    SU changes my Color material from ALL SAME to by material!!
    14 Posts 4 Posters 1.8k Views 4 Watching
    • C
      cleatus269
      ok, here is the model prior to saving... the questions you guys have asked me were in other forum topics and have not worked for me.
      it doesnt have to do with my style setting not being saved... as you see from the pics, everything is updated and saved correctly prior to saving and then upon hitting "save" it changes the color to by material and then the circled greyed arrows appear on the style thumbnail... so i change the color back to all same and the arrows go away.. so theres nothing to "update" or save...
      COMPLETELY INFURIATING!!
      thank you for your continued support
      correct settings prior to saving
      incorrect setting after saving
      • JQLJ
        JQL
        It seems like a bug but it would help if you'd share the model or a part of it.
        However you shouldn't be too worried about it as the wrong style is not being saved. The "incorrect setting after saving" seems to not be saved and so if you change scenes it should return to normal and in Layout too.
        It is annoying though.
        www.casca.pt
        Visit us on facebook!
        • C
          cleatus269
          i agree it seems like a bug. i have shut down my computer, updated SU and deleted some plugins without success... not to keen on sharing my model at this time. are there particular plugins that could cause this???
          TIA
          • JQLJ
            JQL
            If it seems like abug submit it Trimble.
            I also think there's probably something else.
            www.casca.pt
            • C
              cleatus269
              STILL dealing with this over a YEAR later!! PLEASE HELP!!!
                Are you still using SketchUp 2016 as your profile indicates?
                • C
                  cleatus269
                  2017 now. but still doing the problem. i have deleted almost ALL of my plug-ins too...
                    Perhaps you could update your profile.
                    Can you share a SketchUp file that exhibits this problem? Keep in mind that Sketchup 2017 isn't likely to get any updates at this stage.
                    • C
                      cleatus269
                      Ok, so i JUST tried it to upload an example and its not doing it anymore!! I guess when i removed ALL of my plug-ins that must have fixed it.
                      But now i dont have the tools that im used to using.
                      all my examples are too large to upload.
                      but thanks for the help
                        I'm sure that the culprit wasn't ALL of the plugins/extensions you had installed. Put some of them back and see what happens. Keep putting them back until you get to where it happens again. That should give you an idea of which one is at fault.
