    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.9m Views 28 Watching
    • Bob JamesB Offline
      Bob James
      @medeek said:
      Do you have a name or color you would like me to assign to this stucco.
      Cladding_Stucco_Light_Tan
      • medeekM Offline
        medeek
        Grabbed some code from the Truss Plugin this morning and now Glulam Beams are available for window or door headers:
        http://design.medeek.com/resources/images/wall_su90_800.jpg
        The species or types of Glulam beams available are: Western Species, Southern Pine, and UK, Australian and South African varieties.
        Its nice to be able to recycle some code, allows one to implement something very quickly.
        I'm currently working on the corner cladding issue and adding in the option for a LAP or MITER corner treatment.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          As a follow up to a previous post about a day ago I've enabled the wall cladding menus (draw tool and edit menu) so that option (A) as previously discussed above is now a reality:
          http://design.medeek.com/resources/images/wall_su91_800.jpg
          I find this solution a potentially a bit messy since all materials are available within the drop down so there is a possibility of duplicate listings but overall it seems fairly robust and offers the flexibility needed so that the user can define their own materials within SU rather than having to rely on the plugin for a static list of pre-defined materials.
          design.medeek.com
            Bob James
            Is there a new version that includes this? Version 0.7.6?
            • medeekM Offline
              medeek
              Version 0.7.6 is not yet released, so far it will encompass the following fixes and possibly some more:
              • Addition of glulam headers for windows and doors
              • Fixed a bug with the exterior corner trim (end corner)
              • Dynamic material list for cladding
              • LAP and MITER options for corner treatment of the cladding (still a few more hours of coding and testing to go, but progress is solid).
              design.medeek.com
              • medeekM Offline
                medeek
                4" brick facade (Corner Config: LAP) with a 1" air gap and 7/16" sheathing:
                http://design.medeek.com/resources/images/wall_su92_800.jpg
                The mitered corner configuration for cladding is also now working.
                I will address a few other small issues tomorrow morning and then release 0.7.6.
                I've been told that I need to add a lapped option for the sheathing as well since leaving the corners open like we do in the western US doesn't work out so well in the southeastern states.
                I think the next big item on the list I'll tackle is the garage doors so that at least we have one or two options for that available.
                I also have the pseudo code put together for exterior wainscoting (dual exterior cladding). The code behind that wall configuration will get a bit more complicated but hopefully it won't bog down the model too much.
                I currently have 18 major items on the todo list:
                • Interior Trim
                • Garage Doors
                • Door casing for interior walls
                • Gypsum wrap for interior openings
                • Ext. Sheathing LAP option
                • Wall Split Tool
                • Wall Join Tool
                • Gable Wall Tool
                • Wall Grouping
                • SSW Module
                • Columns Module
                • Bug with outside corners less than 90 deg. (framing)
                • Exterior Wainscoting
                • Some additional debugging or checking with the draw wall tool as it relates to auto-corner configuration and defaults for inputs.
                • Global settings parameter allowing user to toggle between standard stud sizes and custom sizes
                • Beam Tool (add to the columns module, one additional icon for toolbar).
                • Wall justification issue (currently the FRONT option is functional)
                • SHIFT key snapping to X or Y axis during wall creation.
                If there are other items you would like to see added to this list please feel free to send them in. Also this list is in no particular order, the squeaky wheel is getting the grease, so if you want something pushed to the top please let me know.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Currently pre-configured doors and windows are saved by the user and accessed by the plugin from the "library" sub-folder of the plugin. The problem I see with this is that if you want to upgrade the plugin and have to remove the "medeek_wall_ext" plugin folder then you must take the added step to copy the contents of the library folder and then put it back after the updated plugin has been installed.
                  Perhaps there is a better location for the user library or I suppose I could make its very location user definable?
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    I've switched to CSS tooltips which allows me to utilize not only text but also graphics:
                    http://design.medeek.com/resources/images/wall_su93_800.jpg
                    I recognize the need for a detailed manual however I find that tooltips like these can be much more useful and instantly accessible.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Looking at the Sheathing Tab above you will also notice I am adding in the option to lap the sheathing at the corners. I figured I might as well knock this one out while the corner lapping code is still fresh in my head. If I wait too long I will have to recalculate and rethink all of the trigonometry (relearn my algorithm), I try not to work too hard, better to work smart
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Sheathing with the corner option set to "LAP":
                        http://design.medeek.com/resources/images/wall_su94_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 0.7.6 - 06.04.2018
                          • Added the option for Glulam Beams for window and door headers.
