    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Version 2.1.9 - 05.27.2018
      • Replaced the 64 bit SketchUp check in the installation module to fix an incompatibility issue with SketchUp 2014.
      • Added additional wall cladding materials in the sheathing tab of the global settings.
      • Fixed a bug in the top level assembly method of the roof truss module.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.2.0 - 06.19.2018
        • Sub-groups within roof and floor truss assemblies can be made persistent by naming these groups or component instances to (custom1, custom2, custom3, etc...), also all other user defined geometry (ie. faces, text, lines and dimensions) are also retained when the assemblies are regenerated by the plugin.
        design.medeek.com
        • medeekM
          medeek
          I don't have a half hip (rafter roof) setup yet however there is probably a workaround by combining a gable with a hip and then using the trim tool to manually trim some of the rafters, however I haven't really tried this at least not for a real design.
          I took about 10-15 minutes and tried creating a half hip with a gable and hip roof as primitives. Using the trim tool made it fairly easy to clean up the rafters, see results here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          Since the end result is not parametric you will want to be sure that you have all of your rafter depths, overhangs etc... set before you dive into the manual editing of such a roof.
          This is obviously a painful and slow process. Conclusion, I need to add in a half hip rafter roof.
          design.medeek.com
          • medeekM
            medeek
            Version 2.2.0b - 09.25.2018
            • Fixed a bug so that structural outlookers can be enabled without utilizing a gable end truss.
            Technically this should not be allowed since structural outlookers typically require a dropped top chord and currently the only way to achieve a dropped top chord is with a gable end truss (option enabled).
            However, since I am not strictly disallowing it I provided some logic so that the appropriate parameters are set so that this particular state is possible. Previously, the gable end truss routine set some required parameters that the structural outlookers were dependent on. Now the outlooker algorithm will set those parameters if they are not previously set by the gable end truss algorithm.
            This is a fairly minor fix/patch.
            design.medeek.com
            • medeekM
              medeek
              Version 2.2.1 - 10.05.2018
              • The trim tool now allows for multiple trim operations once a trimming plane is selected.
              • Pressing the ESC key will reinitialize the trim tool during multiple trim operations, space bar will terminate.
              • The trim tool will now trim components as well as groups.
              design.medeek.com
              • medeekM
                medeek
                Version 2.2.2 - 10.14.2018
                • Name of plugin changed to "Medeek Truss".
                • Updated the licensing system to include a 30 day limit of the trial version.
                • Updates to the HTML pages of the global settings.
                This next week I plan on returning to the multi-pitch hip roof and start back up where I left off a few months ago. I am also going to be adding in the custom material manager so that the truss plugin has the same capabilities as the wall plugin.
                After that the next big push is to make all of the rafter roofs parametric with HTML based edit menus similar to the common truss edit menu.
                While all this is going on I would also like to complete the stair module of the wall plugin. A lot of things to juggle right now.
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.2.2b - 10.16.2018
                  • Updated the "Edit Truss Assembly" menu so that it properly loads default values when advanced options are expanded.
                  • Added a user definable name to truss assemblies that will be utilized in the future options and upgrades.
                  A number of other "under the hood" updates (to numerous to list) were also incorporated to bring the code more in line with the wall plugin and its more efficient and modular organization scheme.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.2.3 - 10.26.2018
                    • Added a Custom Material Library/Manager in the Materials tab of the Global Settings.
                    • Enabled custom materials for wall sheathing, wall cladding, roof sheathing and roof cladding in the HTML wall draw and edit menus for common trusses.
                    • Enabled the ability group materials and control which drop down menu they will appear in.
                    • Added an SKM file import utility to the Material Library.
                    • Default wall sheathing and wall cladding materials brought in line with options available in wall plugin.
                    http://design.medeek.com/resources/images/truss_su360_800.jpg
                    http://design.medeek.com/resources/images/truss_su359_800.jpg
                    Note the various wall sheathing options that are brought over from the wall plugin (ie. Tyvek, Zip Systems, Plywood, Densglass etc..)
                    Also note that the custom and expanded materials selection is only available for common truss shapes (ie. common trusses, scissor trusses etc...). I have not yet implemented the new system for other truss shapes and rafter roofs, that is work for yet another day.
                    There is still a tremendous amount of work that needs to be done with this plugin. Many of the specialty truss shapes do not even have advanced options available to them yet. All I can do is keep hacking away at it and maybe one day I will have the resources to really push this thing along.
                    http://design.medeek.com/resources/images/truss_su361_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.2.3b - 10.26.2018
                      • Fixed a bug in the attribute library for common trusses.
                      design.medeek.com
                      • medeekM
                        medeek
                        @juju said:
                        medeek, it looks like you've started something...
                        [attachment=0:177uncrq]<!-- ia0 -->can-o-worms.gif<!-- ia0 -->[/attachment:177uncrq]
                        It's been over three years now and I'm still working on it, seems I've also opened other cans as well, not sure where this all ends, but it's certainly fun.
                        design.medeek.com
                        • jujuJ
                          juju
                          Thanks for the perseverance and the high grade of scripts.
