    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Version 0.8.7c - 07.20.2018
      • Addressed a number of miscellaneous bugs related to metric templates.
      I've also utilized the Australian standard for window and door call outs when using metric templates. If someone would like to have a different call out system implemented for metric units I can do that as well, I just need specifics and what country or name to associate with that call out system.
      This is a critical bug fix release and addresses a number of bugs having to do with metric units but also affects some issues that are also with imperial/US units. I would highly recommend updating to this latest version at your earliest convenience.
      Locating windows and doors along a wall in meters should now work as intended.
      I'm am reasonably sure there are more bugs with the metric version of the plugin since I have not fully tested it in every possible scenario. If you notice anything please feel free to contact me.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        One known issue with the latest upgrades applies to users who have previously installed the plugin. Once you upgrade to the latest version, click on the global settings and then the layers tab. This will reinitialize the layers settings for the plugin.
        This only applies to users that are upgrading and that also have the layers option enabled in the global settings.
        design.medeek.com
        • medeekM
          medeek
          I've introduced a start and end parameter for the wainscoting which allows for partial wainscoting on exterior walls:
          http://design.medeek.com/resources/images/wall_su171_800.jpg
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          This feature has been requested a number of times in that last month so it managed to float to the top.
          design.medeek.com
          • medeekM
            medeek
            Version 0.8.7d - 07.22.2018
            • Added a start and end parameter for exterior wainscoting, which allows for partial wainscoting of a wall panel.
            • All window grille types extended to half glass and full glass doors (single/double).
            http://design.medeek.com/resources/images/wall_su173_800.jpg
            Just an FYI, I am currently working on the garage door module however I've purposely forked the code so that I can keep putting out fires and attending to minor feature requests while I spend the next few days completing this much larger module.
            design.medeek.com
            • medeekM
              medeek
              Ext. Wainscoting is complicated. Currently all I have is Mode 1 in the logic:
              http://design.medeek.com/resources/wallplugin/WAINSCOTING_MODES_800.jpg
              For example in Mode 3 you may start with full height brick then drop down to a half height and then terminate all on one wall panel.
              With the start and end offsets set to zero the result for any of the different modes would be exactly the same, they really only come into play when you begin offsetting the wainscoting from the right and/or left.
              design.medeek.com
              • medeekM
                medeek
                Version 0.8.8 - 07.24.2018
                • Added an additional "mode" parameter for exterior wainscoting, which allows for multiple configurations of partial wainscoting.
                http://design.medeek.com/resources/images/wall_su174_800.jpg
                http://design.medeek.com/resources/images/wall_su175_800.jpg
                There are now four modes however there are other modes possible but I think I have spent enough time on this for now until further requests propel this to the top of the list again.
                View models here:
                3D Warehouse
                3D Warehouse
                design.medeek.com
                • medeekM
                  medeek
                  Version 0.8.9 - 07.25.2018
                  • Added the CMU framing mode for concrete block wall construction.
                  http://design.medeek.com/resources/images/wall_su176_800.jpg
                  http://design.medeek.com/resources/images/wall_su177_800.jpg
                  Currently the CMU mode is mostly the same as the "No Framing" mode with a few subtle differences:
                  1.) Concrete block texture is applied to vertical and horizontal faces of the wall solid to simulate a block wall.
                  2.) Round openings in the wall are cut out to follow the curve of the window or door.
                  3.) Description of the group (solid) has CMU in the text. This will be important in later releases as the estimating and engineering modules are developed and implemented.
                  As I receive further input on this new wall type I'm sure additional features will need to be added to fully bring the CMU wall framing mode up to speed.
                  View model here:
                  3D Warehouse
                  design.medeek.com
                  • pbacotP
                    The CMU module should be interesting as there are whole new set of standards and details. Looks good! Rarely get the chance to work with this.
                    • facerF
                      facer
                      CMU (Concrete Masonry Unit)
                      IMPERIAL SIZES
                      https://www.archtoolbox.com/materials-systems/
                      4" CMU
                      ACTUAL SIZE
                      D X H X L (INCHES) NOMINAL SIZE
                      D X H X L (INCHES)
                      3 5/8 x 7 5/8 x 7 5/8 4 x 8 x 8
                      3 5/8 x 7 5/8 x 15 5/8 4 x 8 x 16
                      6" CMU
                      ACTUAL SIZE
                      D X H X L (INCHES)
                      5 5/8 x 7 5/8 x 7 5/8 6 x 8 x 8
                      5 5/8 x 7 5/8 x 15 5/8 6 x 8 x 16
                      8" CMU
                      ACTUAL SIZE
                      D X H X L (INCHES)
                      7 5/8 x 7 5/8 x 7 5/8 8 x 8 x 8
                      7 5/8 x 7 5/8 x 15 5/8 8 x 8 x 16
                      • medeekM
                        medeek
                        I will probably need to add an additional parameter for specifying the standard block sizes. Currently the way it is setup it can only realistically show a block length of 16" nominal.
                        design.medeek.com
                        • K
                          KrisM
                          Since you are looking at CMU sizes, in the real world the 3/8" mortar space sometimes gets fudged. For example, if I have a 100' long building, technically the block spacing would create a wall which is 3/8" short at one end. This doesn't happen. The block layers will stretch the spacing over some distance to get the last block to line up at 100'. The same thing happens at overhead doors and man doors. For example, a metal man door frame is typically 3'-4" wide, not 3'-4 3/8" wide which the accurate block spacing would require. When you are modelling everything to a theoretical accuracy, it sometimes doesn't jive with reality. Not sure how you resolve this.
