:
                  http://design.medeek.com/resources/images/wall_su267_800.jpg
                  My idea on this is to add two additional parameters to the blocking module/UI:
                  Number of Rows: 1,2,3 or 4
                  Row Spacing: inches or mm
                  The vertical parameter that already exists will position the first row vertically in the wall and then the next rows of blocking will be arrayed upward by the row spacing and number of rows.
                  For now I am omitting blocking over and under opening but that will probably need to change with multiple rows of blocking.
                  Multiple rows of blocks is going to get a bit heavy in the model but you have to give people what they want.
                  Thoughts?
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 0.9.9f - 11.08.2018
                    • Added two additional parameters for mid-span blocking to enable multiple rows of blocking in a wall panel.
                    • Added two parameters (number of rows, row spacing) for blocking into the Walls tab of the global settings.
                    http://design.medeek.com/resources/images/wall_su268_800.jpg
                    http://design.medeek.com/resources/images/wall_su269_800.jpg
                    There may be an issue with previously created wall presets due to the addition of more parameters to the wall panel dictionary module. The number of parameters now stored for a preset is 97.
                    I am also wondering if anyone would be interested in having me publish the attribute library for the wall panels. This would allow other developers to potentially access and modify the Medeek wall panels with their own plugins or have their plugins interact with the Wall plugin.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 0.9.9g - 11.09.2018
                      • Added the Australian/New Zealand I-Beam (Universal Beam - UB) as another steel beam option in the beam module. (27 different sizes)
                      http://design.medeek.com/resources/images/wall_su270_800.jpg
                      I also spent some time cleaning up this module a bit today and tightening things up. It's amazing how you are able to condense your code when you spend a few minutes and really work at it.
                      I've also made it much easier to add in new schedules/lists of different beam types and sizes. I still need to add in many more beam sizes for the metric world (or just make it completely open ended so the user can define their own sizes).
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 0.9.9h - 11.10.2018
                        • Added hollow structural section beams (HSS) to the beam module.
                        http://design.medeek.com/resources/images/wall_su271_800.jpg
                        This profile is not used as commonly as the wide flange however in specific situations it has its advantages due to its torsional capabilities.
                        design.medeek.com
                        • medeekM
                          medeek
                          Technical discussion about groups vs. components here:
                          Group Name or Description
                          I’ve been in the habit of setting both the name and description for a group but really only ohe of these parameters is being displayed as the Instance name in the Entity Info tray. So where or how is the description fie…
                          SketchUp Community (forums.sketchup.com)
                          This is related to the way I am handling certain elements such as studs, blocking, insulation and other arrayed building elements.
                          design.medeek.com
                          • medeekM
                            medeek
                            Currently in the plugin I have only implemented the California Corner (as we Americans call it) or Energy Corner for corner treatment however there are number of ways to handle corners.
                            https://design.medeek.com/resources/framing/FRAMING_CORNERS.pdf
                            I have been requested by a potential client to enable the following corner type: "Solid corner with short blocks". For a deeper wall sometimes two rows of blocks are used (2x6 wall) rather than one.
                            I can implement the solid corner however I need some more information:
                            1.) If you use blocking rather than a full stud how do you determine the length of the blocks and the number of blocks in a given wall height? Is there any rule of thumb with this? I just need to come up with a reasonable algorithm.
                            2.) Is the blocking typically the same dimensional lumber as the studs?
                            design.medeek.com
                            • medeekM
                              medeek
                              For wall corners I will be adding in the following additional corner treatments:
                              • 3 Stud Solid
                              • 4 Stud Solid
                              • 3 Stud Block
                              • 4 Stud Block
                              When the user sets the number of studs for the corner on anything other than one, that setting will override the corner treatment for the above corner treatment types. However this is not the case for the California corner (however I may change it in the future if it makes sense to).
                              These algorithm can get a bit complicated due to the number of permutations possible when you start mixing up corner treatments and multi-stud corners for shearwalls.
                              The problem I find with California Corners is that it does not provide very good backing for ext. outside corners when it comes to siding and trim. However it certainly is better for insulation and much easier on the electricians.
                              There does not seem to be any hard and fast rule on the length of blocks used but it seems to average between 12" to 14", so I will set my algorithm to a max. block length of 14" . So for example a 96" wall will have four blocks at 13.714".
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 0.9.9j - 11.13.2018
                                • Added the following corner treatments: 3 Stud Solid, 4 Stud Solid, 3 Stud Block, 4 Stud Block, U-Cal
                                • Enabled a parameter in the General tab of the global settings to toggle the labeling of groups.