                          • medeekM
                            medeek
                            Version 2.2.4 - 11.02.2018
                            • Enabled wall sheathing, wall cladding, ceiling gypsum and roof cladding for monopitch trusses.
                            • Enabled gutters and downspouts for monopitch trusses.
                            • Enabled the "Edit Truss Assembly" function for all monopitch trusses (imperial and metric units).
                            http://design.medeek.com/resources/images/truss_su364_800.jpg
                            I still need to add a few more advanced options to the monopitch truss type:
                            • Roof Returns
                            • Battens
                            • Soffit Cut
                            • Heel Blocking
                            I'm also thinking about adding an insulation option for the ceiling for trusses and rafter roofs so that the truss plugin is up to speed with the wall plugin. Some additional feedback in this regard would be helpful.
                            With monopitch trusses there is also the issue where the exterior wall corner is created by the truss and hence I need to apply some corner trim on these corners. I will give this some more thought.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.2.4b - 11.08.2018
                              • Licensee name now appears in the License tab of the Global Settings when plugin is registered.
                              • Removed all advertising banners from the global settings.
                              Even though this may appear to be a minor revision it is actually a critical fix/upgrade for users running on Mac and Windows 10.
                              The advertising banners would only load intermittently and hence would cause the HTML menus to not render (blank white browser window). After giving this some more thought and deciding that the advertising revenue generated by the plugin was not a significant amount, and a less cluttered look is always more appealing, it just made more sense to remove all of it completely.
                              I've also updated the license tab to be up to date with the Wall plugin's license tab.
                              This same issue with the advertising banners in the global settings also plagues the Wall plugin. I will be issuing a new revision for it in short order, that strips the advertising from the plugin. I appreciate everyone's patience in this regard.
                              design.medeek.com
                              • medeekM
                                medeek
                                I've recently been thinking about the multi-pitch hip roof again. Eventually I needed to return to this topic since the designer needs the flexibility of assigning different pitches to the various roof planes.
                                The same issues with multi-pitch hip truss sets applies to rafter roofs as well.
                                When you have a hip roof situation and the pitches are different on adjacent roof planes yet you want to maintain the same overhang and line up the fascia then the wall top plate must change. However with trusses rather than change the top plate you simply have to raise the heel of the truss on the low side until it equals the height of the adjacent side.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Does anyone have any shop drawings of an asymmetric hip truss set they can send me. Specifically I am looking for a hip truss set that has different pitches for front and back and then possibly a different pitch on the ends. I have my theories on how such a truss set should be put together but it is worth the effort to study this a bit further and verify.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Tutorial 8 - Trim Function:
                                    View model here:
                                    3D Warehouse
                                    I've really got to get complex roof framing figured out. The workaround does work (per the video), but who really wants to work that hard? My inherent laziness is what drives me to create these tools, which in turn help not only myself but everyone else who would rather spend 5 minutes designing a roof rather than 4 hours.
                                    I would rather be spending that time playing a game of chess, cooking a good meal or watching a show with the wife.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.2.5b - 12.10.2018
                                      • Added the Extend function for (solid) groups and components. This function allows the user to extend a member to a single plane/face.
                                      http://design.medeek.com/resources/images/truss_su366_800.jpg
                                      The tool also has the ability to handle fairly complex, prismatic beams etc...
                                      A huge shout out to ThomThom and John (John_DrivenuptheWall) from the SketchUp forums for helping me sort some of the issues out with the algorithm and code.
                                      Tutorial 10:
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        ***** CHRISTMAS SPECIAL *****
                                        This year after Thanksgiving we ran a Cyber Monday special (SketchUcation Newsletter) on just the Wall Plugin and the reception was excellent. Unfortunately, I did not run the Truss Plugin with that same promotion. In lieu of a Thanksgiving promotion I will be running a 24 hour Christmas Special instead for the Truss Plugin.
                                        The special will only run from 12:00AM - 11:59PM (PST) on December 12th, which is tomorrow. The price will be marked down to $35.00 (USD). You do not need a discount code, when you go to purchase the price will come up as the discounted price above. This discount only applies to new purchases and not to renewals.
                                        Once the special has ended I will not be accepting requests to honor the special at a later date, there will be no "rain checks".
                                        Thank-you for your support and a very Merry Christmas to all and prosperous New Year.
                                        http://design.medeek.com/resources/images/xmas_tree_large.png
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                          Should anyone be this deep into this thread and not have realized how useful this extension is, take my word for it, it is very useful. If you're sitting on the fence the one-day once-off Christmas discount being offered is plenty of incentive to get it.
                                          • medeekM
                                            medeek
                                            Version 2.2.5 - 12.08.2018
                                            • Added Trim 2 icon to the Medeek Tools toolbar.
                                            • Added the trim 2 function for (solid) groups and components. This trim function allows the user to select two trimming planes.
                                            http://design.medeek.com/resources/images/tools_su_menu_12132018.jpg
                                            This additional trim function will be helpful in trimming more complicated geometry like hip rafters and triangular pieces of roof sheathing or cladding.
                                            Similar to the regular trim function this tool can also be utilized on any non-plugin geometry so long as it is a (solid) group or component.
                                            View video here:
                                            design.medeek.com
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 76
                                            • 77
                                            • 55 / 77