                          KrisM
                          • medeekM
                            medeek
                            I'm not actually drawing the blocks just applying a material/texture to the solid wall group to make it appear that way. With this being said some of the finer points with regards to block wall construction can be safely ignored, at least for now.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 0.8.9b - 07.25.2018
                              • Stud/Wall Depth and Width parameters added to the Walls tab of the Global Settings.
                              For CMU walls you will want to disable the standard stud sizes and then specify the wall/stud width (ie. 7.625") with the Walls tab of the global settings. Also set the framing mode to "CMU" if desired.
                              When creating the walls one would probably turn off the advanced wall options since gypsum, sheathing, trim and cladding are usually not needed for this wall type but if required all of the options are available for this wall type as well.
                              One additional note to add is that if you are upgrading the plugin and currently using the layers feature you will want to open up the layers tab of the global settings, so as to reinitialize the layers. I've added an additional layer option for CMU block.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 0.8.9c - 07.26.2018
                                • Added double, triple and quad casement windows to the window draw and edit modules.
                                • Resolved a bug in the window and door attribute library modules.
                                http://design.medeek.com/resources/images/wall_su178_800.jpg
                                I'm not sure if the callouts are really visible with this image but they are formatted like so:
                                (3) 2040CSMT (for the 3 lite 6040 window)
                                This update is per customer request.
                                View model here:
                                3D Warehouse
                                I've also been thinking quite a bit about integration with other plugins and how I can best facilitate that plugin-to-plugin communication.
                                My first thought is that the under the hood structure of the wall is actually fully exposed already and can be modified with any other third party plugin. Everything required to build the wall is contained within the attribute library of the wall panel group (outermost container). I will be publishing a specification which delineates each value and position within the attribute library so other plugin authors can easily obtain or set this information as required and have an exact understanding of what each parameter is.
                                I will also be assembling an API so that another plugin author can cut holes in the walls for openings (windows and doors) and also rebuild the wall panels etc... I'm not exactly sure on all of the details yet but hopefully this will make the plugin more accessible to other plugin authors and allow for better integration.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  A couple of segmental arches and a quinto acuto and equilateral gothic arch:
                                  http://design.medeek.com/resources/images/wall_su179_800.jpg
                                  Selecting either an arch or gothic arch geometry will enable the "Window Arch Radius" parameter as shown in the edit window menu above.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Arched window openings now have exterior trim and wainscoting enabled:
                                    http://design.medeek.com/resources/images/wall_su180_800.jpg
                                    For those interested this is the underlying equations that I'm using to calculate a gothic arch:
                                    http://design.medeek.com/resources/wallplugin/GOTHIC_ARCH_800.jpg
                                    Notice that the center of the arch is at the same height as the springline but the lateral placement of the center of the arch is driven by the radius since the arch is tangent to the vertical . A classic quinto acuto gothic arch has a radius that is 4/5 of the width of the opening, whereas an equilateral arch will be radius = width.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      These arched windows and their grilles (Prairie Style shown) were a bit more than I was wanting to bite off when I started into them this morning but perseverance won over in the end and I finally got them sorted out:
                                      http://design.medeek.com/resources/images/wall_su181_800.jpg
                                      http://design.medeek.com/resources/images/wall_su182_800.jpg
                                      The half round springline window is created by setting the radius to half the window opening.
                                      Also note that only the picture or fixed window type is available for the arch and gothic arch geometry.
                                      I still need to work on shutters for these window types but that is a job for another day.
                                      View model here:
                                      3D Warehouse
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Does anyone have a good texture for T1-11 siding that they would be willing to share?
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 0.9.0 - 08.03.2018
                                          • Added gothic and segmental arched windows to the window draw and edit modules.
                                          • Added shutters: Solid, Flat Panel, Raised Panel, Louver, Board & Batten to arched and gothic arch windows.
                                          http://design.medeek.com/resources/images/wall_su183_800.jpg
                                          View model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            The arch/gothic arch window rabbit hole was very deep:
                                            http://design.medeek.com/resources/images/wall_su184_800.jpg
                                            Ext. Trim and Shutter (Left)
                                            http://design.medeek.com/resources/images/wall_su185_800.jpg
                                            Interior Casing
                                            http://design.medeek.com/resources/images/wall_su186_800.jpg
                                            Interior Casing Options
                                            Adding a new window type now entails the following additional features that must all be considered:
                                            1.) Exterior Trim (Style A, Style B)
                                            2.) Interior Casing/Trim (Style A, Style B, Style C)
                                            3.) Window frame, casing and glass (window geometry will dictate if additional styles can be created for that geometry in addition to the standard fixed window).
                                            4.) Window Grille (ten different grille configurations currently)
                                            5.) Shutters (five different shutter types currently in three different configurations)
                                            Some window types will also involve additional parameters due to asymmetry or other special features.
                                            The trapezoid or triangular window may also involve a pitched header will further complicate matters with wall framing.
                                            design.medeek.com
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 80
                                            • 81
                                            • 22 / 81
