    Construction Methods In France Questions
    26 Posts 4 Posters 5.4k Views 4 Watching
      Poteaux = Vertical
      Poutres = Horizontal or inclined
      floor framing = l'ossature du plancher, la structure du plancher, le support du plancher...la charpente du plancher πŸ˜„
        Sure! πŸ˜„
        Poteaux / Poutres ?
        An image can better explain than a text! πŸ˜‰
        • Joe WoodJ Offline
          Joe Wood
          This is floor framing
          this is wall framing
          and these are the posts and beams πŸ™‚
          Joe Wood
          woodsshop.com/
          • Joe WoodJ Offline
            Joe Wood
            My questions are
            What do you call posts and beams in France, Poteaux et poutres?
            and floor framing, charpente du plancher ?
            Joe Wood
            woodsshop.com/
              Ok! So what is the question(s) ? πŸ˜„
              If this exist also in France ?
              Put "ossature bois" inside google research image! πŸ˜‰
              "plancher Γ  ossature bois"
              "charpente Γ  ossature bois"
              "mur Γ  ossature bois"
                Affirmative! πŸ˜„
                Post = Poteau (un poteau, le poteau)
                Beam = Poutre (une poutre, la poutre)
                floor framing = l'ossature du plancher, la structure du plancher...la charpente du plancher! πŸ˜„
                • Joe WoodJ Offline
                  Joe Wood
                  Thank you Frenchy, say, is all that artwork on your site digital or do you do any traditional artwork?
                  Joe Wood
                  woodsshop.com/
                    Only digital, but it's just hobbyist relaxing for explore crazzy progs! πŸ˜„
                    • Joe WoodJ Offline
                      Joe Wood
                      Frenchy, what is the French for timber frame? Like with this photo, with the structure joined with mortises and pegs?
                      [attachment=1:2jr1xk38]<!-- ia1 -->1 Capture d’écran 2017-03-03 Γ  15.47.15.png<!-- ia1 -->[/attachment:2jr1xk38]
                      Versus stick framed like this
                      [attachment=0:2jr1xk38]<!-- ia0 -->1 stick framed.jpg<!-- ia0 -->[/attachment:2jr1xk38]
                      With the Deep l translator I said I don't do any timber frame designs, and the translator made it 'wooden frame' instead of timber frame.
                      Joe Wood
                      woodsshop.com/
                        I believe that is "Cadre Poteau / Poutre en Assemblage Γ  mi-bois en partie haute"
                        (Post / beam frame in half-timbered assembly in upper part)
                        I suppose mortise tenon assembly in lower part = assemblage tenon mortaise en partie basse
                        if i can good see the side view (that is not evident! πŸ˜„
                        • Joe WoodJ Offline
                          Joe Wood
                          Merci encore Frenchy!
                          Joe Wood
                          woodsshop.com/
                            Please read your PM system! πŸ˜‰
                            • 2 / 2