                                http://design.medeek.com/resources/images/wall_su275_800.jpg
                                I also addressed some minor issues with the way blocking and insulation interact with the corner treatments. Its seems I have that ironed out now and much less likely to generate geometry that clashes.
                                http://design.medeek.com/resources/images/wall_su277_800.jpg
                                I don't know how commonly the U-shape California Corner (U-Cal) is used (shown above) but I really like the fact that it offers more nailing surface for ext. trim and siding. I've had a few requests for it as well, so being as it was not too hard to include I added it in. There are now seven possible corner treatments for walls, the other two are California or None.
                                http://design.medeek.com/resources/images/wall_su274_800.jpg
                                I typically like to name all of the groups I create within the assemblies however there may be some who do not want this behaviour and so I have made it optional.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 0.9.9k - 11.15.2018
                                  • Added the ability to import materials directly from the model within the Custom Material Libary/Manager in the global settings.
                                  • Provided an additional parameter in the Wall Corners tab of the global settings for setting the thickness of corner blocking (3 and 4 Stud Block corner treatment only).
                                  http://design.medeek.com/resources/images/wall_su278_800.jpg
                                  With this latest update the tutorial on the Material Manager is somewhat out-of-date/obsolete. However the basic functionality has not changed, I've really only added one additional action.
                                  http://design.medeek.com/resources/images/wall_su279_800.jpg
                                  The ability to customize the blocking on these corner treatments was per a request from one of our Australian clients. I've added a tooltip in the global settings to more fully explain the usage of this parameter.
                                  Now back to the big items on the list.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Some of you may have noticed the difference in the way materials are handled between the garage doors and man doors. The method being used in the garage door module is the new and improved method. I will be updating both the man door module and the window module to this new system which incorporates the materials in the Custom Material Library.
                                    Also at some point I need to switch the draw door, draw window and draw garage door menus to HTML. As always, never a dull moment and way too much to do.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Per customer request the available sizes of Wide Flange Steel Beams will be increased to the following:
                                      W8x10
                                      W8x13
                                      W8x15
                                      W8x18
                                      W8x21
                                      W10x12
                                      W10x15
                                      W10x17
                                      W10x19
                                      W12x14
                                      W12x16
                                      W12x19
                                      W12x22
                                      W14x22
                                      W14x26
                                      W14x30
                                      W14x34
                                      W16x26
                                      W16x31
                                      W16x36
                                      W16x40
                                      W18x35
                                      W18x40
                                      W18x46
                                      W18x50
                                      W21x44
                                      W21x50
                                      W21x57
                                      W21x62
                                      W24x55
                                      W24x62
                                      W24x68
                                      W24x76
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 0.9.9i - 11.10.2018
                                        • Added angle iron (L) beams to the beam module.
                                        • Added fillet radiuses to wide flange (W) and universal (UB) beams.
                                        http://design.medeek.com/resources/images/wall_su272_800.jpg
                                        Nine different beam types with two series of wide flange beams (W and UB).
                                        http://design.medeek.com/resources/images/wall_su273_800.jpg
                                        Aside from residential structures one could also use the beam module to create various structural steel assemblies, however that is not really the purpose or target audience for this module.
                                        I added the fillets to the wide flange profiles per customer requests. The primary reason for including this information it to better predict and check bolt patterns that are on the web of the beam(s). Fillet radiuses are per the various standards.
                                        I haven't take the time yet to add in the few hundred standard sizes from my steel manual but as time allows I will continue to populate these fields. Also if there is specific requests for sizes or series of beam types I will accommodate those requests.
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I been thinking about putting on a weekly one hour webinar where I can demonstrate the latest features of the plugin and then take additional questions from the audience. Would there be any interest in this?
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 0.9.9l - 11.16.2018
                                            • Added an option to include 2D wall geometry in 3D modes (Framing, No Framing, CMU).
                                            • Added an additional layer for 2D geometry.
                                            • Added customizable colors for labels, 2D wall geometry, and 2D features (windows, doors, columns etc...)
                                            http://design.medeek.com/resources/images/wall_su280_800.jpg
                                            http://design.medeek.com/resources/images/wall_su281_800.jpg
                                            http://design.medeek.com/resources/images/wall_su282_800.jpg
                                            The custom colors for the labels, and 2D geometry is per a discussion with a client today. Hopefully this upgrade will help facilitate bringing the 2D geometry into layout for creating floor plans.
                                            design.medeek.com
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 80
                                            • 81
                                            • 29 / 81
