    PLEASE HELP! Error Loading File vfs.rb undefined method `fil
    18 Posts 9 Posters 27.6k Views 9 Watching
    • andybotA
      andybot
      wacky! So how is it determined which plugin loads first???
        Alphabetically by filename. V comes pretty late...
        It's a silly bug. Devin... πŸ˜’ πŸ˜„ It warrants a facepalm.
          @sarahbbg said:
          now i am getting this error
          Error Loading File #.rb
          Is a directory - /Users/sarahsaada/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/#.rbError Loading File vfs.rb
          undefined method `file_loaded?' for main:Object
          maybe the plugins folder is in the wrong place?
          You're right! It's not your personal 'users' folder path, but the central library one...
          Type this is the Window > Ruby Console
          Sketchup.find_support_file("Plugins")
          It will return the correct path.
          I hadn't realized you were on MAC.
          When I said edit the new #.rb file with Notepad I hope you understood I meant a 'plain text editor' - do not use a word processor, it will add formatting and break the script.
          Have you seen thomthom's explanation? about how the vfs.rbfile itself has a mis-ordering of lines and how moving the two 'require' lines to the start will fix it...
          • sicksickisckS
            sicksickisck
            I have the same problem; when I copy folder [skp]'plugins' from work to my house .. 😞
              m0ku_m0ku
              Sorry , I have fixed the ruby line as Thomthom recommended.
              But I've still gotten an error.
              "Error Loading File vfs.rb
              no such file to load -- sketchup.rb"
              please help , thank in advance
                IF the very first line of this script reads:
                require 'sketchup.rb'
                or
                require "sketchup.rb"
                Then it should work. πŸ˜’
                I suspect a misplaced " or a missing ' ?
                If you still get an error, then check that there is a file in the SketchUp ' Tools' folder called ' sketchup.rb'.
                If NOT then you must reinstall SketchUp!
                If it's in the ' Plugins' folder then you must remove it.
                If it is in the ' Tools' folder then type $LOAD_PATH...
                If if doesn't include the ' Tools' folder then something is badly adrift...
                • C
                  Cittizewn
                  Its Possible to upload the file vfs.rb fixed..
                  I have the same problem loading it..
                  • E
                    edgaralbandoz
                    I am having this issue after installing Vray1.49. This error shows up when I activate (check-mark) the Vray extension. I am using SketchupPro2015. Any help? Thanks. (Very frustrated with Vray.)
                    Error Loading File /Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/RubyToPython/VfS/Ruby/R2P.rb
                    Error: #<LoadError: dlopen(/Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/RubyToPython/RubyToPython.bundle, 9): no suitable image found. Did find:
                    /Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/RubyToPython/RubyToPython.bundle: mach-o, but wrong architecture - /Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/RubyToPython/RubyToPython.bundle>
                    /Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in require' /Applications/SketchUp 2015/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in require'
                    /Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/RubyToPython/VfS/Ruby/R2P.rb:75:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                    /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/vfs.rb:59:in register_extension'
                    /Users/edgaralbandoz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/vfs.rb:59:in `<top (required)>'
                      dhrubazaan
                      Hello There,
                      I am getting the attached Error message while loading the Sketchup. Please help.
                      • andybotA
                        andybot
                        How old of a version are you trying to use?
                          dhrubazaan
                          My Sketchup is 2016 with Vray 3.4 and my operating system is Windows 7.
