[Plugin] TIG.splitdonut
(c) TIG 2012
Script:
TIG-splitdonut.rbSplits 'donut' shaped faces made with followme etc into 'quads'
[four-sided faces].
Select some faces to process.
All other selected entities and any non-compliant faces are discarded.
Only those faces with an outer-loop and just one inner-loop which both have
the same number of vertices are processed.
Lines are then added between 'matching' vertices to divide the 'donut' face
into 'quads' [four-sided faces]...
Type into the Ruby Console: TIG.splitdonut
OR use Tools > Split Tools... submenu item.
It is one step undoable.Donations: by PayPal.com to info @ revitrev.org
Version:
1.0 20120218 First issue.
1.1 20120219 At the end all new Edges added are selected to let you use
Entity Info to set them soft/smooth or hidden etc as desired.
Error messages added if incorrect selection.
Now in Tools > Split Tools submenu
2.0 20160818 Now comes in the SplitTools RBZ. No longer available separately. -
Very helpful (e.g. for artisan proxy creation), thank you very much!
Interesting tool and thanks TIG. It only works on donut shapes however. Could it be improved so that it could work on non-circular shapes, too? Like an arch for instance.
Try this http://forums.sketchucation.com/viewtopic.php?p=386610#p386610TIG.splitsausage... -
Are these ultimately going to be grouped together on a toolbar?
Best,
Jason. -
Like this http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
TIG-splitTOOLStoolbar/menu combing all three related tools... -
Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=386601#p386601
At the end all new Edges added are selected to let you to use Entity Info to set them soft/smooth or hidden etc as desired.
Now in Tools > Split Tools submenu http://forums.sketchucation.com/viewtopic.php?p=386658#p386658 -
Exactly...Thanks TIG!
Where is the download-Button?
This tool was combined into SplitTools with other similar ones...
https://sketchucation.com/pluginstore?pln=TIG_splitTOOLS -
