    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • E
      Einstein
      @adrisonet said:
      Hello Fredo, I'd love to know if you can extract the lines in between when you use loft by spline. I'm using two lines and the tool, I'd love to get the line.
      https://i.imgur.com/D1TLId9.png
      Those are the lines I want to get in order to create this kind of design.
      https://i.pinimg.com/564x/f7/7d/1e/f77d1e96542765fa0c854430ecb85232.jpg
      Thank you so much!
      I think what yo want to achieve is something like Loop Selection in 3DSmax. You can use ThomThom's Quad Face Tools, convert your mesh to quads, then select quad loops.
      There is also a small plugin by Blindcop "Extrapolate selected edge"
      https://sketchucation.com/forums/viewtopic.php?f=323&t=61884
      which will let you select continuation of an edge in a mesh. However, it doesn't manage triangulated faces well (or at all?).
        rv1974
        Fredo, could you please DISABLE Loft by spline tool working with PRE-selected set of edges?
        Or at least give some give pop-up warning (this operation will take a loot of time co compute blah blah blah)?
        So MANY times I have to shut down skp session (=loosing 15 min of work πŸ˜’ ) because it's freezing forever trying to guess the appropriate order
        • fredo6F
          Do you have a model example where this happens
            rv1974
            Select all 7 (not one by one), then run loft by spline-
            permanent freeze. Very common thing.
            dddd.skp1.skp
            • fredo6F
              This is just a bug, due to the fact that all contours is exactly spaced at the same distance.
              Thanks for signaling
              I fixed it in version 1.7d, just published.
              PS: Actually, the long waiting time you had is not infinite. After a number of seconds, you get back control. So there was no need to force an exit of Sketchup.
              • fredo6F
                NEW RELEASE: Curviloft v1.7d - 31 May 18
                Curviloft 1.7d is a maintenance release fixing a bug in the automatic ordering of contours for the Spline tool.
                See Plugin Page of Curviloft for Download (or use the Sketchup PluginStore plugin for auto-installation.
                Main post of this thread
                  rv1974
                  Unprecedented responsiveness Fredo,many thanks!
                  I'll test the update later today.
                  Another imperfection (?, - maybe I just can't find right buttons) I encountered with Loft by spline is that
                  the inter-medial segments can't keep exact dimensions of initial profiles (lowest and highest ones in attached example 12X81m*, storey height is 3.5m). Another issue is that segments are slightly OFFXY Plane.
                  Is it possible to develop some special mode that'd keep segments exactly parallel to the input profiles, and if initial profiles are equal it'd keep their dimensions?
                  • P.S. In this particular case of 50+ storey towers PlayitItAgain script helped a lot.
                  dddd.skp1.skp2.skp
                  • fredo6F
                    This seems to be a problem of geometry which you can simulate manually.
                    If you wish to keep the junction straight, then the intermediate profiles do not keep the same dimensions.
                    Also, the intermediate sections are parallel to the initial profiles. Do you have something different?
                      rv1974
                      With prussian pedantry I took all horizontal segments, run make faces and...
                      it did it all πŸ™‚ which proves you are right- they are horizontal. What misleads is "~" sign in measurements, must be some SU glitch.
                        rv1974
                        No, what is needed is intermediate segments to preserve initial dimentions of the profile.
                        In attached file the red body is OK (all horizontal segments keep right sizing),
                        and the blue one (lofting with 51 intermediate segments) misbehaves.
                        dddd.skp1.skp21.skp4.skp
                        • fredo6F
                          @rv1974 said:
                          No, what is needed is intermediate segments to preserve initial dimensions of the profile.
                          Then, Curviloft is not adapted, and you should use FollowMe Rotate or TIG Grow extensions.
                          With rotated profile, line joining the begin and end profile corner does not meet the corner of the intermediate profiles.
                          In your red shape, you can see that the short segments joining stores are not aligned and do not form a big straight line.
                            rv1974
                            Thanks for mentioning those alternatives- I'll check them. I'm so glued to your tools that completely forgot others πŸ˜„
                            BTW the straight line on a blue tower shows the horizontal segments don't sit perfectly on it. The gap is ridiculously small in real life scale (~0.3cm in the middle floors, but big enough to spoil the model
                              rv1974
                              Fredo could you take a look please
                              messy result with a newest version (loft)
                              • fredo6F
                                I need to consider this case of indetical profiles more seriously, which Curviloft did not really do.
                                So I'll come with something more robust.
                                  Architure
                                  Hi there,
                                  When selecting more than 3 edge curves, and choosing for junction by orthogonal bezier curves, the surfaces do not get the reach the right spline method result.
                                  Here is what the ruby console shows
                                  Error: #<ArgumentError: Cannot create unit vector from zero length vector>
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in compute_by_offset'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in compute_by_normals'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in spline_profiling_construct'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in option_set_prop'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in call'
                                  c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call'
                                  Just ask me for the file if needed!
                                  Cheers
                                  Manuel
                                  • fredo6F
                                    Yes the file would be useful, as this seems to be a special case.
                                      Architure
                                      Hi there,
                                      Sorry for my late reply. Here is the attached 2018 skp file . You can see that the selected mode is only applied between the first 3 curves.
                                      Let me know if I can provide more information.
                                      Cheers
                                      seat back.skp
                                      • fredo6F
                                        NEW RELEASE: Curviloft v1.8a - 31 Oct 18
                                        Curviloft 1.8a is a maintenance release for bug fixing.
                                        • Z
                                          zswseu
                                          Looking forward to another excellent work.
                                            rv1974
                                            In 99% of of lofting uses I have to straighten borders connnecting ends of segments afterwards(thanks Thom there're Edge tools so it's not manual). Could there be an optionto keep them straight when creating?
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 65
                                            • 66
                                            • 59 / 66
