    3D Truss Models
    1.5k Posts 31 Posters 977.0k Views 30 Watching
    • medeekM Offline
      medeek
      C'est merveilleux, merci beaucoup.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        I will make corrections on the post above! 😉
        • medeekM Offline
          medeek
          French translation of the Roof Truss Menu:
          http://design.medeek.com/resources/images/truss_su322_800.jpg
          I will roll a sub revision so everyone can try it out.
          design.medeek.com
            It's a beginning! 😄
            Have you a system of translation ?
            Or I must edit some files ?
            • medeekM Offline
              medeek
              I am still compiling the list of words and phrases, there are a lot of menus, too many.
              design.medeek.com
                That is the problem of very detailed program! 😉
                Ps I can make an adpatation of this page in French! 😉
                Only for the fun, (It's my hobby) ☀
                So that will be a cool training for the future Panel's Truss Translation!
                Yet made Twillight, Podium, FlexTools, Groboto (collector), ZBrush, SimLab Composer,
                3DCoat (Manual), PolyBrush, Qubicle2, SUbD, Profil Builder2, Moi3D, GifCam, Monolith (manual), [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]Visualizer[/u:26zyq7ev][/url:26zyq7ev], [url=http://visualizervf.weebly.com:26zyq7ev][u:26zyq7ev]SolveSpace[/u:26zyq7ev][/url:26zyq7ev] etc...and so many UI, Manuals, curiosities etc...
                I'm frightened by this list! 💚
                • medeekM Offline
                  medeek
                  Wow, that is pretty amazing.
                  design.medeek.com
                    Look at your Private messages! 😉
                    • medeekM Offline
                      medeek
                      As the number of advanced options have increased (common trusses) the user input menu has slowly grown in size until it is so large that it often does not fit the screen of many laptops and smaller screens.
                      This problem has been well documented by a number of users for quite some time.
                      This weekend I spent some time putting together a new HTML menu for advanced options for roof trusses:
                      http://design.medeek.com/resources/images/truss_su323_800.jpg
                      I still need to work out the metric version and also all of the language translations but otherwise I think it is almost ready to roll out.
                      As you mouse over each of the options a 320x240 image will display as shown, hopefully clarifying the meaning or usage of each parameter/option.
                      design.medeek.com
                        Help Image is a very very good idea! 👍
                        Very very first draft as you can see the "?" ! 😉
                        Veuillez choisir les options avancées pour les fermes de toiture
                        Roof and Wall Sheathing = Revêtement de Toiture et Revêtement Mural
                        Roof Sheathing = Revêtement de Toiture
                        Roof Sheating Thickness = Épaisseur du Revêtement de Toiture
                        Gable Wall Sheathing = Revêtement Mural du Pignon
                        sub-fascia = Sous-fascia ?
                        sub-fascia type = Type de Sous-fascia ?
                        sub-fascia width = Largeur de Sous-fascia ?
                        sub-fascia depth = Profondeur de Sous-fascia ?
                        rakeboard = ?
                        gable overhang = Porte-à-faux du Pignon
                        rake board width = Largeur ?
                        rake board depth = Profondeur ?
                        outloockers = Débords ?
                        outlooker spacing = Espacement du Débord ?
                        outlooker size = Taille du Débord ?
                        structural outlookers = Débord Structurel ?
                        outlooker @ roof peak = Débord @ Pointe de Toit ?
                        heel blocking = Blocage du Talon ?
                        heel block orientation = Orientation du Talon ?
                        cladding = Revêtement
                        roof cladding = Revêtement de Toiture
                        hip and ridge cap = Capuchon de Croupe et de Faîtage ?
                        gable wall cladding = Revêtement Mural du Pignon
                        additional options = Options Supplémentaires
                        soffit cut = Coupe de Soffite ?
                        roof returns = Retours de Toit
                        roof battens = Lattes de toit
                        ceiling gypsum = Gypse de Plafond
                        gutters = Gouttières
                        dropped top chord = Panne Supérieure Lancée ?
