    SU2017 gets slower while working
    12 Posts 4 Posters 6.3k Views 4 Watching
      Khai
      what if your getting this slow down.. and have NO intel graphics? I get it on my rig and went down to 2016 make.. 2017 rapidly becomes useless due to lag.
        And you unticked Hardware Acceleration? That would imply your graphics card isn't up to the task. I think you need a new Tradis.
          Khai
          if a Geforce 1060 is not upto the task... we're all in serious doodoo....
          and no option for hardware acceleration in SU...? (unless you mean fast feedback?)
            You said you went back to SU2016 which does have an option to disable Hardware Acceleration.
            Did you try turning off Fast Feedback in SU2017?
            Do you have a 3D Connexion device?
              Khai
              ok in 2016, I have hardware on, fastfeedback on, no issues with lag at all.
              no 3Dconnexion devices.
              will try 2017 with fastfeedback off...
              I was going to move to 2017 for the extension support..
              also to add a data point:
              Windows 10 Home 64-bit
              AMD A8-6600K
              ASUSTeK COMPUTER INC. A68HM-PLUS (FM2+ ) Mobo
              16.0GB Dual-Channel DDR3
              3071MB NVIDIA GeForce GTX 1060 3GB (NVIDIA)
              all drivers up to date as of this post. all windows updates upto date as of this post.
                Make sure you install 2017 correctly. That is by right clicking on the installer and selecting Run as administrator.
                  Khai
                  so long as it does not require being on C.... it's get to be on E with the rest of the programs...
                    If you don't use Run as administrator, SketchUp will not be installed correctly.
                    • N Offline
                      NOMAA
                      Thanks for the tips.
                      I've reinstalled SU2017 as administrator but still have the problem.
                      I've don't have Integrated Intel Graphics only the GeForce GPU so that shouldn't be the problem either.
                      I'm considering buying SU2018 but am a bit scared that it will have the same lag problem as 2017 so I would like to solve the problem first.
                        rv1974
                        SU works fine with 7xx cards.
                        Try to close all trays (open only needed and then close);
                        Disable:
                        profiles, shadows, 'show hidden'. max. texture,
                        Use layer off to hide geometry you don't need now. Transparency quality- low.
