    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.5b - 14 Jul 18
      LibFredo6 8.5b is for Animator 2.2b (Full Screen option) and bug fixing
        thaissoares
        Hello, I'm having trouble installing LibFredo6, the error message appears:
        Erro ao carregar o arquivo Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        c:/users/thaĆ­s/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/thaĆ­s/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
        c:/users/thaĆ­s/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/thaĆ­s/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
        C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
        C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Erro ao carregar o arquivo Fredo6_JointPushPull.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
        C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
        C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:47:in module:Fredo6'
        C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in <top (required)>' Erro ao carregar o arquivo Fredo6_RoundCorner.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
        C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:47:in module:Fredo6'
        C:/Users/ThaĆ­s/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in `<top (required)>'
        It does not open in the window bar, but old versions work.
        I use Windows 8 and SketchUp Pro 2017.
        • TIGT Online
          The accented "i" in your [Portuguese ?] Windows user name [ tha**Ć­**s] is almost certainly causing the issue.
          Accented characters broke many scripts, until the newer versions of SketchUp got an updated Ruby installation, with extra tools available to try and circumvent such problems...
          However, Fredo's tools have for a long time forced file-path encoding etc into UTF-8 format...
          So I am surprised that this issue has occurred, let's wait for Fredo's comments...
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v8.5c - 31 Jul 18
            LibFredo6 8.5c fixes issues with non-ascii Windows usernames
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v8.5f - 14 Aug 18
              LibFredo6 8.5f increases the timeout for rendering in Vray from Animator. It also fixes other bugs.
              • H Offline
                Helle
                SU 8 free. Updating I get this:
                Error Loading File Fredo6_!LibFredo6.rb
                undefined method `startup' for LibFredo6:ModuleError Loading File Fredo6_FredoScale.rb
                no implicit conversion to float from nilError Loading File Fredo6_RoundCorner.rb
                aiiii, what's wrong please, please help
                regards Helle
                • jujuJ Offline
                  juju
                  regards Helle
                  Fredo6 is upgrading his extensions, support for some older versions of SU are being deprecated to facilitate compatibility with newer coding. SU8 would definitely be on the list of no longer supported SU versions.
                  • H Offline
                    Helle
                    oh, what a shame. I read it as "pre-8" and thought I could use it. Thanks for the fast reply
                    • cam_lC Offline
                      cam_l
                      any chance someone has a copy of the last pre-su8-deprecated version of libfredo? not even sure which version that would be..
                      • sketchartist023S Offline
                        sketchartist023
                        I am still using SU8 and have been for many years. Will not upgrade, been everything I need and more. Any way to upload SU8 compatible versions again for use?
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v8.5h - 27 Aug 18
                          LibFredo6 8.5h reestablishes the compatibility with SU8 and SU2013, which was broken with the previous version
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v8.6a - 06 Sep 18
                            LibFredo6 8.6a is dedicated to the first public version of FredoCorner
                            • OxerO Offline
                              Oxer
                              New version of Spanish language file:
                              LibFredo6_ES.lang.zip
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v8.6c - 08 Sep 18
                                LibFredo6 8.6c fixes a problem of orbiting in FredoCorner.
                                It also integrates an update to the Spanish translation by Oxer.
                                • fredo6F Offline
                                  NEW RELEASE: LibFredo6 v8.6d - 11 Sep 18
                                  LibFredo6 8.6d includes a full French translation and fixes problems for FredoCorner 1.1c.
                                  • OxerO Offline
                                    Oxer
                                    • fredo6F Offline
                                      NEW RELEASE: LibFredo6 v8.6e - 19 Sep 18
                                      LibFredo6 8.6e includes a Spanish French by Oxerand fixes problems for FredoCorner 1.1d.
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v8.6f - 23 Sep 18
                                        LibFredo6 8.6f fixes problems for FredoCorner 1.1e.
                                          Architure
                                          Hi there,
                                          Up: Sorry, probably the wrong place to post that...
                                          With Curviloft - Loft by spline, I'm getting this when selecting the "Junction by orthogonal bezier curves" as Spline method. The modifying spline style seems to stop at the third edge. Just ask me the file or screenshots if needed.
                                          Error: #<ArgumentError: Cannot create unit vector from zero length vector>
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in axes' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:119:in compute_by_offset'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:58:in compute_by_vectors2' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6profile.rbe:86:in compute_by_normals'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:357:in block in spline_profiling_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in each_with_index' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:351:in spline_profiling_construct'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftspline.rbe:249:in spline_junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:497:in generic_junction_construct'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:1418:in junction_construct' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in block in link_construct_all'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in each' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:407:in link_construct_all'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:396:in link_calculate_all' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftalgo.rbe:530:in option_set_prop'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curvilofttool.rbe:206:in option_set_prop' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in call'
                                          c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_curviloft/curviloftpalette.rbe:773:in block in pal_family_spline_method' c:/users/mbe/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3963:in call'
                                          You're doing amazing job!
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v8.6g - 27 Sep 18
                                            LibFredo6 8.6f fixes problems for Curviloft and includes a full Chinese translation by guanjin.
                                            • 91
                                            • 92
                                            • 93
                                            • 94
                                            • 95
                                            • 108
                                            • 109
                                            • 93 / 109
