    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 541.0k Views 153 Watching
      Why are you messing on with an RBZ ?
      This is an old plugin - putting the RB file [latest version] inside the Plugins folder and restarting SketchUp ought to be all you need...
      But if you want to use an .RBZ, you must make a .ZIP of the lone .RB and then change its file-type to .RBZ - use Preferences > Extensions > Install Extension... on that RBZ and it's put into the Plugins folder for you...
      But have you [re]read the Usage instructions ?
      This tool - when properly installed - works from the context-menu, but only when you have a suitable group selected...
      Here are its instructions again...
      • Create a group with all the geometry you wish to deform. This group should contain just faces and/or lines.
      • Right click the group and select one of the options in the FFD submenu. Either 2x2 or 3x3 or NxN FFD. Depending on the size of the model it could take a while (seconds I hope). At the end you should see a new group containing nothing but control points
      • Open the control point group and move the control points as you wish. The object should deform as you move the points. NOTE: it can take a long time for complex models. Look at the status bar in the lower left to see the status of the deformation.
      • H
        Hepf
        Thank you Chris. I was drawing the half dome of Maxentius basilica, and needed just that.
        • ithilI
          ithil
          Hello
          I'm a little bit corrected your plugin
          Now It supports polygons.
          He checks the creation of new edges. And converts the resulting triangles in polygon.
          Strings 534-538
          SketchyFFD_v5_poly.rbz
            Cool and seems you mix some other plugins for help it! 😄
            In the past have only points was a little esoteric! 💚
            But we had only that for deform a volume with powerful!
              In the same order of idea !
              TGi 3D must be make something similar! 😉
              (a free version is existing)
              • facerF
                facer
                **TGI 3D -**Free Version
                http://www.tgi3d.com
                Note:
                Tgi3D SU Amorph Training Edition has the same functionality of Tgi3D SU Amorph, except that it has a limit on the number of vertices to work with. It is still fully functional and will let you experience and appreciate all the features of Tgi3D SU Amorph. Download (Win | Mac)
                Tgi3D price
                • N
                  nickweboffer
                  i am running 2016 SU on my macbook air, and the FFD plugin doesn't seem to function. I am missing options in the right-click menu. and when I manipulated the points, nothing happened.
                  • K
                    kaouther alimi
                    Please can you help me to solve this problem..I've downloaded the script but it doesn't work because of 'Unsigned Author'
                      It's an old plugin.
                      So it won't be 'signed'.
                      If you set SketchUp's Extension Loading Policy to be 'Unrestricted', then it should load - always presuming that it's still compatible with the current SketchUp version...
                      • K
                        kaouther alimi
                        Thank you for your reply..But the problem still here..Please can you give me a similar plugin to FFD sketchy.It would be really helpfull for me.Thanks for you time
                          There is Vertex Tools by Thomthom
                          and also Stretch by Aera by Tak2hata
                            @goodspeeder said:
                            Once I create the control points, I can't seem to grab or select them. Working on a mac if it matters
                            They are inside a group, so edit the group and you can then select them individually, or multiply holding Shift etc, or by fence etc...
                            • G
                              Goodspeeder
                              Once I create the control points, I can't seem to grab or sellect them. Working on a mac if it matters.
                              Would appreciate any help on this because it looks like an awesome plugin.
                              FIgured it out.
                              1. double click ffd control points in outliner window
                              2. be sure to check unlock edges in right click ffd context window
                              I'll leave this here on the chance others are having the same issue
                              • F
                                fusioncraft
                                Hi, I am new to Sketchup and installing plugins and extension.
                                I'm unable to install the ruby Script in my Shetchup 2016. The plugin isn't loading. I have copied and dragged the file into my Plugins folder. Path - /Users/Praveen/Library/Application Support/SketchUp 2016/SketchUp/Plugins
                                Looking for some kinda guidance from the community on what I've done wrong
                                  In all currently supported versions of SketchUp, you [almost] NEVER need to install files into your Plugins folder "manually".
                                  Almost all extensions/plugins come in an RBZ archive format [e.g. all downloads from the SketchUcation PluginStore or the SketchUp EWH]
                                  This needs to be 'installed'.
                                  Users normally leave their RBZ downloads in their Downloads folder - if you have moved any move them back there...
                                  The installer automatically extracts the contents of an RBZ archive [actually a specially-suffixed ZIP file!] and puts the files/subfolders into the correct location[s] and then loads the tool...
                                  In early versions of SketchUp the installer is accessed from Preferences > Extensions > Install... button.
                                  In newer versions of SketchUp the Install... button is now found on the dialog opened from Preferences > Extension Manager...
                                  Both of these tools require you to select the RBZ, it is then installed...
                                  If you have installed the SketchUcation Toolset it has a menu item to also Install Archive... from RBZ [or ZIP].
                                  Also if you have installed the SketchUcation Toolset, then the Toolbar's first button [red] launches the SketchUcation ExtensionStore³ dialog, from that dialog you can browse and AutoInstall any of the extensions/plugins listed in the SketchUcation PluginStore, all without having to first download an RBZ.
                                  The SketchUp EWH has a similar tool to load/enable automatically its Extensions listed.
                                    Mister Fab
                                    I'm trying to use the plugin, but the part I try to modify disappears when I double click the dots.
                                    Example, I draw a cylinder, make it a group, apply 3x3 FFD, and when I double click one of the FFD dots, the cylinder disappears.
                                    Am I doing something wrong? Using sketchup 2017.
                                    Thanks for reading
                                      As these things are inside separate containers I suspect the disappearance is due to your SketchUp settings ?
                                      Ensure that View > Component Edit > Hide Rest of Model... is set OFF...
                                        Mister Fab
                                        Thank you for your answer TIG.
                                        Ok, after I set that parameter of, now I can see the cylinder.
                                        But moving the dots with the scale tool still has no effect on the part.
                                        I'm doing exactly what I found in that tutorial video, except I work on a simple cylinder.
                                        https://www.youtube.com/watch?v=sBLX1SFKULU&t=13s
                                        • C
                                          coolhub786
                                          i cannot find 3x3 node nor 2x2 node
                                          when i select the object > right click ffd > it shows lock unlock and make patch
                                          • boofredlayB
                                            boofredlay
                                            The object has to be a group. Not loose geometry, not a component.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 18 / 21
