    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • TIGT Online
      RBE files are readable by v2016 and newer.
      RBS files are readable by all versions.
      Both are encrypted RB files - RBE is the newer more secure format.
      Fredo actually provides RBE and RBS files in his subfolder, so earlier versions can load the appropriate files.
      So something is stopping your SketchUp from reading the RBE files.
      Typically it's an incorrect installation - but since you seem to have explored all avenues around this, without success, there must be something else...
      Lets consider some other ideas...
      I doubt if it's something in the installed SketchUp.exe that's at fault - rather the system is causing issues, or something 'tweaking' the system.
      So do you have anti-virus software installed that might be limiting/blocking/blacklisting v2016 ?
      Perhaps your Firewall is also being similarly awkward ?
      Are the SketchUp.exe file's Properties set up correctly ?
      e.g. in Compatibility - NOT set to always run as administrator, NOT running in compatibility mode,
      in Security - FULL control set for System and Admins, and Read/Execute for Users,
      etc...
      • fredo6F Offline
        @mgfranz
        Could you advise on your version of Setchup 2016.
        The good one should be 16.1.1449 (64 bits).
        • fredo6F Offline
          @mgfranz said:
          @fredo6 said:
          @mgfranz
          SketchUp Version 16.0.19912 64-bit
          That may be the reason. You run Sketchup release M0, which may have a problem with rbe files.
          So I suggest you upgrade to the latest version of SU2016 M1.
            mgfranz
            @fredo6 said:
            @mgfranz
            SketchUp Version 16.0.19912 64-bit, let me try to update.
            "If you like what you do, it will never be work..."
            In memory of Sam Maloof, 1916-2009
            • fredo6F Offline
              NEW RELEASE: LibFredo6 v8.1f - 19 Mar 18
              LibFredo6 8.1f is a maintenance release providing adjustments for Animator (performance for scaling) and TopoShaper (very high number of isocontours).
              • Z Offline
                Zatyra98
                interesting..
                  mgfranz
                  @fredo6 said:
                  @mgfranz said:
                  @fredo6 said:
                  @mgfranz
                  So I spent a decent number of hours this weekend doing the upgrade to v.1449. Doing uninstall using the Installer to uninstall my previous version, uninstalled all traces of any SU directory or plug-ins and ran a registry clean to remove all known traces of SU. Restarted system and did a fresh install as Admin, started SU, entered my serial info and downloaded Fredo6 v8.1 and Animator, installed using Windows>Preferences. Upon start of SU I received this;
                  Error Loading File C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                  Failed to read RBE/RBS file.
                  Error Loading File Fredo6_!LibFredo6.rb
                  Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                  C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                  C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_Animator.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                  C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                  C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Animator.rb:47:in module:Fredo6'
                  C:/Users/mgfranz/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_Animator.rb:26:in `<top (required)>'
                  I even tried starting SU as Admin, same error.
                  So I went back and uninstalled SU using the installer, cleaned out all directories again, and reinstalled as User, same plug-ins, same error on start. I'm quite confused as to where to go next.
                  • TIGT Online
                    @mgfranz
                    Despite all of your text you have never clearly said how you actually installed SketchUp...
                    Note:
                    Do not set the installed SketchUp.exe to always run as administrator.
                    Do not run SketchUp.exe as administrator.
                    Important:
                    SketchUp always needs to be correctly installed.
                    The only proper way to do this is as follows...
                    If it's already installed close SketchUp.
                    Find its installer exe file - probably in your Downloads folder ?
                    Select it, right-click > context-menu > "Run as administrator"
                    If it's already installed choose "Repair" when prompted.
                    Otherwise choose to "Install"...
                    This should set permissions etc properly.
                    Restart SketchUp and test...
                    If the problem persists try Uninstalling SketchUp, and deleting the related folders in:
                    *C:\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2018\SketchUp*
                    If you have any 'custom files' within subfolders like Materials, Components, Styles etc, then you might want to save them elsewhere, before doing the folder deletion.
                    You can move them back after doing the Install properly...
                      mgfranz
                      @tig said:
                      @mgfranz
                      Note:
                      Important:
                      No, I did, "Restarted system and did a fresh install as Admin,". I also said that I DID delete all related folders in AppData. I have done the install, uninstall, repair so many times I have it memorized.
                      And like I said previously, I can't run 2018 on this system due to the problem that started with 2017 regarding the lack of support for the Intel Graphics drivers, (which I do not understand), so 2016 is what it is, unless I want to buy a new laptop.
                      • TIGT Online
                        @mgfranz
                        Unfortunately your phraseology, "...[did] a fresh install as Admin...", is NOT entirely clear.
                        If you mean that you did it in the way that I outlined, using "Run as administrator", then please make it clear.
                        Installing it as a user who happens to be an 'admin', or even whilst logged-in as the administrator account, is not the same.
                        At the moment your text is not unambiguous...
                          mgfranz
                          @tig said:
                          @mgfranz
                          Yes, I did "Run as Administrator" for fresh install.
                          • TIGT Online
                            I know Fredo has an urgent call out to the SketchUp guys, about this very problem, which seems to be affecting just a few users, and where a proper installation etc fails to resolve these issues...
                            • fredo6F Offline
                              I got an answer from thomthom recommending to upgrade to the latest version of SU2016.
                                mgfranz
                                I'm already running SketchUpPro-2016-1-1449-80430-en-x64.exe, any other ideas?
                                • itcamposI Offline
                                  itcampos
                                  Don't know why, but this version just won't work, same error encountered by @mgfranz =\ Only difference is that I'm using SU2017.
                                  I had to uninstall and reinstall an older version (8.0c, which is the only one not too old I could find).
                                  Would anybody provide a link with the 8.1c ~ 8.1f versions so I can run a few tests?
                                  Thx!
                                  • TIGT Online
                                    Have you installed or repaired your SketchUp by selecting the installer exe file's icon, and
                                    right-click > Run as administrator ?
                                    • itcamposI Offline
                                      itcampos
                                      Yes, I uninstalled and deleted every folder from SU2017, then reinstalled as admin (which I know I already did in the first time), but the problem persisted. So far, the only solution I found was using the 8.0c and pray the next release works for me
                                        mgfranz
                                        Thx!
                                        Where did you find a version 8.0c?
                                        • itcamposI Offline
                                          itcampos
                                          Thx!
                                          I took me a while, I thought it would be faster to upload it than find it again, so there you go: https://mega.nz/#!k9sHjZaY!EzgYiDAO-1mfHwFd1gpn9ljszYBvgaimWT7rVs3NTcY
                                          • fredo6F Offline
                                            NEW RELEASE: LibFredo6 v8.1h - 06 Apr 18
                                            LibFredo6 8.1h is a maintenance release fixing a bug in Scaling flat shapes in Animator.
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 109
                                            • 110
                                            • 58 / 110
