    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • FrederikF
      Frederik
      @medeek said:
      Just remember it is just me programming this thing, I don't have a whole team of professional programmers working behind the scenes, creating the magic.
      Yes, I'm fully aware which makes this even more impressive... πŸ‘
      Cheers
      Kim Frederik
      • medeekM
        medeek
        A preview of the Wall Move Tool:
        View Model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        The primary items left to do before the release are:
        • Interior Walls
        • Global Settings (update)
        • Web Page (update)
        I will start on interior walls tomorrow.
        I also have some additional testing to do with the no framing option to make sure it is working seamlessly with the other modes (2D and 3D).
        http://design.medeek.com/resources/images/wall_su70_800.jpg
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • Bob JamesB
          Bob James
          Nathaniel,
          Looking Good!
          Will the door tool handle double doors (i.e. a house entry composed of two separate doors.)?
          And closet sliding doors?
          • medeekM
            medeek
            @bob james said:
            Nathaniel,
            Looking Good!
            Right now the door types are limited but yes I plan on adding all the various door types:
            • sliding
            • pocket
            • bifold
              etc...
            In that regard I am also very interested in working with other plugin authors to somehow integrate other door and window plugins so that they can work seamlessly with the wall plugin. In order for this to work correctly I will need to setup a simple system that sends a signal to the third party window/door plugin letting it know if the opening size or location has changed that way the windows and doors will stay synchronized with the wall model and automatically move with it.
            design.medeek.com
            • medeekM
              medeek
              As I'm working on interior walls today it occurred to me that just as I've provided for a trim option with exterior walls I also need to provide an interior trim option for both interior (int-int) walls and exterior walls (int-ext).
              I've added in one extra option in the advanced wall options to toggle interior trim. I will probably not full flesh this out until after the plugin release but interior trim will probably deal with the following key elements/options:
              • Baseboard
              • Crown Molding
              • Chair Rail
              • Wainscot
              http://xboxhut.com/wp-content/uploads/2016/06/craftsman-house-interior-trim-scandinavian-compact.jpg
              design.medeek.com
              • jujuJ
                juju
                Nathaniel, I don't know if you should be putting those finishing trims in the plugin. So many variables and options, probably better if those were left to the designer to dictate / complete as per their design wishes?
                • medeekM
                  medeek
                  You can always turn the option off and in the global settings you can always make it default to off so the preference of the designer is respected.
                  However, for those who just want a simple representation for the interior trim the option will exist at some point.
                  design.medeek.com
                  • pbacotP
                    This is looking like a good solutions in a few ways. While you may keep adding alternate details and flexibility, this at least bring SU up to a lot of residential modeling for quick representation of basic contemporary homes, for example for remodels. I might not find it has enough options to work on most jobs I work on, but I might find it good for a quick model that will satisfy less sophisticated jobs and give that instant feel people now are half expecting due to the home remodel shows on TV (for better or worse). On the other hand the overall work is more important to builders to get to the framing and other take-offs, something I don't get involved in fortunately.
                    I like the work with the 2d plan, which updates the model. Refreshing!
                    • medeekM
                      medeek
                      You are just going to have to try it out and see if it works for you.
                      My intent is to make it well suited for most typical conventional homes (residential work) being built today in the US and Canada. I am also providing metric on everything so it should work as well for the Europeans and Aussies and other international designers.
                      Adding more flexibility and options also adds to the complexity, I am trying to strike some sort of balance there but as you can probably already tell I do like to dive into the details with just about everything.
                      In addition to the 2D mode, after speaking with a couple of other designers, I think I'm also going to add an additional global setting called: "2D Layout in 3D"
                      If the user toggles this to "ON" then the 2D representations for the windows and doors will be drawn on the top surface of the wall plate, the door swing(s) will be shown at the wall bottom and the text callouts will also be drawn at the wall bottom. The idea being that you can view the 3D model from the top down and still see the plan layout.
                      design.medeek.com
                      • medeekM
                        medeek
                        Interior Walls:
                        http://design.medeek.com/resources/images/wall_su71_800.jpg
                        A couple of items on today's todo list with regards to interior walls:
                        • The wall move tool decouples interior wall corners from exterior wall corners, this is intended.
                        • I still need to add in an algorithm which can sense when an interior wall is Teeing into an ext. or int. wall. This is important primarily for the move tool and wall creation tool.
