    Objects in Groups Suddenly Hidden
    8 Posts 5 Posters 1.4k Views 5 Watching
    • Joe WoodJ Offline
      Joe Wood
      So suddenly in my model, on all the 10+ Scenes I set up, most everything is hidden and I have to go into each of the groups and do a Unhide All to see them,
      for instance this is a simple elevation Scene I just exported a image from, now if I go back to that Scene, the posts, beams and rafters are Hidden, so what the heck? I didn't Hide anything.
      Joe Wood
      woodsshop.com/
        alpro
        Did you update the scene after you unhid those items?
        • Joe WoodJ Offline
          Joe Wood
          Yeah of course but how did all those things in the different groups get hidden? I didn't open up each group and hide the things in it.
          Joe Wood
          woodsshop.com/
          • pbacotP Offline
            a new sketchup mystery
            • Joe WoodJ Offline
              Joe Wood
              darn ..
              Joe Wood
              woodsshop.com/
                Are you using Hide to make things invisible instead of using Layers?
                • Joe WoodJ Offline
                  Joe Wood
                  No I didn't hide any of those objects inside of the groups Dave.
                  Joe Wood
                  woodsshop.com/
                    Are these things actually 'hidden', or do they have some 'off' [aka 'hidden'] layer[s] assigned to them ?
                    To see if they are hidden use View > Hidden Geometry > ON...
                    Otherwise, check the layer settings...
                    Check which layers the vanishing objects might have assigned...
                    Obviously, SketchUp should not be deciding to make somethings 'hidden' [in either sense] in an unexpected way...
                    I'm sure we can find the culprit...
