    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • facerF
      facer
      OSB stands for oriented strand board.
      The most common uses are as sheathing in walls, flooring, and roof decking
      OSB is a material with favorable mechanical properties that make it particularly suitable for load-bearing applications in construction. It is now more popular than plywood, commanding 66% of the structural panel market. The most common uses are as sheathing in walls, flooring, and roof decking
      Oriented strand board (OSB), also known as flakeboard, sterling board and aspenite in British English, is a type of engineered wood similar to particle board, formed by adding adhesives and then compressing layers of wood strands (flakes) in specific orientations.
      • medeekM
        medeek
        In a high moisture climate (like on the beach here in Western Washington) I would recommend staying with plywood, but most new construction for walls is 7/16 OSB anymore.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          The current Wall Plugin ToDo list as of 10/29/2018:
          1.) Gable Walls (Standard and Shed) [in progress]
          2.) Stair Module (straight run then landings and complex shapes) [in progress]
          3.) Estimating [in progress]
          4.) Adv. Gypsum (multi-layer gypsum both sides of int. walls)
          5.) Custom width of king and trimmer studs for doors, windows and garage doors.
          6.) Transom windows above doors (rectangle and arch)
          7.) Additional door types (bifold, sliding glass, pocket doors)
          8.) Join/Split Wall Tools
          9.) Wall Stretch Tool
          10.) Wall Grouping
          11.) Wall Dropper
          12.) Engineering
          13.) Levels/Stories Manager
          14.) Interior painting of gypsum
          15.) Wall justification in draw wall tool.
          16.) Gypsum backer studs at tee intersections
          17.) Interior Trim (crown molding, baseboard, chair rails, wainscoting)
          18.) Global Settings (8 new tabs) [in progress]
          19.) Shear Wall Module
          Some of these are extremely high priority and some of these are much lower on the list.
          design.medeek.com
          • medeekM
            medeek
            Version 0.9.8j - 10.30.2018
            • Advanced layers (headers, kings and trimmers) enabled for door, window and garage door framing.
            Somehow along the way I setup advanced layers for the framing however they did not get fully implemented until now.
            design.medeek.com
            • medeekM
              medeek
              With balloon framed gable walls one often sees a lot of trapezoidal picture windows used in these walls:
              https://qhj9t4ethoqu9lfx4606zo12-wpengine.netdna-ssl.com/wp-content/uploads/2010/06/Trapezoid_window_solar_shades.jpg
              I need a little more guidance on the most typical way these openings are framed out. If a header is installed it would have to be inclined and would follow the pitch of the roof.
              Any framing details or suggestions would be greatly appreciated.
              design.medeek.com
              • medeekM
                medeek
                Version 0.9.9 - 10.30.2018
                • Enabled custom window header and trimmer widths within draw and edit menus.
                • Added king and trimmer width parameters to Windows tab of global settings.
                • Fixed a bug with insulation positioned above windows where trimmer quantity is greater than one.
                http://design.medeek.com/resources/images/wall_su255_800.jpg
                This addition was per customer request. I will probably add the same two additional parameters for doors and garage doors in the very near future.
                design.medeek.com
                • medeekM
                  medeek
                  On a somewhat related note to the last post I'm looking at various photos of typical residential framing and I've noticed that many framers will include a plate below or above the header or both:
                  https://banksresidence.files.wordpress.com/2012/09/131.jpg
                  Any thoughts on this?
                  Do I need to add this in as another option?
                  design.medeek.com
                  • medeekM
                    medeek
                    Sounds like I need to provide the option for a header top plate and header bottom plate, (not sure what the exact terminology for these plates should be).
                    design.medeek.com
                    • facerF
                      facer
                      Adding a top and bottom plate may be done when the beam is not available.
                      Although redundant it would allow the framer to allow for beams that are not on site
                      at the time the frame is being constructed.
                      • medeekM
                        medeek
                        I can use either one parameter with four possible options or two parameters with two options each:
                        Built-up Header: NO|TOP|BTM|BOTH
                        or
                        Header Top Plate: YES|NO
                        Header Btm Plate: YES|NO
                        Which would you prefer?
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 0.9.9b - 10.31.2018
                          • Enabled built-up headers within the window draw and edit menus: None, Top, Bottom or Both.
                          • Added the built-up header parameter to the Windows tab of the global settings.
                          http://design.medeek.com/resources/images/wall_su257_800.jpg
                          The window to the left is a good example for where the top plate is not needed, just the bottom plate. as the header butts up directly against the top plate of the wall.
                          The window to the right is set lower in the wall and requires both top and bottom plate as shown.
                          The built-up header parameter allows four options: None, Top, Bottom or both. The default behavior can also be set in the global settings.
                          As with the custom widths on the trimmers and kings I am test bedding this with the windows first, once everyone has had a chance to work this through a bit I will roll it out for doors and garage doors.
                          design.medeek.com
                          • medeekM
                            medeek
                            I'm trying to simulate a G-rib metal wall panel here (clay and stone color):
                            http://design.medeek.com/resources/images/wall_su256_800.jpg
                            The problem of course is that the shadow will be cast a certain direction on the original texture/image but when you render it out the light source may be the opposing direction which will make things look a bit off.
                            Modeling the actual texture/profile of the panel is not a good idea either since it would make the model very heavy.
                            Thoughts?