                        • Update interior door casing
                        • Interior windows (windows that are embedded in an interior wall) are not very common, not sure exactly what to do in this case. Perhaps just treat as regular window installed in an exterior wall.
                        • Interior framed openings (without installation of door or window): These need to be wrapped in gypsum to properly finish them out.
                        • Added interior trim (baseboard, crown molding, chair rail, wainscoting) to the long term todo list.
                        That should be it for now. I may be able to get all this done today if I really hustle and then on to the global settings tomorrow.
                        design.medeek.com
                        • medeekM
                          medeek
                          Window and Door callouts with the "2D Layout in 3D" option turned on.
                          Notice that I have parallel projection turned on in SketchUp.
                          I apologize for the strange coloration and quality of the image, I'm trying out some new software for taking screen grabs and turning them into animated GIFs.
                          design.medeek.com
                          • C
                            Charlie__V
                            Nathaniel,
                            Been following your progress with great interest, your plug-in is really looking good now!
                            Anxious to try it out, when ready of course. (No pressure)
                            Best regards,
                            Charlie
                              alpro
                              @charlie__v said:
                              Nathaniel,
                              Best regards,
                              Charlie
                              Me too, looks like a very robust plugin. My question is will there be some kind of library that we could add our own window/door and trim styles to ? Would make it a much more useful tool to me as I have tons of Pella and Anderson speced windows already with quite a bit of modeling time invested.
                              • medeekM
                                medeek
                                I've been giving this some more thought and I like the idea of designers being able to bring in their own pre-built components (dynamic or not) into the model via the plugin.
                                Do you have an example window/door that I can examine and figure out the best way to create the ability to bring in such a pre-configured component.
                                The plugin allows one to set the size and location of an opening and to adjust this at any time. The user would then need to select from their library of pre-configured windows/doors to select the correctly sized component and then it would be inserted automatically into the model at a specific insertion point.
                                I guess the big question for me is where should this insertion point be located for a window or a door? Top center, bottom center and also how should it be centered within the wall depth?
                                design.medeek.com
                                • jujuJ
                                  juju
                                  SU normally uses the the origin of the model that is being brought in as the reference, now this may differ depending on how the external model was made and positioned.
                                  Personally, I prefer bringing windows in at the centre (left / right) of the head (top), doors at the centre (left / right) of the threshold (bottom).
                                  Some kind of picker may be advisable, ie. top: left / centre / right (and the same for middle and bottom). I'm not sure what kind of gymnastics this may cause in coding though...
                                  • Bob JamesB
                                    Bob James
                                    For what it's worth, I use the top/left
                                      db11
                                      I use top centre, though bottom centre works fine for doors. If you want more flexibility you could do it like Profile Builder with a selectable set point.
                                      Ideally there would be an offset variable for the setback from the exterior sheathing. (For flanged windows the default value would then be '0'). In our case (Passivhaus) we centre the window in the middle of the insulating thickness, so the setback from the exterior can be as much as 8".
                                      A saved variable with a default allows any scenario to be covered.
                                      • medeekM
                                        medeek
                                        Per input from various designers I am steering towards top center for windows and bottom center for doors. The insertion point of the window/door component (at origin of SKP file) will be inline with the outside framing by default but then can be adjusted by an inset variable (neg. or pos.) I will create a sub-folder within the plugin called "library" where the designer can place all of their pre-configured SKP files, so the plugin can access them. The plugin will then allow one to select any one of these files to place into an opening.
                                        If there are additional requests I can also make the insertion point fully customizable within the global settings:
                                        • Top Center
                                        • Top Left
                                        • Top Right
                                        • Middle Center
                                        • Middle Left
                                        • Middle Right
                                        • Bottom Center
                                        • Bottom Left
                                        • Bottom Right
                                        design.medeek.com
                                        • pbacotP
                                          I would vote for entering a given head height for the windows, so every window goes in at this height automatically unless the designer opted for another for special windows.
                                            MtnArch
                                            I agree with pbacot. I use Chuck Vali's excellent Instant Architecture plug-in but cannot get used to first adding a line across the wall(s) for the head height before I start the plug-in to insert the windows/doors. To Chuck it makes sense, but for me it's an extra step (or two, or three, or ...) that I don't want to do.
                                            Highest Regards,
                                            Alan T. Hendry, RA
                                            Architect
                                            • 80
                                            • 81
                                            • 8 / 81
