    3D Truss Models
    1.5k Posts 32 Posters 2.0m Views 31 Watching
    • medeekM
      medeek
      Spending some time the last couple of days thinking about the floor module (floor trusses, I-joists, solid sawn joists).
      The obvious 800 lbs gorilla is the ability to easily add openings into these floors. The other missing element is the ability to create a polygon shaped floor (something beyond a rectangle outline).
      With regards to polygon shaped geometry I've already done the heavy lifting when I programmed the foundation plugin to generate polygon shaped layouts (slab and stemwall). The details in trimming the joists is also mostly figured out since my rebar and mesh routine for slabs utilizes a function that will form the basis for this function. It is really just a matter of finding the time and then digging into the code deep for a solid 12+ hour period (uninterrupted).
      These two issues are my main focus the next week or two. If I can address both as well have the edit function work seamlessly with both then I will have created an actual functional floor module.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I have a lot of people recently asking me about features that are or are not included in the plugin. Granted my documentation is still in disarray, especially the manual, but I would strongly suggest doing a search in the Changelog if you are interested in a particular feature and would like to check if it has been implemented yet:
        404 - File or directory not found.
        (design.medeek.com)
        design.medeek.com
        • medeekM
          medeek
          I've been looking at adding in the ability to handle dual pitch hip roofs:
          http://design.medeek.com/resources/images/truss_su357_800.jpg
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          The first thing that jumps out at me is the jack rafters do not line up when the pitches are different. Also if the overhang is the same and the fascia is the same height then the top plate will be a different height for the different pitches.
          design.medeek.com
          • pbacotP
            Yeah irregular pitch roofs are kind of tricky. They occur nevertheless.
            • jujuJ
              juju
              That'll be neat! Just a quick question (or two), are all existing options/functions (as relevant) ready and implemented across all truss types? Manual?
              • medeekM
                medeek
                I am still adding advanced options and the edit function to each truss type and floor type. Some are further along than others, but progress is steady.
                The manual is currently way down on the todo list, once the plugin matures further it will rise to the top.
                With dual pitch hip roofs technically one could have a different pitch for all four sides (the most general case). I should probably try to code this most general case then all the rest simply fall out of it.
                http://design.medeek.com/resources/images/truss_su358_800.jpg
                View model here:
                3D Warehouse
                design.medeek.com
                • medeekM
                  medeek
                  It is certainly an interesting puzzle. Calculating the commons, jacks and hip rafters is not a problem, I can figure that out. The one item that has me though is the fact that if each pitch is different and assuming the same overhang all the way around and the same birdsmouth cut then the top plate of each wall will need to be slightly different. Again I can make that adjustment for each side of the roof. The real question then is what to do with the birdsmouth cut of the hip rafters? Which wall height does one use?
                  design.medeek.com
                    Not exactlly truss house but... 😄
                    • medeekM
                      medeek
                      Version 2.1.9 - 05.27.2018
                      • Replaced the 64 bit SketchUp check in the installation module to fix an incompatibility issue with SketchUp 2014.
                      • Added additional wall cladding materials in the sheathing tab of the global settings.
                      • Fixed a bug in the top level assembly method of the roof truss module.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.2.0 - 06.19.2018
                        • Sub-groups within roof and floor truss assemblies can be made persistent by naming these groups or component instances to (custom1, custom2, custom3, etc...), also all other user defined geometry (ie. faces, text, lines and dimensions) are also retained when the assemblies are regenerated by the plugin.
                        design.medeek.com
                        • medeekM
                          medeek
                          I don't have a half hip (rafter roof) setup yet however there is probably a workaround by combining a gable with a hip and then using the trim tool to manually trim some of the rafters, however I haven't really tried this at least not for a real design.
                          I took about 10-15 minutes and tried creating a half hip with a gable and hip roof as primitives. Using the trim tool made it fairly easy to clean up the rafters, see results here:
                          3D Warehouse
                          Since the end result is not parametric you will want to be sure that you have all of your rafter depths, overhangs etc... set before you dive into the manual editing of such a roof.
                          This is obviously a painful and slow process. Conclusion, I need to add in a half hip rafter roof.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.2.0b - 09.25.2018
                            • Fixed a bug so that structural outlookers can be enabled without utilizing a gable end truss.
                            Technically this should not be allowed since structural outlookers typically require a dropped top chord and currently the only way to achieve a dropped top chord is with a gable end truss (option enabled).