                            View model here:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            http://design.medeek.com/resources/images/wall_su258_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              This is an example of metal roof and wall cladding (utilizing the Material Manager in both the Truss and Wall plugins):
                              http://design.medeek.com/resources/images/wall_su259_800.jpg
                              http://design.medeek.com/resources/images/wall_su260_800.jpg
                              http://design.medeek.com/resources/images/wall_su261_800.jpg
                              View model here:
                              3D Warehouse
                              The model was created with all three plugins. The only manual edit was moving the person outside of the structure and re-positioning of two anchor bolts that landed in the middle of the garage door. The entire model except for the foundation (slab-on-grade) is fully parametric, moving openings or changing the roof pitch is a couple clicks of the mouse. Model creation time was about 10 minutes.
                              As far as speed of modeling goes I think this is starting to close in on other design packages like Revit and Chief Architect. Once I add the estimating and then the engineering it will even exceed their capabilities.
                              design.medeek.com
                              • medeekM
                                medeek
                                Tutorial 6 - Custom Material Library:
                                design.medeek.com
                                • medeekM
                                  medeek
                                  A whole different area I really haven't explored yet is fixtures (and furniture).
                                  Technically this is a very broad topic and could really use an entirely different plugin to do it justice.
                                  However, I will add in a toolbar called "Fixtures" which will allow the user to select from a matrix of options (Bath, Bedroom, Kitchen etc...) and then to select from some standard layouts.
                                  For bathrooms the layout below (Layout A) is very typical in the US for many mid-range homes:
                                  http://design.medeek.com/resources/images/wall_su262_800.jpg
                                  An 8'x5' bathroom with a sink, toilet and tub.
                                  The idea being that the user can quickly generate any standard layout from a library of components. I will probably include a few default (low poly) components however it will be up to the user to drop their own preferred components into the plugin sub-folders if they want to be able to select from them in the drop down menus.
                                  I don't want to include a large number of high poly count components in the plugin because is will make the .rbz file too large and cumbersome. Besides there are vast libraries of manufacturer components available in the 3D warehouse.
                                  The cool thing about integrating this within the plugin suite is that it will then be possible to obtain counts for estimating purposes on many of these fixtures and assign prices etc...
                                  The Edit menu will allow the user to swap out any of the components and also custom position them as required.
                                  For this particular bathroom layout (and most layouts in general) there is a left and right hand orientation. The user will be able to select the orientation in the draw and/or edit menu. The first mouse click will establish the insertion point the second click will establish the rotation. Clicking the shift key will toggle orientation (left or right).
                                  Some fixtures such as the bath tub shown come in a left and right version. It will be up to the user to upload both versions for use however I will include an additional parameter (rotation: 0 or 180) so that orientation can be controlled.
                                  http://design.medeek.com/resources/images/wall_su263_800.jpg
                                  With this new module I will start with bathrooms first and then branch into other rooms as the need arises.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    I think the fixtures should rather be a separate extension.
                                    • medeekM
                                      medeek
                                      Version 0.9.9e - 11.08.2018
                                      • Removed all advertising banners from the global settings.
                                      • Fixed a bug (metric) for window and door grilles in the global settings.
                                      Note that this is a critical fix for Windows 10 and Mac users. The intermittent response times of the google ads was causing issues for the HTML menu pages of the global settings so I decided to completely remove all advertisements.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 0.9.9d - 11.07.2018
                                        • Added a material parameter for ext. wainscot ledges.
                                        • Added toolbar icons for "Fixtures" module.
                                        http://design.medeek.com/resources/images/wall_su265_800.jpg
                                        http://design.medeek.com/resources/images/wall_su264_800.jpg
                                        This extra parameter was added per customer request.
                                        This will allow the designer to setup a texture/material for rowlock brick.
                                        http://design.medeek.com/resources/images/wall_su266_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          I had a request yesterday for multiple rows of blocking/nogging. A typical example might be a 12 ft. wall with a row of blocking every 4 ft.:
                                          http://design.medeek.com/resources/images/wall_su267_800.jpg
                                          My idea on this is to add two additional parameters to the blocking module/UI:
                                          Number of Rows: 1,2,3 or 4
                                          Row Spacing: inches or mm
                                          The vertical parameter that already exists will position the first row vertically in the wall and then the next rows of blocking will be arrayed upward by the row spacing and number of rows.
                                          For now I am omitting blocking over and under opening but that will probably need to change with multiple rows of blocking.
                                          Multiple rows of blocks is going to get a bit heavy in the model but you have to give people what they want.
                                          Thoughts?
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 0.9.9f - 11.08.2018
                                            • Added two additional parameters for mid-span blocking to enable multiple rows of blocking in a wall panel.
                                            • Added two parameters (number of rows, row spacing) for blocking into the Walls tab of the global settings.
                                            http://design.medeek.com/resources/images/wall_su268_800.jpg
                                            http://design.medeek.com/resources/images/wall_su269_800.jpg
                                            There may be an issue with previously created wall presets due to the addition of more parameters to the wall panel dictionary module. The number of parameters now stored for a preset is 97.
                                            I am also wondering if anyone would be interested in having me publish the attribute library for the wall panels. This would allow other developers to potentially access and modify the Medeek wall panels with their own plugins or have their plugins interact with the Wall plugin.
                                            design.medeek.com
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 80
                                            • 81
                                            • 29 / 81