                          First glance! 😄 (must be refined)
                          Veuillez sélectionner l'un des types de fermes suivants:
                          Commun en W - Tunnel - Mono-Pente - Ciseaux - Empennage - Double-Pente
                          Corde d'Arc (?) - Arceau de Barrique (?) - Polynésien - Bombé - Cathédrale - Plateau (?)
                          Simple Ciseau - Simple Cathédrale - Shed - Voûte En Berceau (?) - Tunnel à la Mansart - Caisson
                          Treillis - Cathédrale Symétrique - Studio en Berceau - Double Inversé - Corde Parallèle - Charpente
                          Remarque: Les types de ferme Shed, Arceau de barrique, Studio en Berceau et Double Inversé sont en cours de développement et ne sont pas encore disponibles.
                          • medeekM Offline
                            medeek
                            Version 2.1.1 - 12.04.2017
                            • Enabled a graphical user interface for advanced options of roof trusses.
                            design.medeek.com
                              new refinement! 😄
                              • Commun ( Classique en w) - Grenier( Habitable) - Mono-Pente - Ciseaux( Entrait Retroussé)- Empennage ( à coyeau) Double-Pente ( Asymétrique)
                              • Corde d'Arc (Arc) - Arceau de Barrique (Arc triangulé) - Polynésien ( tropicale)- Bombé ( entrait retroussé variante ou Polonceau ) - Cathédrale - Plateau(Double ferme articulée)
                              • Simple Ciseau - Simple Cathédrale - Clergé (Contemporaine ) - Voûte En Berceau (En voute ) - Grenier Surélevé ( à la Mansart)- Caisson ( à entrait décalé)
                              • Plat ( poutre treillis )- Cathédrale Symétrique ( treillis à deux pentes) - Studio en Berceau ( à entrait décalé) - Double Inversé ( double articulée) - Corde Parallèle - Charpente
                              https://img15.hostingpics.net/pics/255775ferme03.jpg
                              https://img15.hostingpics.net/pics/647757ferme02.jpg
                              https://img15.hostingpics.net/pics/484019ferme04.jpg
                              https://img15.hostingpics.net/pics/576001ferme01.jpg
                              • medeekM Offline
                                medeek
                                I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
                                Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
                                design.medeek.com
                                  glro
                                  not only that
                                  i had the same questions
                                  so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
                                  sheap, you can use windows mouse, keyboard and screen
                                  there are a few things to modify in the ruby code por windows, to make it work on a mac
                                  • medeekM Offline
                                    medeek
                                    I am working on adding the heel blocking since it is an option listed in the advanced options.
                                    http://design.medeek.com/resources/images/truss_su324_800.jpg
                                    So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
                                    I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
                                    design.medeek.com
                                    • pbacotP Offline
                                      Very important. Sometimes the heel blocking, when taller, is a truss manufactured square that might have sheathing.
                                      • medeekM Offline
                                        medeek
                                        I agree, I was investigating this a while back but I'm not sure yet what is standard practice, there could be a number of ways of handling this.
                                        http://res.cloudinary.com/engineering-com/image/upload/v1484676854/tips/SHEAR_PANELS_ego3xz.jpg
                                        http://res.cloudinary.com/engineering-com/image/upload/v1484694321/tips/SHEAR_PANELS2_vis1pr.jpg
                                        design.medeek.com
                                        • pbacotP Offline
                                          Those look nice. I think sometimes the truss blocking has a diagonal which would make it effective (but the engineer will want plywood on it anyway it seems). You can have the truss all the way to the top or the method you show allows (1) continuous plywood gets nailed to the top of the truss block and the solid block provides the shear nailing (2) sometimes decorative rafter tails are added which need to pass through the space above the truss block.
                                          • medeekM Offline
                                            medeek
                                            Featured on the SketchUp Extension Inspection:
                                            design.medeek.com
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 71 / 76
