    Wine Opener - Model Posted
    42 Posts 13 Posters 6.9k Views 13 Watching
    • bazB Offline
      baz
      @tuna1957 said:
      Mike A. , ntxdave, Thanks gentlemen. Dave the image seeming darker might just be monitor differences. Tone looks good on my screen.
      Pretty dark on my (calibrated) monitor too.
      • tuna1957T Offline
        tuna1957
        O.K. everybody, posting new render. Render settings and number of passes the same just went back to a lighter colored back drop......
        baz, I probably need my eyeballs calibrated.....
        • ntxdaveN Offline
          ntxdave
          Better but I still like the render settings from the first image the best.
          Quality of the model is better with the updated edges though.
          Press F1...thank me later
          • tademaT Offline
            tadema
            Hello Charles, I did not explain very well in my first post when I mentioned reflections, this type of "still life" image benefits from HDRI lighting...try it and watch it come alive.
            John
            • bazB Offline
              baz
              Sounds like a render challenge in the making... fancy sharing the model?
              • pbacotP Offline
                Super realistic! Great looking render. I like the shiny parts, especially because of the rounded edges looking good.
                • tuna1957T Offline
                  tuna1957
                  pbacot, Thanks for the kind words.
                  tadema, Just to let you know, all of the images were rendered in a HDRI "soft box".
                  Funny how these threads can go down a different track. Just started it as a "here's a kinda of neat prop" I modeled. Kind of went down the road to let's make it look like a product ad image for wine openers. Do appreciate everyones comments and suggestions.
                  Posting the model. Enjoy.... One final comment, you can pretty easy adjust the position of the lever, corkscrew and knife blade. Click into the main component, select the sub component you want to move and use the rotate tool on the center of the parts "hinge pin" and rotate as desired.
                  wine opener tool2.skp
                  • pbacotP Offline
                    And another thing further down the hole. A serrated blade is better for cutting the foil.
                    • BoxB Offline
                      Here's a quick one to help show what Tadema means about the HDRI.
                      The 'texture' on the handle is all reflections from the HDRI.
                      Your Soft Box may be too 'Flat'.
                      From a different angle
                      • tuna1957T Offline
                        tuna1957
                        Nice images Box. Actually did a couple of renders using an HDRI that gave a "sharper" light like what you used, just personal preference for the images with the "softer" HDRI that I posted.
                        • BoxB Offline
                          Ok. But I thought this had become a render this thread, which shows multiple renders of a specific model.
                          You don't need to defend your renders.
                          Other renders are not criticism just different options.
                          • tuna1957T Offline
                            tuna1957
                            No worries Box. Just thought I was clarifying I understood the points Tadema was making earlier....
                            • HornOxxH Offline
                              HornOxx
                              πŸ‘ πŸ‘ I am happy about this contribution - in every facet of every participant. It is a living proof of how open, constructive, helpful and respectfully this forum deals with each other, despite minor misunderstandings here and there. A great place because the question about SCF's future has been asked in another post. So thanks to all!
                              @ Charles - how did you make this helix cork screw part? and btw - I love your detailed view onto an everyday object in itself πŸ‘
                              never trust a skinny cook
                              • tuna1957T Offline
                                tuna1957
                                HornOxx , Really appreciate your positive comments about this thread in general.
                                On another note.... How did I make the corkscrew part.... Started by creating a helix line with the "Follow Me Helix" plugin. Did some minor adjustment on the helix with the scale tool ( compressing , stretching ) so it best matched the patent drawing I was working from. Drew a circle on the end of the helix, making sure it was square to the last segment of the helix and then ran " Follow Me" tool. Created the point and the rectangular section for the hinge end with "Vertex Tools". Pretty much got real lucky as it went pretty smooth for something I haven't done in a long time.
                                • bazB Offline
                                  baz
                                  Here is my attempt. Still getting my head around HDRI.
                                  • cheddaC Offline
                                    chedda
                                    Thanks for the model, here's my quick try:
                                    Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                    • tuna1957T Offline
                                      tuna1957
                                      baz, Good show ! Really like the different view point. Can relate to your comment about HDRI's. Looks like you may have used one of the studio setups from the SKetchUcation store. Their great but still trying to wrap my brain around "best practices" with them.
                                      chedda, Your welcome. As usual your image "rocks".
                                      • HornOxxH Offline
                                        HornOxx
                                        ... sorry - I couldn't resist to appreciate this beautiful model with a rendertest too πŸ˜„
                                        For years now, exactly this opener has been somewhere in the back of my drawer and I haven't even noticed that there's a blade in it as well ...
                                        • tuna1957T Offline
                                          tuna1957
                                          Good show HornOxx.... like your cork too.... again enjoying the different perspectives everyones doing.
                                          • soloS Offline
                                            quick render, using old scene setup. Thea render.
                                            • 2 / 3
