    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      Cool use of MsPhysics for simulate this tricky door! Bravo Anton! πŸ‘
      by KLEMENS TORGGLER
      https://i.postimg.cc/63wVvk68/GIF_door1.gif
      https://i.postimg.cc/hj5514XC/tuto_door.jpg
      Door_triangles.skp
      • F Offline
        faust07
        Well done! Complex and simple at the same time. A good example of using MSPhysics.
          @Anton
          Not so bad! 😎
          https://s6.postimg.cc/ilhz28w0h/GIF_mur5.gif
          and after Eclate Deplace
          https://s6.postimg.cc/mvwmxu13l/GIF_mur6.gif
          PS Have you something for "untouch" some objects with a measure given inside mS Physics?
          Sure I have yet Eclate-deplace ...
            I have some problem to better "past" this articulated structure to the landscape!
            Convex Hull is used.
            What is the process for this sort of thing ?
            Density, other sort of hinge, Friction, ... ?
            blocka.skp
            • O Offline
              oheimala
              Hi, I suppose the geometry of squares and hinges is the limit. Try with univeral joint instead of hinges. Then the squares can become to diamonds.
                It's not square cube, it's yet "diamond"! πŸ˜‰
                but maybe i have forgotten forget to give these Diamonds "convex" ! 😲
                change the diamond in convex state ...not better!
                Universal joint gives more liberties but "fall down" not more to the ground!
                here with normal hinge no problem πŸ˜„
                  I put all "diamonds" as Convex Hull : not many better...
                  blocka2.skp
                    I put all as Universal joints not many more better...
                    blocka3.skp
                    • F Offline
                      faust07
                      Shape of the ground: Static Mesh (The hill has concave areas)
                      Material of blocks: Concrete (More weight for the deformation)
                      Stiffness of Hinges: 0.95 (The geometry is otherwise too stiff, because the connections allow little lateral twisting.)
                        Excellent! i will study your solution! πŸ‘
                        I was desesperated! πŸ˜„
                          So my biggest error was the "Concave surface"! 😳
                          Will be very good for create very quickly some "roof structures" ! πŸ‘
                            Seems very low intensity of Stiffness faraway element!
                            In case of concave surface maybe other joints can oblige the element to rotate more...? (universal...)
                            (not yet tested)
                            Here 0.1 stiffness
                              philhumphrey
                              Hello,
                              I am trying to model a buoyant house simulation- However am having problems keeping the buoyancy in one plane. This is what the pontoon posts are for in real life. If anyone could please help me simulate this that would be great- thank you
                              Page Not Found
                              Web word processing, presentations and spreadsheets
                              (drive.google.com)
                                philhumphrey
                                Hello I am looking to model buoyancy, is there a way to stop an object falling over only buoyancy straight up and down
                                  cristyan
                                  Hello philhumphrey ! I have uploaded your file with some modifications. You have to play with density on the house and the buoyant material. and look how joint connection tool works or better you have to play a little with MSPhysics to understand how it works.For this you can download some file on 3dwarehouse searching "MSPhysics".
                                  Buoyany Housing2.skp
                                    A cool site for tuto about MS Physics! πŸ˜‰
                                      tayyab2224
                                      It's been so long when started using Ms physics tool and I have learned so many things from developers but the thing is found on YouTube or over here , is flying an object like helicopter and air plane,
                                      J have downloaded a model of an air plane, the plane can fly yeah, sketchyphysics is used in that model, the I want to ask is, how can do that in Ms physics?
                                      M. Tayyab
                                      • OxerO Offline
                                        Oxer
                                        Hi, I installed the new SketchUp 2019 (Trial) to test it and I have obtain one error message in Ruby Console:
                                        Error al cargar archivo /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb
                                        Error; #<IOError; The required, staged c extension file, "/Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/libraries/stage/osx64/2.5/msp_lib.bundle", is missing!>
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb;204;in `block in require_all'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb;201;in `each'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb;201;in `require_all'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main.rb;70;in `<top (required)>'
                                        /Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb;59;in `require'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics/main_entry.rb;15;in `<top (required)>'
                                        /Applications/SketchUp 2019/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                                        /Applications/SketchUp 2019/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb;21;in `register_extension'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb;21;in `<module;MSPhysics>'
                                        /Users/Oxer/Library/Application Support/SketchUp 2019/SketchUp/Plugins/MSPhysics.rb;5;in `<top (required)>'
                                        MSPhysics v1.0.3 & AMS Library v3.6.0h
                                        SU2019 (Trial) & macOS 10.13.6
                                          Anton_S
                                          Thanks for letting me know. I sort of intend to rewrite MSPhysics over simply recompiling the libraries, which should take a while.
                                          • OxerO Offline
                                            Oxer
                                            Thanks for the info.
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 46
                                            • 47
                                            • 41 / 47
