    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 323.1k Views 57 Watching
    • fredo6F Offline
      @littleche said:
      Thanks for your video fredo . but your video is not my issue .
      please select all edges and run "smooth contours " . Certainly i can select only A Points Too but My issue is "smooth by section" in "smooth contours "tool Does not work .
      [attachment=0:29goc5iu]<!-- ia0 -->233.png<!-- ia0 -->[/attachment:29goc5iu]
      That's why I was saying.
      To prevent a corner to smooth, you need to put 2 collinear vertices on each side (i.e. vertices in the middle of each segment). Otherwise there is no way that Curvizard knows you don't want to smooth them.
        littleche
        Ok ! its solved With Your hint to "put 2 collinear vertices on each side " .
        Thank You Fredo . Your plugins is excellent .
          Ahmed0007
          Watch This!
          https://www.youtube.com/watch?v=1OV_YF6jsQA
          • fredo6F Offline
            @ahmed0007 said:
            Watch This!
            Thanks. Good tutorial video. I noticed that TutorialUp makes very didactic videos, going into some details and some usage that I did not think of myself.
            In the case of this video on Curvizard, I think what may be missing is the interactive approach of Curvizard, that is the point-and-click capability to operate transformations (as opposed to pre-selection)
              CassieFlo
              I've downloaded this plugin using the SCF Plugin Store (and restarted Sketchup right after) and have LibFredo6 8.1. However I keep getting a message that pops up saying that I have to install LibFredo6 v6.9 or higher to run curvizard...any thoughts on what is going on or how I can get this plugin working?
              Thanks in advance!
              Cassie
                Assuming you have download both the latest LibFredo and installed it, and also the the latest version of Curvizard...
                and you have restarted SketchUp completely...
                Then that error is indeed strange.
                You profile says: you have a MAC using SketchUp Pro - pre-v6 !
                Can you correct it and advise us on your current configuration...
                Help us to help you...
                  CassieFlo
                  I have indeed installed both latest versions and restarted SU completely multiple times.
                  And oops! I am not sure why that was listed as such, I am using SU 2018.
                  • fredo6F Offline
                    Cassie,
                    I just published an update to Curvizard (v2.1a), as I realized the published version was quite old (2015).
                    Can you tell me if you still get an error.
                    • fredo6F Offline
                      NEW RELEASE: Curvizard v2.1a - 28 Mar 18
                      Curvizard 2.1a is a maintenance release to keep the plugin on par with latest LibFredo6 versions. So upgrade is strongly suggested[/b][/color][/size].
                      Requirement: LibFredo6 8.1 or above
                      See main post of this thread for Download of Curvizard.
                        CassieFlo
                        Fredo-
                        Yes! That worked, thank you so much!
                          bambutec
                          Hi Fredo,
                          actually ´m using your palette tools a lot. Not the Curvizard yet, but wonder if it would be possible to draw a real spatial contour.
                          The tutorial did not refer on a spatial type of editing the vertices.
                          My desire is related to an intuitive process creating contour lines of a hull, which is not yet defined , means from scratch.
                          The strategy follows many times to find a resulting spatial contour from two related planar contours.
                          Do you have an idea in terms of Plugin for this ?
                          Thank you for your work its really great .
                          Uli
                          • BoxB Offline
                            Hi Fredo I'm getting a repeatable error when using Curvizard Convert Edges to Guides.
                            It happens with any edge, even a single straight line.
                            This is with 2018 pro all plugins up to date, Libfredo6 8.4g
                            It works correctly in 2017.
                            I've attached the error text.
                            Ruby Error - Curvizard#convert_to_guide - 04-Jul-18 00_03_59.txt
                            • fredo6F Offline
                              NEW RELEASE: Curvizard v2.1c - 03 Jul 18
                              Curvizard 2.1c is a maintenance release fixing a small bug signaled by Box.
                              • fredo6F Offline
                                NEW RELEASE: Curvizard v2.2a - 23 Nov 18
                                Requirement: LibFredo6 8.6m or above
                                Curvizard 2.2a introduces new toolbar icons designed by JClements. They are provided in Vector mode (SVG, PDF) and Raster mode (PNG), and thus should scale for hi-res screens on SketchUp versions >= SU2016 (and all versions on Mac)
                                See Plugin Page of Curvizard for Download.
                                See main post of this thread for discussion on Curvizard.
                                  rv1974
                                  Since there's a little hope to see this as core function, I wish we had a commercialFredoSplines with following interactivefeatures:
                                  1. handles for shape editing
                                  2. 3 types of control points: smooth\corner\bezier
                                  3. interactive refinement (=segmentation) control
                                  4. Important for arch modelling: total slope (in %%) AND (optionaly) total height input
                                  • pbacotP Offline
                                    That can be very useful at times. Thanks!
                                    • fredo6F Offline
                                      NEW RELEASE: Curvizard v2.4a - 24 Feb 19
                                      Curvizard 2.4a offers 2 new tools[/b][/color] in order to reconstruct Polygons, Arc or Circle from a sequence of edges, when this is possible.
                                      Requirement: LibFredo6 8.8a or above
                                      See Home Page of Curvizard for information and Download.
                                      See Main post of this Curvizard thread for discussion, bug reports and suggestions.
                                      • designerbursaD Offline
                                        designerbursa
                                        "Convert Guides to Edges" Are you considering adding ?
                                          designerbursa
                                          "Convert to Arc / Circle"
                                          thank you fredo6
                                          • fredo6F Offline
                                            This would be different!
                                            Anyway, there are already several plugins doing that, like TIG xLine2Line.
                                            • 5 / 10
