    Rear mid engine coupe.
    16 Posts 6 Posters 7.9k Views 6 Watching
      @mike amos said:
      Thanks L i am. So far this version (#60 in this series) about 12 hours. Mainly due to modeling aerodynamic surfaces and modules so if I can get this done in another 12 I'll be happy. The radiator outlets will exhaust onto the engine/transmission cover hopefully directly onto the lower surface of the rear wing. The exhaust will also exit near this outlet and have a baffle to stall the rear wing for straight line speed.
      Am I reading you correctly. This is number 60, that you have done?
        Number 60 in this series but several hundred overall. I tend to chuck those I do not like so the total number is a miss Terry.
          Moving on, the white oblong is the footprint of a Lotus Elise which demonstrates how small my project is.
          Size comparison with Lotus Elise footprint.
          • Bryan KB Offline
            Looking good!
              Thanks Bryan.
                liam887
                Nice work!
                VISIT MY ONLINE GALLERY
                  Thanks Liam, I am getting the feeling I may have gone too small with this one.
                  • tuna1957T Offline
                    tuna1957
                    Good progress on this one. πŸ‘
                      liam887
                      You can always scale it up my a meter if you need no?
                        I did upscale to Lotus Elise length but it just does not work. Horrible in fact. I may need to rethink my engine/power system for this but that is much easier, there is a very useful two cylinder engine in the Fiat 500 and that with electric assistance and a light vehicle would go some. Batteries go where the transmission tunnel is.
                        • hellnbakH Offline
                          hellnbak
                          Yay, something with wheels!
                          Looking good, Mike. I'm curious as to why you say you might have gone too small (assuming the driver can fit comfortably in it).
                          Also curious about the object protruding from the front. A laser maybe? πŸ˜‰
                          Keep at it!
                          Steve
                            Thanks Steve, nice to see you around. The projecting thing at the front is the steering column that I need to alter, a laser might be useful in traffic. When I say possibly too small I am talking about radiator air flow and a decent fuel tank. Thing is, as intended this whole vehicle is meant to tip the3 scales at about 600-650kg. The crumple zones are going to be aluminium honeycomb structures at the front and a similar item at the rear incorporating the cat/exhaust can. All of this is getting very tight in the structure so far attempted. However it keeps the brain, whats the word, clock thing.............
