    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • pbacotP
      There's "Chief Architect" --don't know if there's a licensed individual involved. Not the same as if you were trying to sell services as an architect but some people do get litigious and states do have widely encompassing protections on the word.
        Medeek 3D Construction ? πŸ˜‰
        • medeekM
          medeek
          Added the APL4 Beam-to-Column Tie per designer request:
          http://design.medeek.com/resources/images/wall_su147_800.jpg
          Installed in pairs with total of six STN22 decorative washers.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • Bob JamesB
            Bob James
            Medeek Architecture Designer?
            • C
              Charlie__V
              Medeek AAi for Sketchup (Artificial Architecture intelligence) πŸ’š
              • K
                KrisM
                I would put a request in for all the Simpson Outdoor Accent Connectors as well as the CPTZ Concealed Post tie. I've modeled some of these for one project but it would be great if they were incorporated into your extension (almost called it a plugin πŸ˜„ ).
                • medeekM
                  medeek
                  I was going to add the post feature to the foundation ext. but I think I will add it to the wall ext.
                  To this feature I will then add the ability to include post bases and caps. Then I will add in all of various Simpson hardware for free standing posts.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 0.8.5 - 07.11.2018
                    • Added the Prairie Grille for picture windows.
                    • Added "Casement" and "Fixed" to the window installation types, these currently are modeled identical to the picture window type.
                    • Added a "No Header" option for windows.
                    • Updated the licensing system to include a 30 day limit of the trial version.
                    • Added Simpson Strong-Tie APL4 Beam-to-Column Tie to the beam hanger library.
                    • Name of plugin changed to "Medeek Wall".
                    http://design.medeek.com/resources/images/wall_su149_800.jpg
                    http://design.medeek.com/resources/images/wall_su148_800.jpg
                    design.medeek.com
                    • medeekM
                      medeek
                      Trying to get to the big stuff but ended up working on some fires and adding some window grilles per customer requests.
                      The following grille options now available will be:
                      • None
                      • Standard
                      • Prairie
                      • Perimeter
                      • Short Fractional
                      • Farmhouse
                      http://design.medeek.com/resources/images/wall_su150_800.jpg
                      View model here:
                      3D Warehouse
                      (3dwarehouse.sketchup.com)
                      Now that I've spent some time organizing the window module better adding various grille configurations is a breeze. If you need others added just let me know.
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 0.8.5b - 07.12.2018
                        • Added the following Grille Types for all windows: Prairie, Perimeter, Short Fractional, Farmhouse, Grid2x2, Grid2x3, Grid3x2, Grid3x3.
                        http://design.medeek.com/resources/images/wall_su151_800.jpg
                        A Grid3x2 would be three columns and two rows (6 lite).
                        There are now 10 variants available for window grilles. One of these days I might consider adding in the Diamond and Queen Anne patterns but right now I'm "grille fatigued". On to bigger and better things.
                        design.medeek.com
                        • medeekM
                          medeek
                          Beyond the trim and grilles the only exterior window treatment I am missing is shutters:
                          http://design.medeek.com/resources/images/wall_su152_800.jpg
                          I will need to add in another set of parameters for shutters and associated menus.
                          The parameters will be:
                          Shutter Geometry: Single or Double
                          Shutter Style: Louver, Raised Panel, Flat Panel, Board & Batten
                          Shutter Material
                          Shutter Thickness
                          By default they will be half the width of the window opening and their height will be the same as the window opening. The shutter(s) will be offset 2" from the edge of the window to simulate the space taken up by hinges. I will not be showing hinges or any other hardware so as to keep the poly count reasonable.
                          The poly count on the various styles should not be too much of a problem except for the louvered style. Not sure how to model this variant without adding a lot geometry which is going to make the model heavy.
                          http://design.medeek.com/resources/images/wall_su153_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 0.8.6 - 07.14.2018
                            • Added shutters: Solid, Flat Panel, Raised Panel, Louver to rectangular windows.
                            http://design.medeek.com/resources/images/wall_su155_800x500.jpg
                            View model here:
                            3D Warehouse
                            Available shutter styles are:
                            • Solid
                            • Raised Panel
                            • Flat Panel
                            • Louver
                            I have not yet enabled shutters for arched windows, that will be next.
                            I also need to add in a board & batten shutter which is also quite popular.
                            Also note that you can position the shutters on either side of the window (left or right, single shutter) or the more common double shutter configuration as shown.
                            design.medeek.com
                              With the free PBR by Samuel inside SketchUp! πŸ˜‰
                              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/gif-wall_orig.gif
                              or more elaborated πŸ˜„
                              https://2img.net/h/s6.postimg.cc/5i1byrosh/elabo01.jpg
                              • medeekM
                                medeek
                                Board and Batten Shutters:
                                http://design.medeek.com/resources/images/wall_su156_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Arched window with flat panel shutters:
                                  http://design.medeek.com/resources/images/wall_su157_800.jpg
                                  These arched shutters are proving to be a bit more challenging. I will need to figure out a new algorithm for board and batten shutters and louver shutters.
                                  design.medeek.com
                                  • pbacotP
                                    No kidding. I can't even imagine!
                                    • medeekM
                                      medeek
                                      I think I've finally been bested by the complicated geometry and the limitations of SketchUp or perhaps my ability to model within SketchUp.
                                      Notice the raised panel shutters for an arched windows shown below:
                                      http://design.medeek.com/resources/images/wall_su158_800.jpg
                                      To create the raised panel effect I will draw the three outlines and then use the transform_entities method to move the edges into the plane. The problem is when I try this with a curved outline(s) as shown SketchUp does not know how to handle the curved planes/surfaces being created.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I guess I haven't been defeated after all. Using the follow-me method I was able to get it to work:
                                        http://design.medeek.com/resources/images/wall_su159_800.jpg
                                        I now have all the shutter types working for arched windows:
                                        http://design.medeek.com/resources/images/wall_su160_800.jpg
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • jujuJ
                                          juju
                                            These are in your plans ?
                                            https://encrypted-tbn0.gstatic.com/images?q=tbn;ANd9GcQV3o09rtmR7I5uwrD5SuXRSM0-vWZlKHcZaZCWE871s4zQFOuc
                                            http://idata.over-blog.com/2/90/86/68/P1010937--800x600-.jpg
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 80
                                            • 81
                                            • 20 / 81
