    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 461.3k Views 109 Watching
    • W
      wingedhippo
      Hello, I understand that Floor Generator is no longer being developed, but I would like to ask how to override or turn off "clapboard pattern can only be placed on a vertical face"? I have a model that is created from rotated and/or scaled components to save building time, so while the faces are "vertical" in appearance they may not be according to Sketchup axis... Even when exploding I still get this error (blue axis is up)...
      • Z
        Zin Min Tun
        Thanks you SDM.But I cannot download it.
        • E
          Einstein
          Hi! I think I had the same problem as c3dx and gizeh33 - nothing happened when I clicked the toolbar button. Now I downloaded the latest version from http://sdmitch.blogspot.com/ and it's working. Please update the newest version into Plugin Store if you can.
          • sdmitchS
            sdmitch
            The plugin store and blog versions are the same.
            • T
              TraxXx
              Hi Sam !
              Thanks for the wonderful plugin first of all, that's really helpful ! I have two questions concerning the wood pattern, would it be possible to make continuous wood planks without any cuts ? I tried to increase the lenght value so it's higher than the maximum height of my volume to cover with planks but I'm still getting cuts.
              I'm actually working on a house project extension. The original house has single lenghts planks going from floor to roof with three differents width of 7, 13 and 20 cm. Yet, your plugin seems to be the most appropriate to complete this task regarding the fact that I need the same spacing between the planks. But i'm looking for a way to lay planks of these precise widths, randomly against my volume. Your plugin is creating random width which provides me with a close result but not what I meant to do. I hope I'm being clear in my explanation...
              I guess there must be a way to achieve that with maybe several plugins, but couldn't find the way. I also tried creating these 3 different planks as components and spray them along line with compospray, but this one doesn't allow me to control the spacing and doesn't adjust the planks top to my shape as your plugin does... Each plugin shows limits for this task and I'm afraid my request is a bit too difficult to solve... But still I'm asking in case of I can avoid making planks one by one πŸ˜„
              Hope you can help πŸ˜„ Thanks !
              Wood planks created against a not parallel shape
              • sdmitchS
                sdmitch
                One should never say never but modifying FloorGenerator to allow multiple wood widths is as close as you can get. Sorry but I just don't see it happening.
                • T
                  TraxXx
                  At least I tried ! πŸ˜„ And what about the gaps ? Can I avoid them to happen on the planks smallest sides ? Like continuous planks from floor to roof ? Or does it have to be necessarily linked to the longest sides gaps value ?
                  • sdmitchS
                    sdmitch
                    Yes, the gap is the same on all sides.
                      awei711
                      it's good, thanks!
                      • K
                        Kuzmic
                        The Rand Tex Material Picker isn't letting me select materials from a folder or the model.
                        • sdmitchS
                          sdmitch
                          Operator error obviously.
                          • C
                            CreaVivaCity
                            Why, I can't load plugin in SU 2018 (Unrestricted)
                            Can Anyone help me?
                            • jenujacobJ
                              jenujacob
                              this saved my backside today! thanks Sdmitch!
                              • F
                                filipeoconde
                                Firstly, thanks a lot sdmitch! Excellent plugin!
                                I'd like to suggest a feature - or maybe ask for help if I'm not using it properly!
                                When using a material with a bump image (in V-Ray), the FlrGen tends to rotate the texture but not its bump. Is it right? Should I've been doing something different?
                                Thanks a lot,
                                filipeoconde.
                                • jujuJ
                                  juju
                                  Thanks a lot,
                                  filipeoconde.
                                  I may be wrong, but as far as I know SU only handles a single texture per surface. If you have bump maps linked to a texture, that is normally handled by the rendering software you use, in which case the problem probably isn't with FloorGenerator, or SU for that matter, but rather with your rendering software?
                                    dimashariyanto
                                    where i can download this plugin? i have been download from the site http://sdmitch.blogspot.com/ but wan't work.. thanks
                                    • sdmitchS
                                      sdmitch
                                      I have removed the plugin from the blog and plugin store because I have received a complaint regarding Copyright infringement.
                                      • Q
                                        qishta
                                        Thanks a lot sdmitch, the plugin seems to be very powerful!! but how could we get it.
                                        • utilerU
                                          utiler
                                          Really, copyright infringement??? I don't know of any other plugin that does this, Sam... that's disappointing that you have to do this.
                                          Where has the complaint come from??
                                          Just Curious...
                                          • sdmitchS
                                            sdmitch
                                            Apparently from Trimble and I still have no idea why or what the complaint is about.
