    FlexTools Updates
    Scheduled Pinned Locked Moved FlexTools
    renderpluginsextensions
    168 Posts 17 Posters 346.6k Views 17 Watching
    • jujuJ
      juju
      The DC's work with Face Cutter ($3.99) as well.
      • halroachH
        halroach
        @juju said:
        To my knowledge, the component position w.r.t. the origin determines how the component is placed, not sure if this is true for DC's as well.
        I understand now what you mean. There are two situations to consider:
        1. When a component is placed into a model
        2. A copy paste situation.
        In the first situation, yes, components are placed according to their main Axis, which in the Flex DCs is the bottom left corner. I could theoretically design them to change the main axis, but it would probably add a lot of calculations that would give them a slower refresh time. We don't want that!
        Also, thanks to SketchUp's super duper inferencing, selecting, moving, re-positioning one or a bunch of windows is really quite quick. I wouldn't want to mess up the code for something that is really easy to do in Sketchup.
        1. In copy paste situations, in most cases the placement is from the bottom left corner, no matter where the component axis is located. So we're keeping the experience quite consistent this way.
        FlexTools - Super Quick Windows, Doors, Slats...
        • halroachH
          halroach
          @juju said:
          The DC's work with [url=http://extensions.sketchup.com/en/content/face-cutter]Face Cutter[/url] ($3.99) as well.
          Good to know! 😄 👍
          Hmmmm, 😕
          Just tried it out - seems a bit buggy when copying and pasting components around.
          If you pull in new components straight from the toolbar it's fine.
          • halroachH
            halroach
            @rv1974 said:
            My $0.02: you should add a corner L shaped aluminum panel. The example shown in video is not quite right.
            Not all panel configurations use an L shaped corner - Like the red paneling in this Alucobond example:
            Though I do agree that L shaped corners would be a nice addition to FlexPanel! 😉
            FlexPanel can be used for all sorts of other repetitive paneling situations like: floors, interior walls, even basic cabinetry situations where you don't want to start messing with a real cabinet components.
            Still working on it... 😎
            • jujuJ
              juju
              @halroach said:
              Good to know! 😄 👍
              Hmmmm, 😕
              I didn't try that initially, but have now. When doing a CTRL+C & CTRL+V it seems to work fine with the louvres (which have no cills), the windows work depends on where the insert point / position is (cills are a problem) and the door seems to go completely awry.
              When doing a shift + move (which equates to copy and move with the native tools) it works on my end.
              • halroachH
                halroach
                Components Update!
                Thanks to your input, we found an issue with the face-cutter versions of all 4 Flex components. The components in this update fix the issue. After updating, you will be able to set the wall thickness independently. (It is not affected by the frame depth, or by the inset settings anymore).
                Important Note
                In the favorites manager - Only the 'Original' components are updated. Previously saved favorites remain untouched in their current versions.
                How to get the update
                An automatic update is available from within the plugin!
                1. Open the FlexTools manager (cog icon)
                2. Click on the red [highlight=#ff4040:1qwtzgchUpdate[/highlight:1qwtzgch]] button at the top of the window.
                3. A restart of Sketchup may be required.
                The updated Flex Component versions:
                FlexDoor 1.3.25
                FlexWindow 2.5.36
                FlexTrapez 1.1.53
                FlexSlat 1.2.06
                Want to make sure you have the latest versions?
                Click on each component's settings icon in the components manager
                • halroachH
                  halroach
                  Existing customers! One day left to get 30% Off all FlexTools products.
                  (Details will arrive by email).
                  • halroachH
                    halroach
                    FlexPanel is finally here!
                    You can now create all sorts of orthogonal panels, cladding, tiles, walls, floors, ceilings… in just a few clicks!
                    And as usual with Flex components with Responsive Scaling, the panels fit exactly where you need them.
                    • Full control over panel thickness, spacing and distributions.
                    • Set the number of panels to be equally distributed, or set a fixed size, and let FlexPanel complete the remainders.
                    • Choose between 6 edge extensions, for when you want to align a few panel systems - side by side, or around a corner.
                    • Cutter version, for when you want to embed panels to be flush with the face they are placed on.
                    Click to see animation
                    How to get FlexPanel?
                    Check out FlexTools
                    If you already have FlexPack 2017 installed, you can start using it now! All you need to do, is to open the FlexTools Manager and click on the red update button.
                    Happy Flexing! 😉
                    • Daria C137D
                      Daria C137
                      https://flextools.cc/wp-content/uploads/2018/01/open_02_64.png
                      Open / Close multiple FlexDoors at once
                      https://flextools.cc/wp-content/uploads/2018/01/flextools-open-close_02-01e.gif
                      1. Make a selection.
                      2. Run the Open/Close tool - any FlexDoors included in the selection will either open or close.
                      If there are more 'open doors' than 'closed doors' in the selection, all the doors will be closed.
                      FlexTools.cc - Parametric 3D modeling for busy architects
                      • Daria C137D
                        Daria C137
                        The entire UI of the plugin and all the components and tools, can be displayed in different languages.
