    Construction Methods In France Questions
    26 Posts 4 Posters 5.7k Views 4 Watching
    • Joe WoodJ
      Joe Wood
      Good Info Tig! How about those search terms, if you speak French?
      Joe Wood
      woodsshop.com/
      • Joe WoodJ
        Joe Wood
        cour ร  bois ร  Cannes France?
        chantier bois ร  Cannes France?
        what do they call places that sell lumber / timber?
        Joe Wood
        woodsshop.com/
          Perhaps: http://www.englishspoken.info/English_Info_Results6.php?Department=France:96&Trade=Shops/Suppliers/Dealers
          http://services.completefrance.com/forums/completefrance-forums/cs/forums/2695420/ShowPost.aspx
          http://www.granvillebois.com/index.html
          Remember that in English-English it's not called "Lumber", it's Timber or Wood...
          • Joe WoodJ
            Joe Wood
            Oh right on Tig some very good links!
            Joe Wood
            woodsshop.com/
              What a headache for me to do it all in metric!
              It's nothing compare of the inverse for us! ๐Ÿ’š
              it's follish to use imperial unities in the 21 century! ๐Ÿ˜„
              Remember Mars climate orbiter cost! ๐Ÿ˜„
                a sawmill ? = une scierie ๐Ÿ˜‰
                or any building materials distributor = distributeur de matรฉriaux de construction
                But most of France is not very seismically active.
                Yes but Cannes is like San Fransisco! Near by the sea and inside a seismic zone!
                We are waiting a big one too! Earthquake or Tsunami or both in the same time!
                See what append year after year in Italy! ๐Ÿ˜ฒ
                A famous French volcanologist Haroun Tazieff has predicted that!
                http://img.over-blog.com/482x360/3/02/18/95/actu-8/Actu-9/Actu-10/actu-13/Dossier-16/Dossier-24/haroun-tazieff--image-Fr.-Le-Guern.jpg
                Cannes - Nice 34 kms !
                From this Map : Cannes is on orange zone = moderated seismicity
                https://niceavence.files.wordpress.com/2015/02/seisme_web.jpg
                http://s2.lemde.fr/image/2013/08/16/534x0/3462523_5_f759_une-cartographie-inedite-devrait-deboucher_0432bc5aef2e06da0a6e175f3e55bb54.png
                • Joe WoodJ
                  Joe Wood
                  Yes I agree, I wish I was brought up using metric, would make it a lot easier to do all the calculations carpenters need to make!
                  Joe Wood
                  woodsshop.com/
                  • L
                    Could not agree more. In my early school days Australia was imperial but changed to metric in about 1975 so I have a perspective on the subject. I was originally a firefighter and 1 ft of water had a head of 0.433 pounds per square inch. cubic foot (62.4 lb/ft3); dont get me started ๐Ÿ‘Ž 1 cubic meter of water weighs 1 tonne. All of a sudden fire-ground hydraulics could be done in your head by moving decimal points.
                    Three countries on the entire planet which are not using the metric system are Liberia, Myanmar and of courseโ€ฆ the United States of America ๐Ÿ˜‰
                    • Joe WoodJ
                      Joe Wood
                      What do you call posts and beams in the UK, and when you talk about wall and floor framing do you use 'framing'?
                      how about in France, Poteaux et poutres?
                      floor framing in France, charpente du plancher?
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ
                        Joe Wood
                        You misunderstood my question Pilou.
                        Joe Wood
                        woodsshop.com/
                          Poteaux = Vertical
                          Poutres = Horizontal or inclined
                          floor framing = l'ossature du plancher, la structure du plancher, le support du plancher...la charpente du plancher ๐Ÿ˜„
                            Sure! ๐Ÿ˜„
                            Poteaux / Poutres ?
                            An image can better explain than a text! ๐Ÿ˜‰
                            • Joe WoodJ
                              Joe Wood
                              This is floor framing
                              this is wall framing
                              and these are the posts and beams ๐Ÿ™‚
                              Joe Wood
                              woodsshop.com/
                              • Joe WoodJ
                                Joe Wood
                                My questions are
                                What do you call posts and beams in France, Poteaux et poutres?
                                and floor framing, charpente du plancher ?
                                Joe Wood
                                woodsshop.com/
                                  Ok! So what is the question(s) ? ๐Ÿ˜„
                                  If this exist also in France ?
                                  Put "ossature bois" inside google research image! ๐Ÿ˜‰
                                  "plancher ร  ossature bois"
                                  "charpente ร  ossature bois"
                                  "mur ร  ossature bois"
                                    Affirmative! ๐Ÿ˜„
                                    Post = Poteau (un poteau, le poteau)
                                    Beam = Poutre (une poutre, la poutre)
                                    floor framing = l'ossature du plancher, la structure du plancher...la charpente du plancher! ๐Ÿ˜„
                                    • Joe WoodJ
                                      Joe Wood
                                      Thank you Frenchy, say, is all that artwork on your site digital or do you do any traditional artwork?
                                      Joe Wood
                                      woodsshop.com/
                                        Only digital, but it's just hobbyist relaxing for explore crazzy progs! ๐Ÿ˜„
                                        • Joe WoodJ
                                          Joe Wood
                                          Frenchy, what is the French for timber frame? Like with this photo, with the structure joined with mortises and pegs?
                                          [attachment=1:2jr1xk38]<!-- ia1 -->1 Capture dโ€™รฉcran 2017-03-03 ร  15.47.15.png<!-- ia1 -->[/attachment:2jr1xk38]
                                          Versus stick framed like this
                                          [attachment=0:2jr1xk38]<!-- ia0 -->1 stick framed.jpg<!-- ia0 -->[/attachment:2jr1xk38]
                                          With the Deep l translator I said I don't do any timber frame designs, and the translator made it 'wooden frame' instead of timber frame.
                                          Joe Wood
                                          woodsshop.com/
                                            I believe that is "Cadre Poteau / Poutre en Assemblage ร  mi-bois en partie haute"
                                            (Post / beam frame in half-timbered assembly in upper part)
                                            I suppose mortise tenon assembly in lower part = assemblage tenon mortaise en partie basse
                                            if i can good see the side view (that is not evident! ๐Ÿ˜„
