    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • H Offline
      Helle
      oh, what a shame. I read it as "pre-8" and thought I could use it. Thanks for the fast reply
      • cam_lC Offline
        cam_l
        any chance someone has a copy of the last pre-su8-deprecated version of libfredo? not even sure which version that would be..
        • sketchartist023S Offline
          sketchartist023
          I am still using SU8 and have been for many years. Will not upgrade, been everything I need and more. Any way to upload SU8 compatible versions again for use?
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v8.5h - 27 Aug 18
            LibFredo6 8.5h reestablishes the compatibility with SU8 and SU2013, which was broken with the previous version
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v8.6a - 06 Sep 18
              LibFredo6 8.6a is dedicated to the first public version of FredoCorner
              • OxerO Offline
                Oxer
                New version of Spanish language file:
                LibFredo6_ES.lang.zip
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v8.6c - 08 Sep 18
                  LibFredo6 8.6c fixes a problem of orbiting in FredoCorner.
                  It also integrates an update to the Spanish translation by Oxer.
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v8.6d - 11 Sep 18
                    LibFredo6 8.6d includes a full French translation and fixes problems for FredoCorner 1.1c.
                    • OxerO Offline
                      Oxer
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v8.6e - 19 Sep 18
                        LibFredo6 8.6e includes a Spanish French by Oxerand fixes problems for FredoCorner 1.1d.
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v8.6f - 23 Sep 18
                          LibFredo6 8.6f fixes problems for FredoCorner 1.1e.
                            Architure
                            Hi there,
                            Up: Sorry, probably the wrong place to post that...
                            With Curviloft - Loft by spline, I'm getting this when selecting the "Junction by orthogonal bezier curves" as Spline method. The modifying spline style seems to stop at the third edge. Just ask me the file or screenshots if needed.
                            Error: #<ArgumentError: Cannot create unit vector from zero length vector>
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in compute_by_offset'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in compute_by_normals'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in spline_profiling_construct'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in option_set_prop'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in call'
                            c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call'
                            You're doing amazing job!
                            • fredo6F Offline
                              NEW RELEASE: LibFredo6 v8.6g - 27 Sep 18
                              LibFredo6 8.6f fixes problems for Curviloft and includes a full Chinese translation by guanjin.
                                jessie chuwardi
                                hello , my sketchup doesnt appear anything .....
                                its installed libfredo but doesnt make any change :<
                                how should i do ?
                                  rheeeeeeeee
                                  hello im having trouble with installing all your rubies..
                                  my sketchup version is 2018 and in extension manager, your file all goes 'unvalid signature'
                                  i really wonder what is problem.. of course i installed your newest version, 8.6g
                                  plz let me know how i can fix this
                                  thank you
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v8.6h - 15 Oct 18
                                    LibFredo6 8.6h if for FredoCorner 1.2b (Fixes in Radius offset mode).
                                      Invalid Signature doesn't indicate there are any problems with the extension. It only means it hasn't been "signed" by the extensibility folks at SketchUp. It has nothing to do with the functionality of the extension.
                                      • fredo6F Offline
                                        All my plugins are duly signed and scrambled by the Extension Warehouse.
                                        So there must be something else.
                                          lionroar41
                                          hi Fredo6,
                                          I have downloaded the latest version of fredo6 animator and the library. I am coming up with an issue I think. I have transitioning parts in my model, I select where my model starts transitioning from. However the origin of where my model is transitioning from keeps changing.
                                          Is there something I would need to adjust in my model?
                                          I very much appreciate your help!
                                          • fredo6F Offline
                                            @lionroar41 said:
                                            hi Fredo6,
                                            It s difficult to avise without the model. Could you please post it.
                                            Also, there is a dedicated subforum for Animator.
                                            The best would be that you open a new thread with your problem there.
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 104 / 109
