    Vray Material Editor
    renderpluginsextensions
    4 Posts 3 Posters 2.1k Views 3 Watching
      annette1306
      Hello,
      I am fairly new to Vray Sketch Up 2018. I have a problem with the material editor and would be grateful for any help I get since I am on a time crunch.. My first showed the materials the same way it was on sketch up. But when I tried to render the same scene with the same materials again, the materials are coming out much darker. I have attached the first and second render and also the difference in material editors.
      • filibisF Offline
        filibis
        Looks like a 'color space' issue to me and not material. Make sure you enabled sRGB color space in the Vray Frame Buffer. Check this: V-Ray Frame Buffer | VFB
          annette1306
          Thank you Filibis. But that did not fix it 😞 I checked the colour space and rgb colour space is enabled.
            TeKnoel
            the link to the image file has been broken. V-ray can no longer find the source file. the new version has a file path editor that will help you fix this. go to extensions/vray and look for file path editor.