                          • Cladding corner treatment now has MITER and LAP available as two additional corner options.
                          • Sheathing corner treatment now has LAP available as an additional corner option.
                          • Cladding materials selection extended to include all SketchUp materials currently in model.
                          • Minor bug in exterior corner trim corrected.
                          • The update status message in HTML edit menus (wall, door and window) moved to top of form for better visibility.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Working with a designer this morning has exposed a few minor bugs with the auto-corner configuration. I've already addressed those and the function is that much more robust.
                            I am now addressing another flaw with the wall creation tool (line and polyline) so that it retains the last used parameter values while creating multiple walls. I originally thought I had this enabled but determined with further testing that it was not fully implemented.
                            I will probably roll out a sub-rev. in a couple hours that addresses all of these issues and then jump back onto the garage door and gable wall module programming.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I suppose I am a little obsessed right now, but I realize I am working against the clock on this one. Even though I am hoping for a good response from the SketchUp design community, the orders, even with the promotion, are only trickling in.
                              In order to garner more interest and uptake the plugin needs to be further along and have more features as well as stability. If I can't increase the uptake I will be forced to abandon the project (or at least devoting my full attention to it) and I really don't want to loose the momentum I have right now.
                              So I am scrambling, trying to accomplish as much as possible before I have to ultimately change gears and possibly go back to the corporate world. When that time comes I will continue the development, as I have done with the Truss Plugin in the last two years, but at a decreased rate.
                              I also realize that the competition in this arena is only beginning to heat up and in order to grab a certain segment of that market share I need to establish this plugin as quickly as possible and also make it "hard to beat". So yes, I am quite motivated for a number of reasons.
                              I am currently setting up the garage door module, it is very similar to the door module but will have a few additional (garage door specific) parameters.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Just had an interesting conversation with a professional estimator about the plugin this morning.
                                He reinforced what already I'm seeing with this plugin and how it relates to design, designers and architects.
                                As I've mentioned previously the plugin audience is three fold and the design side probably will utilize the 2D and 3D (no framing) mode the most. The reason being is that most designers are not overly interested in how the structure goes together, their main concern is the layout and placement of windows and doors.
                                The full framing mode will have more utility among the engineers, panel designers, estimators, contractors and DIYers.
                                A building design is really no more than a concept and it takes a whole team of professionals to take something off of paper (or pdf) and make it into a physical reality.
                                Once I have the design side of this software put together and reasonably solid I will begin focusing on the engineering and estimating pieces.
                                This estimator talked at length about the disconnect between himself and the architects. My goal is to help heal this disconnect and get everyone on the same page, I think we can do this.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 0.7.6b - 06.05.2018
                                  • Auto-Corner Configuration algorithm revised to handle "stepped" walls.
                                  • Wall "Draw Tool" configured to retain most recent inputs from user. Parameters not shown in UI default to global settings.
                                  This sub. revision is actually fairly significant and worth upgrading to since it addresses a major flaw in the UI.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 0.7.6c - 06.05.2018
                                    • Added the option to toggle between standard stud sizes and custom (user defined width x depth) sizes with the "Walls" tab of the global settings.
                                    http://design.medeek.com/resources/images/wall_su95_800.jpg
                                    Note that within the wall edit menu the stud width and depth can be adjusted independently regardless of the standard stud size option being enabled.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Updated the vendor page to reflect all of the products listed within the plugin:
                                      404 - File or directory not found.
                                      (design.medeek.com)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 0.7.6d - 06.05.2018
                                        • Fixed a bug with the wall sheathing and cladding so that door openings are properly cut out even when the vertical offset parameter is negative.
                                        http://design.medeek.com/resources/images/wall_su96_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          This morning I am spending a little extra time on the auto-corner config module and the related module that checks for tee intersections. It has been brought to my attention that this area of the plugin is not as robust as it needs to be. I've already made a number of minor corrections and augmentations but if anyone has a particular case that is throwing an error or unexpected result please send that information along.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I need some feedback on another marketing strategy for the plugin. I'm thinking about creating a lite version Medeek Wall Plugin LT, this version would only have the 2D and 3D (no framing) mode available to it. The interior of the wall (framing, studs, headers etc...) would not be included in the LT version, nor would holdowns and any engineering or estimating features.
                                            The LT version may be more suitable for some designers who do not want to be bothered with the details of the construction and are only interested in the layout.
                                            The ability to insert windows and doors as well as all of the trim and casing options would still be available in the LT version.
                                            What would you suggest as the regular price for an LT version? Is there any interest in this direction?
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 79
                                            • 80
                                            • 12 / 80
