    Controlling shadows in hdri dome light
    renderpluginsextensions
    5 Posts 4 Posters 7.2k Views 4 Watching
    • john2J Offline
      john2
      How can I control the sharpness of shadows if I'm using a dome light with an HDRI map? I'm using Vray 3.4 on sketchup 2017
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • majidM Offline
        majid
        It replicates the environment that has been created from . So no way to change the shadow sharpness. Just change the HDRI image with a sharp sun one.
          rv1974
          Easily. Take a round brush and put 15-stop
          circle in PS
          • V Offline
            valerostudio
            I have also seen posts where artists have worked with the gamma. Not sure if this is still relevant in 3.6
            HDRi lighting workflow β€” PETER GUTHRIE
            Following on from a tip I first saw on Bertrand Benoit's blog , I have now adopted a new method of loading my HDRi skies. Essentially you can increase the apparent strength of the sun (and therefore get stronger shadows) by changing the gamma of the loaded HDRi map. If you use the vrayHDRi map (w
            PETER GUTHRIE (www.peterguthrie.net)
              rv1974
              It kills details in sky's lights/shadows
              Though the best way is to bind vray sun to dome light (in Max)
