    3D Truss Models
    1.5k Posts 31 Posters 977.0k Views 30 Watching
    • medeekM Offline
      medeek
      A number of presets can be set by the user in the global settings however I have not fully implemented a "store" function that will take an entire roof configuration and store it as a preset roof assembly. This may be another feature that I add.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • facerF Offline
        facer
        Medeek,
        ..."take an entire roof configuration and store it as a preset roof assembly."
        I think this will be very popular, looking forward to this function! πŸ‘
        • medeekM Offline
          medeek
          Version 2.1.7 - 03.06.2018
          • Enabled the "Edit Truss Assembly" function for all common roof trusses (imperial units only).
          To edit a roof truss assembly just right click on the assembly and select the "Edit Truss Assembly" option.
          Note, that this function is only available for common trusses with imperial units (template). Metric will be next.
          It seems to be working fairly robustly but I'm sure there will be some minor bugs that pop up considering the complexity of the code and the sheer numbers of variables that I am working with.
          Please report any errors by using the ruby console to record the error and email it to me.
          Once this feature has been out for a while and I know it is running fairly stable I will then work on updating all rafter and truss assemblies so that the user can edit them. I can already see that this will be a very useful upgrade to the plugin.
          design.medeek.com
          • medeekM Offline
            medeek
            Realize that the entire roof assembly is being redrawn from scratch so any manual customization will disappear. It is actually quite a bit faster than I thought it might be so I’m fairly happy with that.
            I did notice that when you initially create a truss assembly without any advanced options and then enable advanced options in the edit panel it does not auto populate the various advanced option fields, I think this could use some attention.
            Below is a screenshot of the edit panel:
            http://design.medeek.com/resources/images/truss_su350_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.1.7b - 03.10.2018
              • Enabled the "Edit Truss Assembly" function for all common roof trusses (metric units).
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 7, Edit Function and some changes to the global settings:
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.1.7c - 03.11.2018
                  • Added ceiling gypsum and ceiling battens to cathedral trusses.
                  http://design.medeek.com/resources/images/truss_su351_800.jpg
                  http://design.medeek.com/resources/images/truss_su352_800.jpg
                  View model here:
                  3D Warehouse
                  (3dwarehouse.sketchup.com)
                  design.medeek.com
                  • jujuJ Offline
                    juju
                    Not on your home website yet?
                    • medeekM Offline
                      medeek
                      Should be up now.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I've been giving some thought to framed openings in floors, see image below:
                        http://design.medeek.com/resources/images/truss_su353_800.jpg
                        Generally, at least from what I've seen most holes in floors are either rectangular, L-shaped or U-shaped, but I guess any outline is possible.
                        What I've shown in the image above is LSL or LVL framing out the opening however the actual framing might be significantly different depending on what is supporting the floor below.
                        In some cases the rectangular opening might not be supported by bearing walls from below, in that case the two LSL boards running parallel to the joists would probably be larger beams and the headers would be hangered from these beams and would also probably be more substantial.
                        The point is how to make this feature flexible enough to accommodate most framed openings but at the same time keeping it as simple as possible so the user is not overwhelmed with parameters.
                        View model here:
                        3D Warehouse
                        Any ideas would be greatly appreciated.
                        P.S. I am also going to make this feature editable so that the actual hole can be altered after the fact. This should be an interesting programming challenge.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Alternatively that same opening could be framed as below:
                          For the size of the opening one would probably use some PSL Beams rather than a couple of I-Joists but the concept is the same, compare with the previous example where the opening would probably be supported from below by bearing walls.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Here is an example of a L-shaped opening in a floor to allow for a stairway.
                            https://cdn.instructables.com/FXK/LIS1/ITXTNPWV/FXKLIS1ITXTNPWV.LARGE.jpg
                            Probably not the best example but I think it helps get the idea across.
                            Note the bearing walls supporting perimeter of the opening.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.1.7d - 03.14.2017
                              • Addresses a minor bug with the UI menu for common trusses. The overhang of the truss could be rounded to an integer value upon recreation of another truss set.
                              I wonder why no one else has noticed the overhang rounding issue. I just realized it is an artifact from when I had it setup to use a integer value for the overhang, which I eventually changed but I must have forgot to update the rounding function (or remove it) so that non integer values could be input.
                              It appears this bug only affected common trusses but I will need to go through and check each truss type to make sure the same issue was not replicated elsewhere.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                I am trying to get my hands on some shop drawings for a dutch gable truss set. I would like to work on adding this truss set into the plugin this weekend if possible.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Two different ways to truss out a dutch gable roof:
                                  http://design.medeek.com/resources/images/truss_su354_800.jpg
                                  http://design.medeek.com/resources/images/truss_su355_800.jpg
                                  The first method involves a wailing plate attached to the side of the girder truss. This appears to be the preferred method of construction in Australia.
                                  The second method employs vertical studs on the gable end portion (upper half) of the girder truss. What is not entirely clear to me is how the joint comes together at the top chord where the horizontal member (at the top of the jacks) meets the vertical and diagonal web of the girder truss.
                                  I could really use a shop drawing (2D) of this particular configuration.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.1.8 - 03.18.2018
                                    • Enabled the "Edit Floor Assembly" function for all I-Joist floors (imperial and metric units): TJI, BCI, LPI, Red-I, PKI.
                                    http://design.medeek.com/resources/images/truss_su356_800.jpg
                                    Now I just need to get the floor framed opening feature working and then this module might actually be useful.
                                    Realize that any manual edits made to the floor assembly are blown away when you use the edit function. It is essentially re-drawing the entire floor assembly, the same goes for the roof truss assembly edit feature.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Spending some time the last couple of days thinking about the floor module (floor trusses, I-joists, solid sawn joists).
                                      The obvious 800 lbs gorilla is the ability to easily add openings into these floors. The other missing element is the ability to create a polygon shaped floor (something beyond a rectangle outline).
                                      With regards to polygon shaped geometry I've already done the heavy lifting when I programmed the foundation plugin to generate polygon shaped layouts (slab and stemwall). The details in trimming the joists is also mostly figured out since my rebar and mesh routine for slabs utilizes a function that will form the basis for this function. It is really just a matter of finding the time and then digging into the code deep for a solid 12+ hour period (uninterrupted).
                                      These two issues are my main focus the next week or two. If I can address both as well have the edit function work seamlessly with both then I will have created an actual functional floor module.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I have a lot of people recently asking me about features that are or are not included in the plugin. Granted my documentation is still in disarray, especially the manual, but I would strongly suggest doing a search in the Changelog if you are interested in a particular feature and would like to check if it has been implemented yet:
                                        Medeek Design Inc. - Medeek Truss Plugin Changelog
                                        (design.medeek.com)
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I've been looking at adding in the ability to handle dual pitch hip roofs:
                                          http://design.medeek.com/resources/images/truss_su357_800.jpg
                                          View model here:
                                          3D Warehouse
                                          The first thing that jumps out at me is the jack rafters do not line up when the pitches are different. Also if the overhang is the same and the fascia is the same height then the top plate will be a different height for the different pitches.
                                          design.medeek.com
                                          • pbacotP Offline
                                            Yeah irregular pitch roofs are kind of tricky. They occur nevertheless.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 75
                                            • 76
                                            • 15 / 76
