    [Plugin Library] LibFredo6 - v16.0a - 08 Aug 26
    2.2k Posts 580 Posters 6.1m Views 582 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.6a - 06 Sep 18
      LibFredo6 8.6a is dedicated to the first public version of FredoCorner
      • OxerO Offline
        Oxer
        New version of Spanish language file:
        LibFredo6_ES.lang.zip
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v8.6c - 08 Sep 18
          LibFredo6 8.6c fixes a problem of orbiting in FredoCorner.
          It also integrates an update to the Spanish translation by Oxer.
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v8.6d - 11 Sep 18
            LibFredo6 8.6d includes a full French translation and fixes problems for FredoCorner 1.1c.
            • OxerO Offline
              Oxer
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v8.6e - 19 Sep 18
                LibFredo6 8.6e includes a Spanish French by Oxerand fixes problems for FredoCorner 1.1d.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v8.6f - 23 Sep 18
                  LibFredo6 8.6f fixes problems for FredoCorner 1.1e.
                    Architure
                    Hi there,
                    Up: Sorry, probably the wrong place to post that...
                    With Curviloft - Loft by spline, I'm getting this when selecting the "Junction by orthogonal bezier curves" as Spline method. The modifying spline style seems to stop at the third edge. Just ask me the file or screenshots if needed.
                    Error: #<ArgumentError: Cannot create unit vector from zero length vector>
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in compute_by_offset'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in compute_by_normals'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in spline_profiling_construct'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in option_set_prop'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in call'
                    c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call'
                    You're doing amazing job!
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v8.6g - 27 Sep 18
                      LibFredo6 8.6f fixes problems for Curviloft and includes a full Chinese translation by guanjin.
                        jessie chuwardi
                        hello , my sketchup doesnt appear anything .....
                        its installed libfredo but doesnt make any change :<
                        how should i do ?
                          rheeeeeeeee
                          hello im having trouble with installing all your rubies..
                          my sketchup version is 2018 and in extension manager, your file all goes 'unvalid signature'
                          i really wonder what is problem.. of course i installed your newest version, 8.6g
                          plz let me know how i can fix this
                          thank you
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v8.6h - 15 Oct 18
                            LibFredo6 8.6h if for FredoCorner 1.2b (Fixes in Radius offset mode).
                              Invalid Signature doesn't indicate there are any problems with the extension. It only means it hasn't been "signed" by the extensibility folks at SketchUp. It has nothing to do with the functionality of the extension.
                              • fredo6F Offline
                                All my plugins are duly signed and scrambled by the Extension Warehouse.
                                So there must be something else.
                                  lionroar41
                                  hi Fredo6,
                                  I have downloaded the latest version of fredo6 animator and the library. I am coming up with an issue I think. I have transitioning parts in my model, I select where my model starts transitioning from. However the origin of where my model is transitioning from keeps changing.
                                  Is there something I would need to adjust in my model?
                                  I very much appreciate your help!
                                  • fredo6F Offline
                                    @lionroar41 said:
                                    hi Fredo6,
                                    It s difficult to avise without the model. Could you please post it.
                                    Also, there is a dedicated subforum for Animator.
                                    The best would be that you open a new thread with your problem there.
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v8.6i - 21 Oct 18
                                      LibFredo6 8.6i is for bug fixing and FredoTools 3.3a.
                                        thj14
                                        I have problems with all fredo6 plugins
                                        Have Sketchup 18 pro, uses sketchup extension manager to install
                                        all plugins are updated and are in the same directory.
                                        When I press an icon, it does not respond. Do not get menu and no selections around the object.
                                        Someone who can help me.
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v8.6j - 30 Oct 18
                                          LibFredo6 8.6j is for bug fixing and small GUI adjustments (size of toolbar icons for high-DPI screens).
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v8.6k - 03 Nov 18
                                            LibFredo6 8.6k provides new instructions for downloading FFmeg on Mac-OS platforms.
                                            IMPORTANT: the previous documentations included a link that is no longer supported and, worse, may have been hacked. So if you use Animator, please use the new link,
                                            https://www.ffmpeg.org/download.html
                                            Attached are the new PDF instructions
                                            Instructions_ffmpeg_Mac.pdf
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 111
                                            • 112
                                            • 68 / 112
