    Wine Opener - Model Posted
    42 Posts 13 Posters 7.0k Views 13 Watching
    • Bryan KB
      Nice! Well done!
      • tuna1957T
        tuna1957
        In responce to good input from tadema, tweaked a few things in the model and made some adjustments on the render side and ran a new image.For better or worse.....
        • tademaT
          tadema
          Hello Charles, the rounded edges certainly look better IMHO πŸ‘ few modern objects have arris corners/edges, supposedly to aid both aesthetics and safety. Please don't think I was criticising, that was never my intention.
          John
            I think it is great too.
            • ntxdaveN
              ntxdave
              Definitely looks better to me. Now if you get just brighten the render just a little. At least on my iPad it is just a little dark.
              πŸ‘ πŸ‘
              Press F1...thank me later
              • tuna1957T
                tuna1957
                John, No worries. If I thought you were being harsh I wouldn't have gone back into the model and tweaked on things. Try to absorb peoples input , just takes a while to sink in sometimes. Thanks.
                Mike A. , ntxdave, Thanks gentlemen. Dave the image seeming darker might just be monitor differences. Tone looks good on my screen. Bye the way I did use a darker grey background color on the second render. Just liked the looks of it a little better.
                • bazB
                  baz
                  Pretty dark on my (calibrated) monitor too.
                  • tuna1957T
                    tuna1957
                    O.K. everybody, posting new render. Render settings and number of passes the same just went back to a lighter colored back drop......
                    baz, I probably need my eyeballs calibrated.....
                    • ntxdaveN
                      ntxdave
                      Better but I still like the render settings from the first image the best.
                      Quality of the model is better with the updated edges though.
                      • tademaT
                        tadema
                        Hello Charles, I did not explain very well in my first post when I mentioned reflections, this type of "still life" image benefits from HDRI lighting...try it and watch it come alive.
                        John
                        • bazB
                          baz
                          Sounds like a render challenge in the making... fancy sharing the model?
                          • pbacotP
                            Super realistic! Great looking render. I like the shiny parts, especially because of the rounded edges looking good.
                            • tuna1957T
                              tuna1957
                              pbacot, Thanks for the kind words.
                              tadema, Just to let you know, all of the images were rendered in a HDRI "soft box".
                              Funny how these threads can go down a different track. Just started it as a "here's a kinda of neat prop" I modeled. Kind of went down the road to let's make it look like a product ad image for wine openers. Do appreciate everyones comments and suggestions.
                              Posting the model. Enjoy.... One final comment, you can pretty easy adjust the position of the lever, corkscrew and knife blade. Click into the main component, select the sub component you want to move and use the rotate tool on the center of the parts "hinge pin" and rotate as desired.
                              wine opener tool2.skp
                              • pbacotP
                                And another thing further down the hole. A serrated blade is better for cutting the foil.
                                • BoxB
                                  Here's a quick one to help show what Tadema means about the HDRI.
                                  The 'texture' on the handle is all reflections from the HDRI.
                                  Your Soft Box may be too 'Flat'.
                                  From a different angle
                                  • tuna1957T
                                    tuna1957
                                    Nice images Box. Actually did a couple of renders using an HDRI that gave a "sharper" light like what you used, just personal preference for the images with the "softer" HDRI that I posted.
                                    • BoxB
                                      Ok. But I thought this had become a render this thread, which shows multiple renders of a specific model.
                                      You don't need to defend your renders.
                                      Other renders are not criticism just different options.
                                      • tuna1957T
                                        tuna1957
                                        No worries Box. Just thought I was clarifying I understood the points Tadema was making earlier....
                                        • HornOxxH
                                          HornOxx
                                          πŸ‘ πŸ‘ I am happy about this contribution - in every facet of every participant. It is a living proof of how open, constructive, helpful and respectfully this forum deals with each other, despite minor misunderstandings here and there. A great place because the question about SCF's future has been asked in another post. So thanks to all!
                                          @ Charles - how did you make this helix cork screw part? and btw - I love your detailed view onto an everyday object in itself πŸ‘
                                          never trust a skinny cook
                                          • tuna1957T
                                            tuna1957
                                            HornOxx , Really appreciate your positive comments about this thread in general.
                                            On another note.... How did I make the corkscrew part.... Started by creating a helix line with the "Follow Me Helix" plugin. Did some minor adjustment on the helix with the scale tool ( compressing , stretching ) so it best matched the patent drawing I was working from. Drew a circle on the end of the helix, making sure it was square to the last segment of the helix and then ran " Follow Me" tool. Created the point and the rectangular section for the hinge end with "Vertex Tools". Pretty much got real lucky as it went pretty smooth for something I haven't done in a long time.
                                            • 1 / 3