                        Currently FlexTools for SketchUp can be used in:
                        ⭐️English ⭐️Spanish ⭐️French ⭐️Portuguese ⭐️Traditional Chinese and ⭐️Simplified Chinese!
                        We are very proud of our translation system, since it also works retroactively!
                        All Flex components previously used, and saved in the Favorites Library will also be automatically translated.
                        https://flextools.cc/wp-content/uploads/2018/04/FlexTools-in-6-languages_01_01e.gif
                        Special thanks to those who contributed their precious time and expertise:
                        • Rafael Teresa - Spanish version
                        • Pilou - French version
                        • Rebeca Rabia - Portuguese version
                        • Charles Tom - Traditional Chinese version
                        • Shaun 肖万涛 (1462232@qq.com) - Simplified Chinese version
                        If you wish to contribute a translation in your own language, please contact us: https://flextools.cc/contact/#WriteUs
                        • halroachH
                          halroach
                          We just launched a beta version of ComponentFinder. Hooray!
                          Looking for people to help us test and improve it.
                          Be part of it! --> https://flextools.cc/componentfinder-beta/
                          And yes, it’s FREE!
                          • jujuJ
                            juju
                            Yoni, any chance we can get an option with the doors to have the door swing also show when the doors are closed? I keep on configuring the door and explode the component, rotate the door to the closed position and draw a missing line (door leaf in open position).
                            • halroachH
                              halroach
                              Hi Juju,
                              I imagine you need this for presenting plans? Can you post an image or a model of what the end product should look like? I think I understand, but just to make sure.
                              • jujuJ
                                juju
                                That would be correct, needed when creating construction documentation. When using parallel projection with section cut (I use Skalp) the doors appear correct on plan, and the elevations as well with my work-around.
                                The doors would normally appear correct on plan in the current open setting, however on parallel projection elevation one would want these closed, but when you close the doors to get the elevations looking correct you lose the door swing representation in plan again.
                                Also the current method I'm using isn't ideal because I need to spend a little extra time per door to do this, plus I lose the dynamic component / interactive part thereof since I'm exploding it and manually rotating to the closed position. I suppose I could just copy / paste the swing and draw the extra line representing the door in the open position, but if it could be done automatically it would be a great help.
                                I can imagine there may be times when you would not want the door swing representations, thus if it could be an optional on/off for this it'd be great. Of course if one could customize / name the layer where you would this 2D swing / open door representation to be placed (as well as the glazing & framing) it would be the ultimate, but this will probably remain a pipe dream for now. But hey, it never hurts to ask / put it out there.
                                current open position appearance
                                current closed position appearance
                                requested closed position appearance
                                • halroachH
                                  halroach
                                  Hey Juju,
                                  Please see the attached FlexDoor. It has an extra option under the 'Arc:' attribute called "Always ON". When you want to turn it off, you may need to open and close the door once to see the changes. It's not perfect, but it's way better than exploding! 😄
                                  flex_door_ft_1.6-arc always on option - Juju.skp
                                  Regarding layers: The arcs are on a separate layer called FlexDoor_Arc. You can always change it's name to what ever you want and then save the component to a folder in ComponentFinder (now officially released as part of FlexTools!).
                                  Hope this helps,
                                  • jujuJ
                                    juju
                                    @halroach said:
                                    Hey Juju,
                                    [attachment=0:12nekw82]<!-- ia0 -->flex_door_ft_1.6-arc always on option - Juju.skp<!-- ia0 -->[/attachment:12nekw82]
                                    Hope this helps,
                                    Hi Yoni, thanks for this. Will you be making this part of the sets that comes with your extension by default?
                                    • halroachH
                                      halroach
                                      Hey Juju,
                                      Sure, we'll do our best to add this feature in the next update, or the next after that...
                                      In the mean time you can add this component to any folder on your hard disk, and have quick access to it through ComponentFinder.
                                      If you want to change the default component that loads from the toolbar, you can replace the default door with this one. Make sure the new component has the same name => "flex_door_ft_1.skp". (Make a backup of the old one, just in case...)
                                      C:%ProgramData%\F3d_FlexTools\packages\components\flex_door_ft_1\component
                                      • halroachH
                                        halroach
                                        Big news! The following new additions that we are working on will be part of the new package called FlexPack Pro!
                                        • WallCutter
                                        • Slider Window
                                        • Double-Hung Window
                                        • Awning and Hopper Windows
                                        • Casement Window
                                        • ComponentFinder improvements
                                        Read more on our blog: https://flextools.cc/blog/flexpack-pro/
                                        • halroachH
                                          halroach
                                          The first update for FlexPack Pro:
                                          WallCutter is released, and it cuts through walls like never before! 😄 👍
                                          Check it out! >> https://flextools.cc/wallcutter
                                          • halroachH
                                            halroach
                                            A quick update:
                                            We released a few enhancements and important bug fixes for WallCutter and the Place Upright tool.
                                            Read more about the changes in the Change log: https://flextools.cc/change-log
                                            • 1 / 9
