    Medeek Wall Plugin
    1.5k Posts 29 Posters 1.3m Views 28 Watching
    • jujuJ Offline
      juju
      Nathaniel, I don't know if you should be putting those finishing trims in the plugin. So many variables and options, probably better if those were left to the designer to dictate / complete as per their design wishes?
      • medeekM Offline
        medeek
        You can always turn the option off and in the global settings you can always make it default to off so the preference of the designer is respected.
        However, for those who just want a simple representation for the interior trim the option will exist at some point.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • pbacotP Offline
          This is looking like a good solutions in a few ways. While you may keep adding alternate details and flexibility, this at least bring SU up to a lot of residential modeling for quick representation of basic contemporary homes, for example for remodels. I might not find it has enough options to work on most jobs I work on, but I might find it good for a quick model that will satisfy less sophisticated jobs and give that instant feel people now are half expecting due to the home remodel shows on TV (for better or worse). On the other hand the overall work is more important to builders to get to the framing and other take-offs, something I don't get involved in fortunately.
          I like the work with the 2d plan, which updates the model. Refreshing!
          • medeekM Offline
            medeek
            You are just going to have to try it out and see if it works for you.
            My intent is to make it well suited for most typical conventional homes (residential work) being built today in the US and Canada. I am also providing metric on everything so it should work as well for the Europeans and Aussies and other international designers.
            Adding more flexibility and options also adds to the complexity, I am trying to strike some sort of balance there but as you can probably already tell I do like to dive into the details with just about everything.
            In addition to the 2D mode, after speaking with a couple of other designers, I think I'm also going to add an additional global setting called: "2D Layout in 3D"
            If the user toggles this to "ON" then the 2D representations for the windows and doors will be drawn on the top surface of the wall plate, the door swing(s) will be shown at the wall bottom and the text callouts will also be drawn at the wall bottom. The idea being that you can view the 3D model from the top down and still see the plan layout.
            design.medeek.com
            • medeekM Offline
              medeek
              Interior Walls:
              http://design.medeek.com/resources/images/wall_su71_800.jpg
              A couple of items on today's todo list with regards to interior walls:
              • The wall move tool decouples interior wall corners from exterior wall corners, this is intended.
              • I still need to add in an algorithm which can sense when an interior wall is Teeing into an ext. or int. wall. This is important primarily for the move tool and wall creation tool.
              • Update interior door casing
              • Interior windows (windows that are embedded in an interior wall) are not very common, not sure exactly what to do in this case. Perhaps just treat as regular window installed in an exterior wall.
              • Interior framed openings (without installation of door or window): These need to be wrapped in gypsum to properly finish them out.
              • Added interior trim (baseboard, crown molding, chair rail, wainscoting) to the long term todo list.
              That should be it for now. I may be able to get all this done today if I really hustle and then on to the global settings tomorrow.
              design.medeek.com
              • medeekM Offline
                medeek
                Window and Door callouts with the "2D Layout in 3D" option turned on.
                Notice that I have parallel projection turned on in SketchUp.
                I apologize for the strange coloration and quality of the image, I'm trying out some new software for taking screen grabs and turning them into animated GIFs.
                design.medeek.com
                  Charlie__V
                  Nathaniel,
                  Been following your progress with great interest, your plug-in is really looking good now!
                  Anxious to try it out, when ready of course. (No pressure)
                  Best regards,
                  Charlie
                    alpro
                    @charlie__v said:
                    Nathaniel,
                    Best regards,
                    Charlie
                    Me too, looks like a very robust plugin. My question is will there be some kind of library that we could add our own window/door and trim styles to ? Would make it a much more useful tool to me as I have tons of Pella and Anderson speced windows already with quite a bit of modeling time invested.
                    • medeekM Offline
                      medeek
                      I've been giving this some more thought and I like the idea of designers being able to bring in their own pre-built components (dynamic or not) into the model via the plugin.
                      Do you have an example window/door that I can examine and figure out the best way to create the ability to bring in such a pre-configured component.
                      The plugin allows one to set the size and location of an opening and to adjust this at any time. The user would then need to select from their library of pre-configured windows/doors to select the correctly sized component and then it would be inserted automatically into the model at a specific insertion point.
                      I guess the big question for me is where should this insertion point be located for a window or a door? Top center, bottom center and also how should it be centered within the wall depth?
                      design.medeek.com
                      • jujuJ Offline
                        juju
                        SU normally uses the the origin of the model that is being brought in as the reference, now this may differ depending on how the external model was made and positioned.
                        Personally, I prefer bringing windows in at the centre (left / right) of the head (top), doors at the centre (left / right) of the threshold (bottom).
                        Some kind of picker may be advisable, ie. top: left / centre / right (and the same for middle and bottom). I'm not sure what kind of gymnastics this may cause in coding though...
                        • Bob JamesB Offline
                          Bob James
                          For what it's worth, I use the top/left
                            db11
                            I use top centre, though bottom centre works fine for doors. If you want more flexibility you could do it like Profile Builder with a selectable set point.
                            Ideally there would be an offset variable for the setback from the exterior sheathing. (For flanged windows the default value would then be '0'). In our case (Passivhaus) we centre the window in the middle of the insulating thickness, so the setback from the exterior can be as much as 8".
