    Multiple re-use of copied object???
    9 Posts 6 Posters 1.7k Views 6 Watching
    • K
      KJofSketchHouse
      Hi all,
      In SU, I was wondering if it was at all possible to make multiple copies of a selected item without having to singly select the object to move/copy each time. Say I have a grid, and I want to copy a whole heap of circles to random grid intersections. How do I do that quickly without having to select move and copy each time, the last one I have just placed? I want to be able to copy and place as many as I need to by just simply clicking once on each grid random point?
      Is there a way?
      Kerry
        rv1974
        No such app
        (bfy.tw)
        • pbacotP
          What I may do in such a case is make a component and copy it (using generic "Copy" command) then use paste key command to paste to each point. You have to press the key command each time-- so maybe there's a plugin for simply clicking one after the other (considering if it's worth it to go that route). Pay attention to the insertion point of the component you create for accurate placement.
          • K
            KJofSketchHouse
            Yes I see. Not exactly what I wanted, but I reckon its probably the quickest way of going about it at this stage. Thanks pbacot.
            • H
              helvetica
              Kerry, after you copy the first circle and type the distance, you can type 10x to repeat the copy 10 times, or however many times you want. read this short article:
              https://help.sketchup.com/en/sketchup/copying-what-youve-already-drawn#copy-move
              • K
                KJofSketchHouse
                Thanks helvetica. I know about that one. What I was after is to be able to copy and then paste repeatedly at different locations without having to "Click on object, Select Move, Click, Ctrl, Click" everytime. I just want to "Click on object, Select Move, Click, Ctrl, Click, click, click, click, click, click". Similar to what can be done in autocad.
                • T
                  TBoy
                  SketchUp Plugins | PluginStore | SketchUcation
                  SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                  (sketchucation.com)
                  • K
                    KJofSketchHouse
                    Thanks TBoy. Will check it out. I also found "Repeat Copy" by Chris Fullmer of Smustard.com. works well.
                    • HornOxxH
                      HornOxx
                      ... the use of Skatter is ideal to combine your desired randomness with a grid
                      never trust a skinny cook
