    3D Truss Models
    1.5k Posts 31 Posters 1.4m Views 30 Watching
    • medeekM Offline
      medeek
      @juju said:
      medeek, it looks like you've started something...
      [attachment=0:177uncrq]<!-- ia0 -->can-o-worms.gif<!-- ia0 -->[/attachment:177uncrq]
      It's been over three years now and I'm still working on it, seems I've also opened other cans as well, not sure where this all ends, but it's certainly fun.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ Offline
        juju
        Thanks for the perseverance and the high grade of scripts.
        • medeekM Offline
          medeek
          Version 2.2.4 - 11.02.2018
          • Enabled wall sheathing, wall cladding, ceiling gypsum and roof cladding for monopitch trusses.
          • Enabled gutters and downspouts for monopitch trusses.
          • Enabled the "Edit Truss Assembly" function for all monopitch trusses (imperial and metric units).
          http://design.medeek.com/resources/images/truss_su364_800.jpg
          I still need to add a few more advanced options to the monopitch truss type:
          • Roof Returns
          • Battens
          • Soffit Cut
          • Heel Blocking
          I'm also thinking about adding an insulation option for the ceiling for trusses and rafter roofs so that the truss plugin is up to speed with the wall plugin. Some additional feedback in this regard would be helpful.
          With monopitch trusses there is also the issue where the exterior wall corner is created by the truss and hence I need to apply some corner trim on these corners. I will give this some more thought.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.2.4b - 11.08.2018
            • Licensee name now appears in the License tab of the Global Settings when plugin is registered.
            • Removed all advertising banners from the global settings.
            Even though this may appear to be a minor revision it is actually a critical fix/upgrade for users running on Mac and Windows 10.
            The advertising banners would only load intermittently and hence would cause the HTML menus to not render (blank white browser window). After giving this some more thought and deciding that the advertising revenue generated by the plugin was not a significant amount, and a less cluttered look is always more appealing, it just made more sense to remove all of it completely.
            I've also updated the license tab to be up to date with the Wall plugin's license tab.
            This same issue with the advertising banners in the global settings also plagues the Wall plugin. I will be issuing a new revision for it in short order, that strips the advertising from the plugin. I appreciate everyone's patience in this regard.
            design.medeek.com
            • medeekM Offline
              medeek
              I've recently been thinking about the multi-pitch hip roof again. Eventually I needed to return to this topic since the designer needs the flexibility of assigning different pitches to the various roof planes.
              The same issues with multi-pitch hip truss sets applies to rafter roofs as well.
              When you have a hip roof situation and the pitches are different on adjacent roof planes yet you want to maintain the same overhang and line up the fascia then the wall top plate must change. However with trusses rather than change the top plate you simply have to raise the heel of the truss on the low side until it equals the height of the adjacent side.
              design.medeek.com
              • medeekM Offline
                medeek
                Does anyone have any shop drawings of an asymmetric hip truss set they can send me. Specifically I am looking for a hip truss set that has different pitches for front and back and then possibly a different pitch on the ends. I have my theories on how such a truss set should be put together but it is worth the effort to study this a bit further and verify.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Tutorial 8 - Trim Function:
                  View model here:
                  https://3dwarehouse.sketchup.com/model/9cf8f6a5-6066-4d27-99e0-775608225e4c/Trim-Test
                  I've really got to get complex roof framing figured out. The workaround does work (per the video), but who really wants to work that hard? My inherent laziness is what drives me to create these tools, which in turn help not only myself but everyone else who would rather spend 5 minutes designing a roof rather than 4 hours.
                  I would rather be spending that time playing a game of chess, cooking a good meal or watching a show with the wife.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.2.5b - 12.10.2018
                    • Added the Extend function for (solid) groups and components. This function allows the user to extend a member to a single plane/face.
                    http://design.medeek.com/resources/images/truss_su366_800.jpg
                    The tool also has the ability to handle fairly complex, prismatic beams etc...
                    A huge shout out to ThomThom and John (John_DrivenuptheWall) from the SketchUp forums for helping me sort some of the issues out with the algorithm and code.
                    Tutorial 10:
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      ***** CHRISTMAS SPECIAL *****
                      This year after Thanksgiving we ran a Cyber Monday special (SketchUcation Newsletter) on just the Wall Plugin and the reception was excellent. Unfortunately, I did not run the Truss Plugin with that same promotion. In lieu of a Thanksgiving promotion I will be running a 24 hour Christmas Special instead for the Truss Plugin.
                      The special will only run from 12:00AM - 11:59PM (PST) on December 12th, which is tomorrow. The price will be marked down to $35.00 (USD). You do not need a discount code, when you go to purchase the price will come up as the discounted price above. This discount only applies to new purchases and not to renewals.
                      Once the special has ended I will not be accepting requests to honor the special at a later date, there will be no "rain checks".
