    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.0c - 10 Dec 17
      LibFredo6 8.0c is a maintenance release dedicated to the integration of VRay 3.6 in Animator.
        MennaD
        thankx
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v8.1a - 23 Feb 18
          LibFredo6 8.1a is a maintenance release dedicated to bug fixing and evolutions in other plugins
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v8.1b - 25 Feb 18
            LibFredo6 8.1b is a maintenance release dedicated to bug fixing and evolutions in other plugins. Please use 8.1b or above on Mac, as rhere was a problem with toolbar icons in Vector format on Mac with v8.1a.
              ChillBilla
              2018? why doesn't this work? Is the latest version even available for 2018?
              • fredo6F Offline
                What exactly is your problem?
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v8.1c - 27 Feb 18
                  LibFredo6 8.1c is a maintenance release dedicated to bug fixing for JointPushPull, Curviloft and FredoTools. Please also upgrade to the latest versions of these plugins.
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v8.1d - 04 Mar 18
                    LibFredo6 8.1d is a maintenance release dedicated to tentatively solving occasional bugsplats in Curviloft and FredoTools. Please also upgrade to the latest version if you have the case.
                      ali_yonder
                      Hello Fredo.
                      When i installed fredo6 8.1 for SU2017, it has failed. How can i fix this problem?
                      Error Loading File Fredo6_!LibFredo6.rb
                      Error: #<ArgumentError: invalid byte sequence in UTF-8>
                      c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                      c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/ali yönder/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                      C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                      C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                      C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require'
                      C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in module:Fredo6'
                      C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>' Error Loading File Fredo6_ToolsOnSurface.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_!LibFredo6.rb:79:in -'
                      C:/Program Files/SketchUp/SketchUp 2017/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:in require' C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:47:in module:Fredo6'
                      C:/Users/Ali Yönder/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>'
                      Thank you 😄
                        dci02081
                        Ce ruby Libfredo6 v8.1d n’est pas marché sur sketchup pro 2016 (win10) dans l’ordinateur portable (surface pro5). Comment je le fixe ? en fait, le ‘***’ est la différente langue (c’est la langue coréenne). C’est la raison de montrer ce bug ?
                        c:/users//appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in gsub' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:43:in get_dir_from_ENV'
                        c:/users/
                        /appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:405:in dir_appdata' c:/users/***/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:204:in startup'
                        C:/Users//AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:63:in process' C:/Users/***/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:70:in module:LibFredo6_Loader'
                        C:/Users/
                        /AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in `<top (required)>'
                          c:/users/ali yönder/appdata/...
                          I suspect it's to do with your Windows user name [ali yönder] containing some invalid character [likely the 'ö'].
                          Ruby must be given UTF-8 encoded text strings.
                          I'm sure that Fredo's code will attempt to force every string's encoding into an acceptable format.
                          Clearly it's failing in your case...
                          What is your normal system encoding ?
                          Perhaps Fredo can comment...
                          The other similar post's issue is again almost certainly because of the 'langue coréenne' user-name encoding...
                          • fredo6F Offline
                            This is related to the encoding of ENV["xxx"] variables, where LibFredo6 does try to convert them to UTF-8.
                            Could you open the Ruby console and type sequentially
                            • a = ENV["LOCALAPPDATA"]
                            • b = a.force_encoding("UTF-8")
                            • b.encoding (should return UTF-8)
                            Can you also type
                            • c = LibFredo6.get_dir_from_ENV("LOCALAPPDATA")
                            • c.encoding (should return UTF-8)
                            Thanks to report if there are errors.
                              ali_yonder
                              Thanx for reply TIG & Fredo
                              I am from Turkey nd there are 'ı,ü,ö' letters in my sytstem.
                              I've written
                              • b.encoding
                              to ruby conlose.
                              but it has failed again.
                              Error: #<RuntimeError: can't modify frozen String>
                              <main>:in force_encoding' <main>:in <main>'
                              SketchUp:1:in `eval'
                              b.encoding
                              Error: #<NoMethodError: undefined method encoding' for nil:NilClass> <main>:in <main>'
                              then, i ve written
                              • c.encoding
                              to ruby console, but it has failed again 😞
                              <main>:in <main>' SketchUp:1:in eval'
                              c.encoding
                              Do u have any suggestion?
                              thanx all 😄
                                Try this slightly different way, which sidesteps reading in the frozen system string...
                                puts a = ENV["LOCALAPPDATA"]**+""** puts b.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                                Fredo needs to fix his coding, once we get to the bottom of this issue...
                                • fredo6F Offline
                                  Apparently ENV["LOCALAPPDATA"] is not defined.
                                  Could you type in the Ruby console
                                  ENV["LOCALAPPDATA"].inspect
                                  @TIG: indeed, in LibFredo6 code, I duplicate the original string before forcing encoding. Just forgot this detail here.
                                    So whenever any of us intend to use a 'frozen reference' we need to use something like:
                                    a = ENV["LOCALAPPDATA"]+""
                                    to make a copy of it to work on 😉
                                      ali_yonder
                                      Thanx for replies again 😄
                                      i've written ENV["LOCALAPPDATA"].inspect
                                      "C:\Users\Ali Y\xF6nder\AppData\Local"
                                      • fredo6F Offline
                                        Many thanks
                                        Then can you type the commands suggested by TIG
                                        puts a = ENV["LOCALAPPDATA"]+"" puts a.encoding puts b = a.force_encoding("UTF-8") puts b.encoding
                                        and add this one
                                        puts a = ENV["LOCALAPPDATA"].encode("UTF-8")
                                        IMPORTANT: your profile says you use Sketchup 8. Is that correct?
                                          ali_yonder
                                          Thanx fredo. I use sketchup 2017. i have to update my profile.
                                          i've written these
                                          puts a.encoding
                                          puts b.encoding
                                          and ruby said;
                                          puts a.encoding
                                          Windows-1254
                                          puts b.encoding
                                          UTF-8
                                          C:\Users\Ali Yönder\AppData\Local
                                          but still my problem is not solved. maybe i have to format my pc. i do not know.
                                          • fredo6F Offline
                                            Ali,
                                            You need to type the commands one by one.
                                            Apparently the last one seems to work.
                                            Could send me a private message with an email address where I can send you a modified version of LibFredo6.
                                            To be sure, can you type separately the 3 commands below:
                                            a.encoding
                                            a.gsub(/\\/, "/")
                                            The last one should return the path with \ replaced by /
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 109
                                            • 110
                                            • 57 / 110
