    3D Truss Models
    1.5k Posts 31 Posters 978.1k Views 30 Watching
    • medeekM Offline
      medeek
      Wow, that is pretty amazing.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        Look at your Private messages! 😉
        • medeekM Offline
          medeek
          As the number of advanced options have increased (common trusses) the user input menu has slowly grown in size until it is so large that it often does not fit the screen of many laptops and smaller screens.
          This problem has been well documented by a number of users for quite some time.
          This weekend I spent some time putting together a new HTML menu for advanced options for roof trusses:
          http://design.medeek.com/resources/images/truss_su323_800.jpg
          I still need to work out the metric version and also all of the language translations but otherwise I think it is almost ready to roll out.
          As you mouse over each of the options a 320x240 image will display as shown, hopefully clarifying the meaning or usage of each parameter/option.
          design.medeek.com
            Help Image is a very very good idea! 👍
            Very very first draft as you can see the "?" ! 😉
            Veuillez choisir les options avancées pour les fermes de toiture
            Roof and Wall Sheathing = RevĂȘtement de Toiture et RevĂȘtement Mural
            Roof Sheathing = RevĂȘtement de Toiture
            Roof Sheating Thickness = Épaisseur du RevĂȘtement de Toiture
            Gable Wall Sheathing = RevĂȘtement Mural du Pignon
            sub-fascia = Sous-fascia ?
            sub-fascia type = Type de Sous-fascia ?
            sub-fascia width = Largeur de Sous-fascia ?
            sub-fascia depth = Profondeur de Sous-fascia ?
            rakeboard = ?
            gable overhang = Porte-Ă -faux du Pignon
            rake board width = Largeur ?
            rake board depth = Profondeur ?
            outloockers = Débords ?
            outlooker spacing = Espacement du Débord ?
            outlooker size = Taille du Débord ?
            structural outlookers = Débord Structurel ?
            outlooker @ roof peak = Débord @ Pointe de Toit ?
            heel blocking = Blocage du Talon ?
            heel block orientation = Orientation du Talon ?
            cladding = RevĂȘtement
            roof cladding = RevĂȘtement de Toiture
            hip and ridge cap = Capuchon de Croupe et de FaĂźtage ?
            gable wall cladding = RevĂȘtement Mural du Pignon
            additional options = Options Supplémentaires
            soffit cut = Coupe de Soffite ?
            roof returns = Retours de Toit
            roof battens = Lattes de toit
            ceiling gypsum = Gypse de Plafond
            gutters = GouttiĂšres
            dropped top chord = Panne Supérieure Lancée ?
              First glance! 😄 (must be refined)
              Veuillez sélectionner l'un des types de fermes suivants:
              Commun en W - Tunnel - Mono-Pente - Ciseaux - Empennage - Double-Pente
              Corde d'Arc (?) - Arceau de Barrique (?) - Polynésien - Bombé - Cathédrale - Plateau (?)
              Simple Ciseau - Simple Cathédrale - Shed - Voûte En Berceau (?) - Tunnel à la Mansart - Caisson
              Treillis - Cathédrale Symétrique - Studio en Berceau - Double Inversé - Corde ParallÚle - Charpente
              Remarque: Les types de ferme Shed, Arceau de barrique, Studio en Berceau et Double Inversé sont en cours de développement et ne sont pas encore disponibles.
              • medeekM Offline
                medeek
                Version 2.1.1 - 12.04.2017
                • Enabled a graphical user interface for advanced options of roof trusses.
                design.medeek.com
                  new refinement! 😄
                  • Commun ( Classique en w) - Grenier( Habitable) - Mono-Pente - Ciseaux( Entrait RetroussĂ©)- Empennage ( Ă  coyeau) Double-Pente ( AsymĂ©trique)
                  • Corde d'Arc (Arc) - Arceau de Barrique (Arc triangulĂ©) - PolynĂ©sien ( tropicale)- BombĂ© ( entrait retroussĂ© variante ou Polonceau ) - CathĂ©drale - Plateau(Double ferme articulĂ©e)
                  • Simple Ciseau - Simple CathĂ©drale - ClergĂ© (Contemporaine ) - VoĂ»te En Berceau (En voute ) - Grenier SurĂ©levĂ© ( Ă  la Mansart)- Caisson ( Ă  entrait dĂ©calĂ©)
                  • Plat ( poutre treillis )- CathĂ©drale SymĂ©trique ( treillis Ă  deux pentes) - Studio en Berceau ( Ă  entrait dĂ©calĂ©) - Double InversĂ© ( double articulĂ©e) - Corde ParallĂšle - Charpente
                  https://img15.hostingpics.net/pics/255775ferme03.jpg
                  https://img15.hostingpics.net/pics/647757ferme02.jpg
                  https://img15.hostingpics.net/pics/484019ferme04.jpg
                  https://img15.hostingpics.net/pics/576001ferme01.jpg
                  • medeekM Offline
                    medeek
                    I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
                    Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
                    design.medeek.com
                      glro
                      not only that
                      i had the same questions
                      so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
                      sheap, you can use windows mouse, keyboard and screen
                      there are a few things to modify in the ruby code por windows, to make it work on a mac
                      • medeekM Offline
                        medeek
                        I am working on adding the heel blocking since it is an option listed in the advanced options.