                      Thank-you for your support and a very Merry Christmas to all and prosperous New Year.
                      http://design.medeek.com/resources/images/xmas_tree_large.png
                      design.medeek.com
                      • jujuJ Offline
                        juju
                        Should anyone be this deep into this thread and not have realized how useful this extension is, take my word for it, it is very useful. If you're sitting on the fence the one-day once-off Christmas discount being offered is plenty of incentive to get it.
                        • medeekM Offline
                          medeek
                          Version 2.2.5 - 12.08.2018
                          • Added Trim 2 icon to the Medeek Tools toolbar.
                          • Added the trim 2 function for (solid) groups and components. This trim function allows the user to select two trimming planes.
                          http://design.medeek.com/resources/images/tools_su_menu_12132018.jpg
                          This additional trim function will be helpful in trimming more complicated geometry like hip rafters and triangular pieces of roof sheathing or cladding.
                          Similar to the regular trim function this tool can also be utilized on any non-plugin geometry so long as it is a (solid) group or component.
                          View video here:
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            In order to round out the selection of tools available and also per suggestion from a respected colleague it would seem prudent that I also include a mitering tool in the grab bag that is the Medeek Tools.
                            This can take shape in a few forms however the most important configuration in my opinion would be a tool that can take two solids and miter both of their ends at a common plane, while retaining the solid status of the group or component and retaining all of their properties and meta-data.
                            This would involve selecting the faces to extend/trim on each solid and then selecting two (non-parallel) edges that intersect at a point, so four pick points in total. The intersecting edges need not be orthogonal (90 degrees) just so long as they intersect at a point, that is enough to define the mitering plane.
                            I haven't searched very much yet to see if such a tool/plugin already exists and I don't really want to recreate the wheel on this one. Please let me know if you are aware of such a tool, that can work for any (non-plugin specific) solids.
                            Would there be a need/demand for this proposed tool?
                            design.medeek.com
                              Seems Profile builder has such tool page 28-31...?
                              • medeekM Offline
                                medeek
                                I'm not seeing a miter tool?
                                design.medeek.com
                                  Not specially it's for repare one by one if miter joint of an existing object(page 35) is not as you want...
                                  • medeekM Offline
                                    medeek
                                    Version 2.2.6 - 12.16.2018
                                    • Added the Miter Cut icon to the Medeek Tools toolbar.
                                    • Added the Miter Cut function for (solid) groups and components.
                                    • Enabled temporary (construction) dimensions for trusses, roofs and floor assemblies.
                                    • Added a section in the General tab of the global settings for configuring construction dimensions.
                                    http://design.medeek.com/resources/images/truss_su367_800.jpg
                                    http://design.medeek.com/resources/images/tools_su_menu_active.jpg
                                    Tutorial 12 - Miter Cut:
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.2.5c - 12.13.2018
                                      • Added the Trim 3 icon to the Medeek Tools toolbar.
                                      • Added the Trim 3 function for (solid) groups and components. This trim function allows the user to select three trimming planes.
                                      • Enabled the ability to invert your selection within the Trim 2 and Trim 3 tools using the "CTRL" key in Windows.
                                      http://design.medeek.com/resources/images/tools_su_menu_12162018.jpg
                                      Tutorial 11:
                                      Note that the planes in either advanced trim tool do not need to be orthogonal.
                                      When using the Trim 3 tool the suggested order of selecting the cutting planes/faces is:
                                      Vertical - Vertical - Horizontal
                                      On an outside corner like that I'm not entirely sure how a skilled roof framer would cut that birdsmouth, but at least with the Trim 3 tool you have the option to cut it so it fits tight to the wall as I've shown in the video.
                                      I like including this toolset as part of the Truss plugin, but I am also wondering if there might be a potential market for it as a stand alone plugin ($5 - $10). As it stands currently the prospective user is forced to purchase the entire Truss Plugin if they want to use these tools.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I'm a little burned out right now with the addition of all these extra tools to the Medeek Tools toolbar, but I still feel like I need to add one final addition to the mix.
                                        This one will be called the split tool and similar to the trim tool the user will select a single face (or three points, toggle with the control key?) to define a plane which will then be used to cut a solid group or component in two.
                                        The slightly tricky part with this is to make sure that the copied group/component is nested in the same overall group(s) as the original and retains all of its properties.
                                        This tool would be useful where you've used the followme tool to create some geometry but want to break the resulting solid into separate segments (groups).
                                        design.medeek.com
                                          Seems a very colol "knife"! 😎
                                          • medeekM Offline
                                            medeek
                                            Version 2.2.6b - 12.18.2018
                                            • Added the Split icon to the Medeek Tools toolbar.
                                            • Added the Split function for (solid) groups and components: split plane via one face or three points.
                                            When you first click on the tool it defaults to the user selecting a face for the cutting plane however if you hit the "CTRL" key in Windows it will toggle to the three point mode.
                                            Tutorial 13 - Split Tool:
                                            design.medeek.com
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 75
                                            • 76
                                            • 56 / 76