                            A saved variable with a default allows any scenario to be covered.
                            • medeekM Offline
                              medeek
                              Per input from various designers I am steering towards top center for windows and bottom center for doors. The insertion point of the window/door component (at origin of SKP file) will be inline with the outside framing by default but then can be adjusted by an inset variable (neg. or pos.) I will create a sub-folder within the plugin called "library" where the designer can place all of their pre-configured SKP files, so the plugin can access them. The plugin will then allow one to select any one of these files to place into an opening.
                              If there are additional requests I can also make the insertion point fully customizable within the global settings:
                              • Top Center
                              • Top Left
                              • Top Right
                              • Middle Center
                              • Middle Left
                              • Middle Right
                              • Bottom Center
                              • Bottom Left
                              • Bottom Right
                              design.medeek.com
                              • pbacotP Offline
                                I would vote for entering a given head height for the windows, so every window goes in at this height automatically unless the designer opted for another for special windows.
                                  MtnArch
                                  I agree with pbacot. I use Chuck Vali's excellent Instant Architecture plug-in but cannot get used to first adding a line across the wall(s) for the head height before I start the plug-in to insert the windows/doors. To Chuck it makes sense, but for me it's an extra step (or two, or three, or ...) that I don't want to do.
                                  Highest Regards,
                                  Alan T. Hendry, RA
                                  Architect
                                  • medeekM Offline
                                    medeek
                                    Straps, holdowns, anchor bolts, threaded rod and couple nuts are now part of the plugin. More details on that later. At some point the engineering module will be able to do the entire lateral calcs on a structure with the click of a button and input of a few site criteria parameters. The idea is to fully automate the engineering of a residential structure, engineers shouldn't have to work this hard.
                                    http://design.medeek.com/resources/images/wall_su74_800.jpg
                                    http://design.medeek.com/resources/images/wall_su72_800.jpg
                                    Tomorrow I will wrap up the global settings and we will release the plugin for beta testing.
                                    I still have quite a bit more stability testing to make sure I have missed any glaring errors but I'm sure the beta testers will help sniff out a lot of those issues.
                                    design.medeek.com
                                      Bob James
                                      Agree
                                      Super!
                                      • pbacotP Offline
                                        I don't know how the application would work--when you set this height. It could be that when you begin using the tool it remembers last time you worked,it was 8', or this must be set in each model, each drawing session, or what. But the outcome would be a constraint, so if you insert a window in 2d or 3d, it knows how high it is.
                                        If you are allowing custom components to be used, I suppose that means the axis / insertion point location is significant, and needs to be at the head for windows, at the base for doors.
                                        • medeekM Offline
                                          medeek
                                          I've now enabled the "Install Mode" parameter which allows the user to use the "Builtin" window generator/plugin or use one of their own pre-configured windows stored within the "library" sub-folder of the plugin:
                                          http://design.medeek.com/resources/images/wall_su75_800.jpg
                                          Notice that the insertion point can be specified as well as locating within the wall depth by two parameters:
                                          1.) Window Location: ON SHEATHING or ON FRAMING, this parameter will offset the location of the window within the wall by the sheathing thickness automatically or place it inline with the wall framing.
                                          2.) The window location within the wall can be further modified/customized by adjusting the outset with either a positive or negative value.
                                          One thing to note is that the framed opening has no idea what the dimensions of the window or door are, the user must provided the correct width and height for the installed window. Also note that callout at the base of the wall does not include any specifics on the window installed when in library mode since it does not know whether the window is a picture, single hung, casement etc...
                                          Since this particular library file already has the proper trim and casing as part of the component I have turned off these advanced features for this opening. If it did not I could alternatively enable both the trim and/or casing within the plugin even though the plugin is not actually drawing the window itself (it is bringing in a third party component instead).
                                          The plugin will automatically populate the library dropdown with any valid SketchUp files found within the sub-folder "library/windows/".
                                          I am now working on the door modules to extend this functionality for doors.
                                          I am also interested in working with other plugin authors so that I can establish an API which will allow the wall plugin to talk to their window/door plugin and automatically pass parameters back and forth so that opening location and size can properly sync with a third party plugin.
                                          You might also notice that there are two dots shown on the top plate at each end of the wall in this model. This gives the user indication that holdowns are installed in this wall panel at these locations. In 2D mode these indicators will also be shown even though no hardware is drawn.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Working on updating the global settings to reflect the myriad of settings added to the plugin in the last month.
                                            This is what you will see when you pull up the license tab with a fully licensed plugin:
                                            http://design.medeek.com/resources/images/wall_su76_800.jpg
                                            Notice that there are twelve tabs:
                                            • General (complete)
                                            • Layers (complete)
                                            • Materials
                                            • Sheathing
                                            • Walls
                                            • Doors
                                            • Windows
                                            • Wall Corners (complete)
                                            • Trim
                                            • Insulation
                                            • Holdowns (complete)
                                            • License (complete)
                                            The window and door tabs will have the largest amount of options. Updating all of these html pages is rather tedious work but it is necessary.
                                            design.medeek.com
                                            • 77
                                            • 78
                                            • 8 / 78