                        http://design.medeek.com/resources/images/truss_su324_800.jpg
                        So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
                        I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
                        design.medeek.com
                        • pbacotP Offline
                          Very important. Sometimes the heel blocking, when taller, is a truss manufactured square that might have sheathing.
                          • medeekM Offline
                            medeek
                            I agree, I was investigating this a while back but I'm not sure yet what is standard practice, there could be a number of ways of handling this.
                            http://res.cloudinary.com/engineering-com/image/upload/v1484676854/tips/SHEAR_PANELS_ego3xz.jpg
                            http://res.cloudinary.com/engineering-com/image/upload/v1484694321/tips/SHEAR_PANELS2_vis1pr.jpg
                            design.medeek.com
                            • pbacotP Offline
                              Those look nice. I think sometimes the truss blocking has a diagonal which would make it effective (but the engineer will want plywood on it anyway it seems). You can have the truss all the way to the top or the method you show allows (1) continuous plywood gets nailed to the top of the truss block and the solid block provides the shear nailing (2) sometimes decorative rafter tails are added which need to pass through the space above the truss block.
                              • medeekM Offline
                                medeek
                                Featured on the SketchUp Extension Inspection:
                                design.medeek.com
                                  Very enlighting video! 😎
                                  else (Always : https://trussfr.weebly.com 😉
                                  Truss Type = Type de Fermes
                                  (not sure to translate all names of this little list of part of trusses)
                                  King Post
                                  Queen Post
                                  Fink
                                  Howe
                                  Fan
                                  Mod Queen
                                  Double Fink
                                  Double Howe
                                  Mod Fan
                                  Triple Fink
                                  Quad Fink
                                  Out-to-Out Span = Portée Hors tout
                                  Top Chord Angle = Angle de Corde Supérieure (?)
                                  Overhang Left = Porte-Ă -faux Gauche
                                  Overhang Right   (Same as Left) = Porte-à-faux Droit (Identique au Gauche)
                                  TC Size = Taille TC (? à définir)
                                  BC Size = Taille BC (? à définir)
                                  Web Size = Taille (?)
                                  Ply Thickness = Epaisseur du Pli
                                  Raised Heel (No, Yes) =Talon surélevé (?) ( (Non, Oui)
                                  Heel Heigh = Hauteur du Talon (?)
                                  Bldg.lenght = Longueur BĂątiment
                                  Truss Spacing = Espacement de Ferme
                                  Gable End Trusses (Yes, No, Front) = Poutrelles d'extrémité (Oui, Non, Face Avant)
                                  Gable Stud Spacing = Espacement Goujons de Pignon (?)
                                  Adv. Roof Options (Yes, No) = Options Avancées de Toit (Oui, Non)
                                  PS
                                  Does the Messages' window data is self-adapting to the length of words ?
                                  • medeekM Offline
                                    medeek
                                    Thank-you Pilou, I will add these phrases into the language file.
                                    Yes, the SU menu automatically adjust for the length of the words so even though French is often more verbose than English it does not matter. I've noticed though that Russian has some problems rendering in the SU menus.
                                    I would have liked to see the video dive into the advanced menus more but I realize there is far too much material to cover in such a short video.
                                    design.medeek.com
                                      Excellent! 👍
                                      What is BC and TC size ? 😳
                                      Minor Roof Family = Famille de Toit Secondaire
                                      Gable Dormer = Lucarne de Pignon
                                      Hit Dormer = Lucarne de Toit
                                      Shed Dormer = Lucarne de Hangar
                                      Gable Roof Minor = Pignon de Toit Secondaire (?)
                                      Hip Roof Minor = Lucarne de Toit Secondaire (?)
                                      Dutch Gable Roof Minor = Pignon de Toit Hollandais Secondaire (?)
                                      The (?) does not signify that is forcefully false but can maybe be enhanced! 😉
                                      Else works fine! 😄
                                      • medeekM Offline
                                        medeek
                                        BC = Bottom Chord
                                        TC = Top Chord
                                        Web = Internal (web) members of truss
                                        design.medeek.com
                                          Thx for the Infos! ☀
                                          • medeekM Offline
                                            medeek
                                            The license registration module was causing some problems in isolated cases so I've released a sub-rev. 2.1.1b to address that issue.
                                            If you are trying to enter in your serial number and it does not appear to take, first verify that you are not entering in any leading or trailing white spaces if that does not solve the problem you may be encountering the issue at top, in that case download the latest version which should address the issue fully.
                                            design.medeek.com
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 75
                                            • 76
                                            • 69 / 76