                            However, since I am not strictly disallowing it I provided some logic so that the appropriate parameters are set so that this particular state is possible. Previously, the gable end truss routine set some required parameters that the structural outlookers were dependent on. Now the outlooker algorithm will set those parameters if they are not previously set by the gable end truss algorithm.
                            This is a fairly minor fix/patch.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.2.1 - 10.05.2018
                              • The trim tool now allows for multiple trim operations once a trimming plane is selected.
                              • Pressing the ESC key will reinitialize the trim tool during multiple trim operations, space bar will terminate.
                              • The trim tool will now trim components as well as groups.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.2.2 - 10.14.2018
                                • Name of plugin changed to "Medeek Truss".
                                • Updated the licensing system to include a 30 day limit of the trial version.
                                • Updates to the HTML pages of the global settings.
                                This next week I plan on returning to the multi-pitch hip roof and start back up where I left off a few months ago. I am also going to be adding in the custom material manager so that the truss plugin has the same capabilities as the wall plugin.
                                After that the next big push is to make all of the rafter roofs parametric with HTML based edit menus similar to the common truss edit menu.
                                While all this is going on I would also like to complete the stair module of the wall plugin. A lot of things to juggle right now.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 2.2.2b - 10.16.2018
                                  • Updated the "Edit Truss Assembly" menu so that it properly loads default values when advanced options are expanded.
                                  • Added a user definable name to truss assemblies that will be utilized in the future options and upgrades.
                                  A number of other "under the hood" updates (to numerous to list) were also incorporated to bring the code more in line with the wall plugin and its more efficient and modular organization scheme.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.2.3 - 10.26.2018
                                    • Added a Custom Material Library/Manager in the Materials tab of the Global Settings.
                                    • Enabled custom materials for wall sheathing, wall cladding, roof sheathing and roof cladding in the HTML wall draw and edit menus for common trusses.
                                    • Enabled the ability group materials and control which drop down menu they will appear in.
                                    • Added an SKM file import utility to the Material Library.
                                    • Default wall sheathing and wall cladding materials brought in line with options available in wall plugin.
                                    http://design.medeek.com/resources/images/truss_su360_800.jpg
                                    http://design.medeek.com/resources/images/truss_su359_800.jpg
                                    Note the various wall sheathing options that are brought over from the wall plugin (ie. Tyvek, Zip Systems, Plywood, Densglass etc..)
                                    Also note that the custom and expanded materials selection is only available for common truss shapes (ie. common trusses, scissor trusses etc...). I have not yet implemented the new system for other truss shapes and rafter roofs, that is work for yet another day.
                                    There is still a tremendous amount of work that needs to be done with this plugin. Many of the specialty truss shapes do not even have advanced options available to them yet. All I can do is keep hacking away at it and maybe one day I will have the resources to really push this thing along.
                                    http://design.medeek.com/resources/images/truss_su361_800.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.2.3b - 10.26.2018
                                      • Fixed a bug in the attribute library for common trusses.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        @juju said:
                                        medeek, it looks like you've started something...
                                        [attachment=0:177uncrq]<!-- ia0 -->can-o-worms.gif<!-- ia0 -->[/attachment:177uncrq]
                                        It's been over three years now and I'm still working on it, seems I've also opened other cans as well, not sure where this all ends, but it's certainly fun.
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                          Thanks for the perseverance and the high grade of scripts.
                                          • medeekM
                                            medeek
                                            Version 2.2.4 - 11.02.2018
                                            • Enabled wall sheathing, wall cladding, ceiling gypsum and roof cladding for monopitch trusses.
                                            • Enabled gutters and downspouts for monopitch trusses.
                                            • Enabled the "Edit Truss Assembly" function for all monopitch trusses (imperial and metric units).
                                            http://design.medeek.com/resources/images/truss_su364_800.jpg
                                            I still need to add a few more advanced options to the monopitch truss type:
                                            • Roof Returns
                                            • Battens
                                            • Soffit Cut
                                            • Heel Blocking
                                            I'm also thinking about adding an insulation option for the ceiling for trusses and rafter roofs so that the truss plugin is up to speed with the wall plugin. Some additional feedback in this regard would be helpful.
                                            With monopitch trusses there is also the issue where the exterior wall corner is created by the truss and hence I need to apply some corner trim on these corners. I will give this some more thought.
                                            design.medeek.com
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 76
                                            • 77
                                            • 55 / 77
