[Plugin] TIG.splitdonut
11 Posts 6 Posters 13.8k Views
    Script:
    TIG-splitdonut.rb
    Splits 'donut' shaped faces made with followme etc into 'quads'
    [four-sided faces].
    Select some faces to process.
    All other selected entities and any non-compliant faces are discarded.
    Only those faces with an outer-loop and just one inner-loop which both have
    the same number of vertices are processed.
    Lines are then added between 'matching' vertices to divide the 'donut' face
    into 'quads' [four-sided faces]...
    Type into the Ruby Console: TIG.splitdonut
    OR use Tools > Split Tools... submenu item.
    It is one step undoable.
    Donations: by PayPal.com to info @ revitrev.org PayPalButton ###
    Version:
    1.0 20120218 First issue.
    1.1 20120219 At the end all new Edges added are selected to let you use
    Entity Info to set them soft/smooth or hidden etc as desired.
    Error messages added if incorrect selection.
    Now in Tools > Split Tools submenu
    2.0 20160818 Now comes in the SplitTools RBZ. No longer available separately.
    http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
      cotty
      Very helpful (e.g. for artisan proxy creation), thank you very much!
      my SketchUp gallery
        Interesting tool and thanks TIG. It only works on donut shapes however. Could it be improved so that it could work on non-circular shapes, too? Like an arch for instance.
          Try this http://forums.sketchucation.com/viewtopic.php?p=386610#p386610 TIG.splitsausage...
            jason_maranto
            Are these ultimately going to be grouped together on a toolbar?
            Best,
            Jason.
              Like this http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
              TIG-splitTOOLS toolbar/menu combing all three related tools...
                Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=386601#p386601
                At the end all new Edges added are selected to let you to use Entity Info to set them soft/smooth or hidden etc as desired.
                Now in Tools > Split Tools submenu http://forums.sketchucation.com/viewtopic.php?p=386658#p386658
                  d12dozr
                  Exactly...Thanks TIG! 😄
                  http://goo.gl/f7ooYh
                    Drachenbauer
                    Where is the download-Button?
                      This tool was combined into SplitTools with other similar ones...
                      https://sketchucation.com/pluginstore?pln=TIG_splitTOOLS
