    Can´t install SkUp2017 Make
    5 Posts 3 Posters 974 Views 3 Watching
    • HornOxxH
      HornOxx
      Try to install SkUp2017 Make on a friend's computer. Somehow I constantly hang on this error message and I have no idea what I should do to complete the setup now - does any of you have an idea?
      (running Windows 8.1)
      never trust a skinny cook
      • jujuJ
        juju
        Does the install.log file mentioned in the last paragraph not shed any more light on this either?
        Also, I assume you did right-click > run as administrator when installing?
        • HornOxxH
          HornOxx
          thanks Juju for your answer - yes, as I´ve learned here 😄 I ran the setup as administrator.
          Unfortunately I can not grasp the logfile information and do not know what and how to do now...
          (I am extremely awkward and also a bit stupid with this entire windows update thing, which luckily runs perfectly and automatically on my own machines)
          • HornOxxH
            HornOxx
            Done !
            I have never experienced a computer of this age which had´nt had any updates so far - this thing is now - after a few hours - completely updated and everything runs fine
            Thanks Juju and Dave for your postmail 😄
              If installing SketchUp using "Run as administrator" doesn't work for you...
              You might need to manually install the files it's choking on in the error message...
              That is Microsoft.NET framework 4.5.2 or better [64 & 32 bit]
              Which should include C++ libs 14 ?
              Download it separately and install it...
              https://www.microsoft.com/net/download/dotnet-framework-runtime/net452
              Then retry installing SketchUp using "Run as administrator"...
